Inadvertent hardtail
Discussion in 'UK Motorcycles' started by TOG@Toil, Sep 15, 2010.
  1. TOG@Toil
    TOG@Toil Guest
    The GN250 toppled off its sidestand the other day, and came down
    resting on the low wall separating the Chateau's front hardstanding
    from that of the neighbours. A couple of small scrtaches in the side
    panel, so I wasn't bothered.
    But yesterday I thought it felt a bit harsh at the back end. Same this
    morning and at the traffic lights I bounced experimentally on the
    seat. The swinging arm didn't budge. Oops.
    Investigation revealed the impact also knocked the left-hand rear
    shock, and probably bent the damper rod fractionally. It compresses
    but won't rebound. Oh well, the shocks were 20 years old and nasty
    anyway, so it needed a new set.
    Meanwhile, I've got a hardtail custom *Proud*.
  2. TOG@Toil
    Simon Wilson Guest
    <buys Anusol shares>
    Simon Wilson, Sep 15, 2010
  3. TOG@Toil
    ian field Guest
    My CB200 could do with thrashing over a few pot holes with the nut off the
    swingarm bolt - pity I had to SORN it.
    ian field, Sep 15, 2010
  4. TOG@Toil
    SIRPip Guest
    That should press the grapes nicely.
    SIRPip, Sep 15, 2010
  5. TOG@Toil
    crn Guest
    www.hagon-shocks.co.uk
    Sorted.
    crn, Sep 15, 2010
  6. TOG@Toil
    boxerboy Guest
    Given the low tech nature and the need to keep commuting costs replace
    them with two hefty pieces of wood.
    Boxerboy
    boxerboy, Sep 15, 2010
  7. TOG@Toil
    ian field Guest
    Back when I had an old B25FS someone tried to sell me a couple of twisted
    wrought iron struts as a hardtail conversion, a couple of months later he
    had them on his own bike - he did at least fit a fat back tyre.
  8. The fat 16" tyre on the GN is the only thing that stopped my lower spine
    from fracturing today.
    I'll take another bike to work tomorrow, and the GN can sit until I get
    the new shocks.
    The Older Gentleman, Sep 15, 2010
  9. TOG@Toil
    ian field Guest
    There was a time me and a few lads were a bit too noisy and exhuberent in
    one of the pubs out in the villages, when we came out at closing time some
    of the bikes were on their sides - someone had reversed into them as a
    parting gift.
    The only damage we noticed before setting off was one of the bikes rear
    mudgard was bent against the back wheel, so we straightened that and off we
    went.
    Halfway round the first fast bend I discovered that the car had clipped one
    of my rear shocks which on compression - jammed.
    As the back wheel got away I turned into the slide, which took me halfway
    across a field of barley (not wearing gloves!).
    Not realising I'd cleared a ditch on the way in, I fell in it pushing the
    bike back to the road.
    ian field, Sep 16, 2010
  10. <snip>
    Replacement shocks were waiting on the mat when I got home. Very good -
    only ordered them from Wemoto yesterday morning.
    AND THEY DON'T FUCKING FIT.
    They're 20mm too long - the domed nut on the bottom mount fouls the
    silencer. Grrrrrr....
    The Older Gentleman, Sep 16, 2010
  11. TOG@Toil
    I've only ever ordered one thing from Wemoto - an SV650 clutch cable.
    It didn't fit.
    Angle grinder.
    Krusty, Sep 16, 2010
  12. TOG@Toil
    I ordered a battery and a brake lever for the RGV from Wemoto. Both were
    cheap, delivered quickly and fitted perfectly.
    ogden, Sep 16, 2010
  13. TOG@Toil
    ian field Guest
    That happened to me when I bought shocks for the 200.
    Bearing in mind the swingarm bushes are siezed, I pressganged a neighbour
    into slipping the bolt in at the bottom while I levered the wheel down with
    a length of angle iron under the mudgard.
  14. I did consider that the old shocks might have compressed with age and
    got shorter. And other ads for GN250 shocks quote a centre-to-centre
    eyelet length of 335mm - which is what the Wemoto ones are. The OE ones
    are 315mm. I'd have thought a 20mm shortening unlikely.
    But still, you can't fit the bastards without the bottom securing nut
    whacking the silencer on full extension.
  15. TOG@Toil
    ian field Guest
    Last time I had that problem, a suitable clearance was introduced with a
    ball pein hammer.
    ian field, Sep 17, 2010
Similar Threads
Loading...
