Interesting viewpoint
Discussion in 'UK Motorcycles' started by Wicked Uncle Nigel, Jun 27, 2007.
  1. It might if you had to lick it off with your tongue. I think the court
    omitted to ask that question, though
    -dan
    Daniel Barlow, Jun 28, 2007
  2. at slow speeds yes, the nub is the speed. you can manover a car on ice
    that you'll struggle to stand on but only at very low speeds. at 50
    wouldn't of required much ice to get the car sliding then it's weight
    will do the rest.
    it's the reason i favour small cars in snow and ice, they don't try to
    carry on, if they do slide it's much more recoverable.
    a 50mph on bike would be terrifing on ice but it wouldn't have the
    weight that a car does.
    roger
    Roger Merriman, Jun 28, 2007
  3. Wicked Uncle Nigel
    Err... yes there is. It's a lockable diff that isn't locked in
    full-time 4WD mode but selecting part-time 4WD locks it.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    '02 MV Senna '03 Tigtona 955i '96 Tiger '79 Fantic Hiro 250
    Krusty, Jun 28, 2007
  4. Wicked Uncle Nigel
    Peter Clinch Guest
    Should you want to do such a thing, why is that not reasonable?
    But a lot less likely than faster will provide.
    That wasn't what you asked though. You asked me how long it would take
    at 10 mph to get between a couple of places, and how long I'd drive at
    10 mph before speeding up.
    A greater degree of caution is required if it's sub-zero to if it's over
    zero, for the duration of the trip. That's all, nothing about requiring
    anyone to go at 10 mph.
    Pete.
    Peter Clinch, Jun 28, 2007
  5. Wicked Uncle Nigel
    He's got one - Ace is wrong. You can get Cherokees with two types of
    transfer case - SelecTrac which has a centre diff allowing full-time
    4WD, & CommandTrac which which hasn't got a diff & just locks the
    driveshafts together, hence can only be used in 4WD on slippery
    surfaces.
    Krusty
  6. Wicked Uncle Nigel
    Bryan Guest
    Is this a grammar troll ?
    Bryan, Jun 28, 2007
  7. Wicked Uncle Nigel
    but your explanation doesn't make sense - why does the manual (and
    naggers in the car itself) tell me *to* use permanent 4x4 on the road
    (which has the wheels in lock-step) rather than part-time 4x4?
    darsy, Jun 28, 2007
  8. Wicked Uncle Nigel
    OK, so that makes some sense.
    "it's nature's way". I was faffing about in the RX-8 at the weekend,
    in very wet conditions, and it's simply amazing what sort of corner
    speeds in crap conditions that the Dynamic Stability Control will let
    you achieve.
    Fortunately, you can turn it off, and get the whole arrangement
    sideways on the exit from roundabouts...
    darsy, Jun 28, 2007
  9. Wicked Uncle Nigel
    I'm sure the huge queue of traffic behind you could answer that
    question.
    Not necessarily, but even if that were true, it's a lot more likely
    than 20mph will provide.
    Err... oh never mind.
    Which by definition means a lesser degree of caution is required if
    it's over zero - meaning you're more likely to be caught out by a patch
    of black ice in a shaded dip.
    By all means carry on making your judgements based on the air
    temperature when you get in the car. I'll stick to basing my judgements
    on the actual road conditions tyvm.
    Krusty
  10. Wicked Uncle Nigel
    that would appear to be the case - ta.
    darsy, Jun 28, 2007
  11. Wicked Uncle Nigel
    Not for serious off-roading. Viscous diffs require a certain amount of
    spin before they'll engage, which isn't necessarily A Good Thing.
    Viscous diffs that can also be manually locked otoh would be ideal.
    Krusty
  12. Wicked Uncle Nigel
    Yes, yes, all right, I should have added the text 'when the mde to
    which darsy was referring is selected'.
    _______
    \`\ | /`/ DS#8
    Ace, Jun 28, 2007
  13. Have you ever had even a vague connection with reality?
    Phil
    Phil Launchbury, Jun 28, 2007
  14. Wicked Uncle Nigel
    Pathetic! You don't think you're gonna get away with it that easily do
    you?
    Krusty
  15. Wicked Uncle Nigel
    Peter Clinch Guest
    But since you've just done your "let's pluck an irrelevant condition out
    of the air" trick again, that's not really an apposite point.
    The *probablity* will go up, because the kinetic energy has gone up.
    True, but, errrr, so what? The point is you should be more cautious
    than you would otherwise be.
    Oh deary me. I'm big enough to admitr I wasn't careful enough with my
    wording, it's a shame you're daft enough to think facile nit-picking
    helps. If it's /near/ zero. There, better?
    What, like the chap who wiped out 4 people was doing?
    Pete.
  16. Wicked Uncle Nigel
    Watch me.
    _______
    \`\ | /`/ DS#8
    Ace, Jun 28, 2007
  17. Wicked Uncle Nigel
    A few years ago I took the thing to Tuscany, and was staying at a
    complex of villas at the top of a very windey steep gravel and dirt
    track - one of the most enjoyable bits of the whole holiday was
    putting the thing into 4WD and driving up/down the hill at about 4
    times the speed of everyone else staying there (almost exclusively
    germans in Mercs). 4x4s rock.
    On the other hand,, the last time I put it into FWD, it made a sort of
    whining screech for a little bit, which then went away - is this
    normal, or is it going to go bang?
    darsy, Jun 28, 2007
  18. Wicked Uncle Nigel
    TimP Guest
    What? This from the twat who was nit-picking about the 10 mph. You are
    an exceptionally dull man.
    TimP, Jun 28, 2007
  19. Wicked Uncle Nigel
    Jérémy Guest
    Both. HTH.
    Jérémy, Jun 28, 2007
  20. Wicked Uncle Nigel
    Could be it got stuck in the no man's land between full & part-time
    4WD. Mine's done it a couple of times, & I've had to find a bit of
    grass to drive on while it sorts itself out.
    A handy tip is don't try to select 4WD until you've done a few miles to
    warm the transfer box oil up.
    Krusty
