Invite to members of uk.rec.motorcycles
Discussion in 'UK Motorcycles' started by pcman, Jun 15, 2010.
  1. pcman
    Paul - xxx Guest
    Nah fanks I is happy in my iggerance.
    Paul - xxx, Jun 15, 2010
  2. pcman
    Derek Turner Guest
    Here's a few to start with:
    HTML Errors
    E604 - 1 instance(s): According to the HTML specification being validated
    against, the tag must have an end tag. Sometimes this error is caused by
    improperly nested tags where the end tag exists but cannot be matched
    with the corresponding start tag.
    E610 - 1 instance(s): The HTML specification being tested against defines
    that the tag identified must have one or more specific tags nested within
    it. You should add one or more of the missing tag(s) as appropriate.
    E620 - 1 instance(s): The most common reason for this error is the use of
    a browser-specific attribute (such as 'leftmargin' in the <body> tag),
    which is not part of the official HTML specification being tested
    against. If the attribute is for purely for layout then consider using
    CSS instead.
    E630 - 1 instance(s): When 'id' and 'name' attributes appear in the same
    element they must have the same value. See http://www.w3.org/TR/html401/
    struct/links.html#h-12.2.3 (displayed in new window).
    E631 - 2 instance(s): All 'id' and anchor 'name' attributes in the same
    document must have unique values. See http://www.w3.org/TR/html401/struct/
    E649 - 10 instance(s): When intrinsic events (onclick, onmouseover etc)
    are specified the default scripting language should be specified using a
    Content-Script-Type HTTP header or <meta> tag. See http://www.w3.org/TR/
    html401/interact/scripts.html#h-18.2.2.1 (displayed in new window).
    E651 - 1 instance(s): When you include a 'for' attribute to associate a
    label with a control you must provide a control with a matching 'id'
    value in the same form. Referencing controls in different forms, or
    outside of forms produces an inaccessible page.See http://www.w3.org/TR/
    html401/interact/forms.html#h-17.9.1 (displayed in new window).
    WCAG v2 A Errors
    E831 - 1 instance(s): Associate labels properly with their controls. See
    http://www.w3.org/TR/WCAG20-TECHS/H44.html (displayed in new window)
    E872 - 1 instance(s): You must provide a mechanism that allows users to
    explicitly request changes of context. The intended use of a submit
    button is to generate an HTTP request that submits data entered in a
    form, so it is an appropriate control to use for causing a change of
    context. See http://www.w3.org/TR/WCAG20-TECHS/H32.html (displayed in new
    window)
    E883 - 11 instance(s): Heading elements must be ordered properly. For
    example, H2 elements should follow H1 elements, H3 elements should follow
    H2 elements, etc. Developers should not skip levels or use headings for
    presentation effects. See http://www.w3.org/TR/WCAG20-TECHS/F43.html
    E885 - 1 instance(s): Associate labels properly with their controls. See
    http://www.w3.org/TR/WCAG20-TECHS/F68.html (displayed in new window)
    E886 - 4 instance(s): Although HTML may allow the 'alt' attribute here,
    it should only be used on image submit buttons. User agent support for
    this attribute on other types of form controls is not well defined. Other
    mechanisms are available to label these controls. See http://www.w3.org/
    TR/WCAG20-TECHS/H36.html (displayed in new window)
    E892 - 1 instance(s): Tags that are being used purely to create a visual
    presentation effect should not be used. You should use CSS to control
    layout and presentation so that users and their aids may control it. See
    http://www.w3.org/TR/WCAG20-TECHS/G140.html (displayed in new window)
    E894 - 2 instance(s): IDs must be unique within a document to ensure that
    Web pages can be interpreted consistently. See http://www.w3.org/TR/
    WCAG20-TECHS/F62.html (displayed in new window)
    E895 - 1 instance(s): References to other parts of the same document must
    exist to ensure that Web pages can be interpreted properly. Note that
    certain attributes such as 'for' can only reference certain elements in
    the same %lt;form>, others can only reference elements in the same table.
    See http://www.w3.org/TR/WCAG20-TECHS/F62.html (displayed in new window)
    E898 - 4 instance(s): If you have different links with the same link text
    it can be confusing to the user. So you should either change the link
    text or add a unique 'title' attribute to each link. See http://
    www.w3.org/TR/UNDERSTANDING-WCAG20/navigation-mechanisms-refs.html
    Derek Turner, Jun 15, 2010
  3. pcman
    davethedave Guest
    It's for advertising revenue.
    davethedave, Jun 15, 2010
  4. pcman
    davethedave Guest
    Seems a bit buggy to me. :)
  5. pcman
    pcman Guest
    pcman, Jun 15, 2010
  6. pcman
    Derek Turner Guest
  7. pcman
    davethedave Guest
    I got 2,740,000 for "more unique" quoted and 385,000,000 unquoted.
    However as you didn't quite point out the fact that 2,740,000
    people are wrong does not make it right.
  8. pcman
    freewarer Guest
    See what you mean.
    OK due to the negative feedback I have recieved on here, some good
    some not worth reading I am closing the site for redesign
    Thanks to all for taking the time to visit the site.
    freewarer, Jun 15, 2010
  9. pcman
    Yes, _I_ know that, and also that this twat won't get any.
    Ace, Jun 15, 2010
  10. pcman
    Yeah he didn't rise to my comment about Not for Profit.
    So, just another spamming git.
    Hog, Jun 15, 2010
  11. Heh.
    Didn't take us long, did it? :))
    The Older Gentleman, Jun 15, 2010
  12. pcman
    Nige Guest
    **** off ya mong...
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Jun 15, 2010
  13. pcman
    Yay!
    Pip Luscher, Jun 15, 2010
  14. pcman
    Catman Guest
    That's possibly the most concerning[1] thing is that he didn't notice.
    [1] For certain VV small values of disturbing. Frankly I DGAF.
    www.cuore-sportivo.co.uk
    Catman, Jun 15, 2010
  15. pcman
    Catman Guest
    There are 3 millions copies of The Sun sold every day. You're point is?
  16. pcman
    petrolcan Guest
    What camera/lens combo were you using?
    petrolcan, Jun 15, 2010
  17. pcman
    davethedave Guest
    Well that free website content thing has done its run I'd say.
    We provide the content and consume his ads.
    I say Noooooooo!
  18. pcman
    petrolcan Guest
    The IS lens or did you mean the 75-300?
    Extension tubes are a cheap way into macro.
    http://picasaweb.google.co.uk/petrolcan/Macro#
  19. pcman
    petrolcan Guest
    Tamron are quite good.
    If that was shop bought new, that was a good price.
    I've never liked the idea of a reversing as it exposes the most
    important optic and close up filters are crap.
    I generally use handheld for macro.
    40D, kenko extension tubes and either a 50mm 1.4 or 28-135 IS.
    I was bored on a Saturday morning and decided to justify the extension
    tubes that I've had for over a year.
    petrolcan, Jun 16, 2010
  20. pcman
    A Saab
    Lozzo, Jun 16, 2010
