IOM mountain course and others,...
Discussion in 'UK Motorcycles' started by Gavsta, May 29, 2009.
  1. Gavsta
    Gavsta Guest
    Just a heads up for anyone bobbing over in the next week or so.
    Even BEFORE the temp speed limits are in place there has been some areas
    extended - notably is Ballahutchin, its now a 40 until about halfway up
    (presumably due to the blind dip), and the entry to Ballaugh is now a 40
    further back than it used to be.
    The normal restrictions from Kates to Douglas will be in place, what out
    for speed traps at Brandish, lots of bikes get caught there, and also
    the road between Sulby and Ramsey, its a 50 and there are a lot of blind
    corners that plod seem to like to have a radar gun the other side of.
    More worrying (from a fun point of view), is that I spotted the markers
    that are down for coneing off the Mountain today. It looks like its
    cones almost all the way to the Gooseneck, a lot further than it used to
    be (this tends to be a 60 limit as well until past the Gooseneck).
    But there are a lot more markers after the Veranda - time will tell, but
    it looks a lot more than previous years.
    Having done two laps in the work van today, it appears (although
    probably not) that viewing is highly restricted. I dont understand why
    in some spots, but you will have to find a good spot early or its likly
    to be taken.
    Ill be out on the bike on Sat with a couple of mates and so will be able
    to see how bad the mountain is,..
    Gavin.
    For the road: GSXR600K1
    For the track: <gone>
    Current project: Peugeot Speedfight 2
    For everything else: Citroën Berlingo
    MSN:
    Twitter: http://twitter.com/gavin_wilby
    Blog: http://www.stoof.co.uk
  2. Gavsta
    I'm glad I got over for the Centenary and a year or two before and
    after, because it sounds like the Nazis have taken over the island.
    Actually I suppose it was like Chile.....
    Hog, May 29, 2009
  3. Gavsta
    Gavsta Guest
    OK,
    Went out yesterday, and its actually not that bad. Its coned to the
    Waterworks and then open, but the 60 limit is right past the Gooseneck
    and only opens up about 200 yards further on.
    Its then open and unrestricted all the way to the straight bit before
    The Bungalow - so what the markers are for round the Veranda I have no
    idea. Its then open and free until the left hander before Kates Cottage.
    Your then in a 50/40/60 until Brandish. There are also traffic lights at
    the Creg (good idea actually).
    There are 4 unmarked police cars circulating all the time apparently,
    and there was a speed gun between Ginger Hall and Ramsey (the bit where
    the DOT buildings are). There are temp speed restrcition to look out for
    (I forgot about the bit after Handleys, and was hooing, until I came
    across a derestrict sign :(
    Out of Douglas is normal.
    Union Mills, to Crosby is now a 30 ALL THE WAY.
    Its then a 50 all the way to Ballacraine.
    Normal 60 through Glen Helen.
    Unrestricted to Handleys, and then a 60 to just before Kirk Micheal.
    Normal roads then until Ramsey and then the restrictions as above.
    And the one nobber I saw happened to be a local lad on a Motard.
    Gavin.
    MSN:
    Gavsta, May 31, 2009
  4. Gavsta
    Eiron Guest
    Coned off? What do you mean? And why is it good to have traffic lights there?
    It wasn't necessary twenty years ago when I last went, when there were more bikes about.
    Eiron, May 31, 2009
  5. Gavsta
    Gavsta Guest
    Coned as in the roads one way, but half the road is blocked off.
    Ill use this as an excuse to post my vid again so you can see:
    the lights are a good idea, as you can see round the bend going UP to
    the creg, and it allows ppl to get to the slip road easily and safely,
    as thats where the one way starts (or indeed, finishes).
    20 years ago the road wasnt one way for 2 weeks now was it?
    Gavin.
    MSN:
  6. Gavsta
    Gavsta Guest
    Actually, after re-watching, the video shows you **** all thats relevant.
    Sorry about that.
    Gavin.
    MSN:
  7. Gavsta
    Eiron Guest
    It shows what you meant by 'coned off'. Thanks.
    Don't see the point of blocking half the road as well as making it one-way.
    Did they get Brunstrom in as a consultant?
    Eiron, May 31, 2009
