Is it bad form to...
Discussion in 'UK Motorcycles' started by YTC#1, Aug 26, 2010.
  1. YTC#1
    YTC#1 Guest
    .... filter between a funeral proccession ?
    Just asking.
    YTC#1, Aug 26, 2010
  2. YTC#1
    rick Guest
    Only if you wheelie
    rick, Aug 26, 2010
  3. YTC#1
    YTC#1 Guest
    I'll try harder next time
    YTC#1, Aug 26, 2010
  4. YTC#1
    davethedave Guest
    Not at all. Proper etiquette as explained in Debrett's
    http://www.debretts.com/search.aspx?search=funerals
    Would be to salute the deceased as you pass. Policemen on foot
    should remove their hats as a sign of respect as the cortège
    passes. Sadly a tradition which seems to be dying.
    The correct and proper form of respect from the passing
    motorcyclist would be to salute left handed facing left
    whilst holding a steady one handed mono. Careful use of the
    rear brake for balance and control is recommended.
    Also remember if your exhaust is loud enough to wake the dead
    then it will be an occasion for joy and not sorrow.
    One further point, the conductor of the funeral will be distributing
    kudos in a manner relating to how much of a traffic jam can be
    caused by the driver of the hearse. The previously held record being
    from South Mymms roundabout all the way to Cockfosters. It only counts
    if it makes the traffic report.
    If you can make it past both the limousine and the hearse on one wheel
    the drivers get a lower share of the kudos in deference to the bearers.
    Be aware that the vehicle operatives whilst travelling at such a slow
    speed are probably eyeing up roadside female pedestrians and rating
    them out of 10. With one being the highest score. This inevitably means
    that concentration is not at it's highest in the funeral vehicles.
    Finally remember. Respect the dead. Give only your finest wheelies.
    We'll all be there one day.
    davethedave, Aug 26, 2010
  5. YTC#1
    boxerboy Guest
    Only if you fart
    Boxerboy
    boxerboy, Aug 26, 2010
  6. YTC#1
    nicknoxx Guest
    I'm not sure I should admit this on here but in the last month I've
    twice been overtaken by a hearse. Ok, I was in the van doing 60 on a
    dual carriageway but even so, it's still a bit of a surprise.
    nicknoxx, Aug 27, 2010
  7. YTC#1
    YTC#1 Guest
    Was the stero playing "Get me to the church on time " ?
    YTC#1, Aug 27, 2010
  8. YTC#1
    Switters Guest
    <applause>
    Switters, Aug 27, 2010
  9. <snip>
    Excellent.
    The Older Gentleman, Aug 27, 2010
  10. YTC#1
    zymurgy Guest
    Don't try it in Norn Iron
    Paul.
    zymurgy, Aug 27, 2010
