Is this typical ..
Discussion in 'UK Motorcycles' started by T i m, Aug 28, 2008.
  1. T i m
    ianmcdonald Guest
    If the system has been fitted incorrectly - and then run like that-
    the pipes will tend to "heat set" to that incorrect position. But
    certainly loosening the bracket and moving it around could well help
    ianmcdonald, Sep 1, 2008
  2. T i m
    Eiron Guest
    Chinese exhausts don't fit?
    Does that mean they were copying Micron designs instead of Motad?
    Eiron, Sep 1, 2008
  3. T i m
    T i m Guest
    Ok, well luckily it's only in the vertical plane and should be
    absorbable in the mounting bracket in any case.
    All the best ..
    T i m
    T i m, Sep 1, 2008
  4. T i m
    Way hey!
    Rub the old zutty pipe hard enough and a genie /will/ pop out of the
    end of it.
    Lurking isn't underhand, Ian - it is merely a usenet term for people
    who read but don't habitually post replies, or start threads. The
    ratio is reckoned to be 10 lurkers to every poster, so you're in the
    majority. You carry on lurking man, especially if you're going to pop
    up and sort queries when they arise.
    Goodonyer.
    Pip, Sep 4, 2008
  5. T i m
    ianmcdonald Guest
    Just as well i know more about exhaust systems than I do about
    internet slang!
    ianmcdonald, Sep 4, 2008
  6. T i m
    On mailing lists, where you have to register to recieve the emails,
    the sysadmin knows how many registered users there are, and how many
    of them are posting. The 10:1 ratio comes from there.
    Champ, Sep 4, 2008
  7. T i m
    An oft used analogy is that UKRM is a bit like a pub. Lurking is like
    going to the same pub every night, always sitting next to the same
    group of people and listening in on every conversation they have, but
    never saying hello.
    Creepy.
    ogden, Sep 4, 2008
  8. T i m
    des Guest
    The analogy is flawed. You don't normally walk into a pub and get set
    upon by half a dozen of the regulars, for no other reason than having
    expressed your opinions (irrespective of how 'controversial').
    D.
    des, Sep 4, 2008
  9. T i m
    SD Guest
    Not repeatedly, no.
    I don't normally walk into a pub and shout "you're a wanker!, and you,
    and you, too" and expect a civil reception when I've done it every
    weeknight for six months either.
    SD, Sep 4, 2008
  10. T i m
    des Guest
    When have I ever called you a wanker, Nick? I still haven't forgotten
    the huge bag of crispies..
    D.
    des, Sep 4, 2008
  11. T i m
    All the lurkers that email me just want to talk about sex or how they
    know a way I can stay up all night. My problem is sleeping, so it just
    shows how much they fucking read.
    sweller, Sep 4, 2008
  12. T i m
    If I went into a pub and was set upon by the regulars a few times I
    might realise that they didn't want me there and find somewhere else
    to go. That could be because I'm clever enough to be able to see these
    things whereas not everybody else would manage that.
    Why haven't you fucked off yet?
    Andy Bonwick, Sep 4, 2008
  13. T i m
    I don't know whether my odd emails come from lurkers, but all they ever
    say is something about sleeping with the fishes - I'm fucked if I know
    what they're on about, it's their wives I've been sleeping with.
    Lozzo, Sep 4, 2008
  14. T i m
    des Guest
    Because I'm right.
    HTH.
    D.
    des, Sep 4, 2008
  15. T i m
    That would probably hold true if usenet was the only place you could read
    ukrm. More places than Google replicate our wibblings.
    platypus, Sep 4, 2008
  16. The couple of lists I look after (3 low-volume and one higher volume)
    has roughly that ratio.
    Phil
    Phil Launchbury, Sep 5, 2008
  17. T i m
    The only emails I've had from lurkers are along the lines of "Get well
    soon"
    Champ, Sep 5, 2008
  18. Using the patented Mavis Beacon "Hunt&Peck" Technique,
    typed
    <thread hijack>
    You boys got any plans for the GTR1400? Something a little... smaller in
    the can dept?
    Wicked Uncle Nigel, Sep 6, 2008
  19. T i m
    Nice set of straight through slash cuts would be good...with some
    leather tassles for your bar ends thrown into the deal.
    Lozzo, Sep 6, 2008
  20. Using the patented Mavis Beacon "Hunt&Peck" Technique, Lozzo
    "Set"? It's a 4-1, you iggerant Spic.
