It lives!!!!!
Discussion in 'Australian Motorcycles' started by Fraser Johnston, Sep 19, 2008.
  1. My K7 GSX-R 1000 I picked up at the auctions finally lives. After iks
    post about security systems and new Suzukis I jumped on Perth Street
    Bikes to see if I could find the key for it. As luck would have it the
    previous owner contacted me and he still had both keys. Saving me $2300
    for a new ecu and lockset. : ) I was a happy camper. Today my radiator
    arrived from the states and I installed it. After addding coolant it
    fired up first push of the button and purred. So now all I need is a
    headlight, my plastics from Hong Kong and maybe a rear subframe and it
    should be on the road. Can't wait. I reckon it is about 4 weeks away.
    After a country ride on the Triumph this week I've decided to get rid
    of it and keep the gixxer. It just fits me better and the Trumpy kills
    my wrists after 50kms.
    Fraser
  2. Fraser Johnston
    Biggus :)~ Guest
    It just fits me better and the Trumpy kills my wrists after 50kms.
    LOL! Wait till u see what the GSXR does to ya wrists then! Bloke I
    raced with has one, he only does short shots as it fucks his wrists,
    the leaning angle on them.
    Biggus :)~, Sep 19, 2008
  3. Fraser Johnston
    Fraser's a 675 Date-owner.
    Knobdoodle, Sep 19, 2008
  4. Yeah Suzukis quote for it. There is no way they can replace lost keys
    according to the 4 dealers I rang. Pain in the arse.
    Got the radiator for $300 off US ebay. Cheapest quote here from the
    dealer was $650.
    Subframe may be a little bent. If it is I'll replace it. Won't know
    until I get all the plastics off.
    Trumpy is a Daytona 675.
    Fraser
    Fraser Johnston, Sep 20, 2008
  5. Way better fit for my body type on the gixxer. Horses for courses and
    all that. The gixxer is a lot lower as well. You really perch on the
    Daytona. Plus I miss the mid range stonk of the Blackbird and the
    Suzuki should have that in spades.
    Fraser
  6. Fraser Johnston
    CrazyCam Guest
    Owning a Daytona 675 is OK, but riding one takes a committed masochist.
    regards,
    CrazyCam
    CrazyCam, Sep 20, 2008
  7. Fraser Johnston
    atec77 Guest
    Are you under 6' ?
    atec77, Sep 20, 2008
  8. Fraser Johnston
    CrazyCam Guest
    Well under. I used to be 5'10" before the operation.
    regards,
    CrazyCam
  9. Fraser Johnston
    atec77 Guest
    I have ridden one for some distance but I have long limbs and stall much
    taller than you , perhaps if you use top gear and stay moving it will
    ease the wrists ?
  10. Fraser Johnston
    CrazyCam Guest
    Mate, I can't even sit on a Daytona in the showroom, which is why I have
    the Street Triple.
    I can do the curled up leg bit, since I've got the Daytona pegs fitted,
    but having the hands that far forward and down is way too much for me.
    I can understand that most folk riding them are younger, fitter and
    bendier than I am...... not a big ask! .....but even at that, I still
    reckon that doing a 1,000kms in a day would require serious amounts of
    masochism.
    I can imagine, from how the Striple goes, that the Daytona is a really
    nice sports bike, but it'll never, sensibly, be called a sports/tourer. :)
    regards,
    CrazyCam
    CrazyCam, Sep 21, 2008
  11. I concurr. At 5'10" as well the riding position is truly awful for me.
    That is the main reason I am getting rid of it.
    Fraser
    Fraser Johnston, Sep 21, 2008
  12. Fraser Johnston
    Toosmoky Guest
    If your weight is on your wrists, then you're doing it wrong.
    Toosmoky, Sep 21, 2008
  13. Fraser Johnston
    CrazyCam Guest
    Thanks mate, but I have a wife to tell me that sort of stuff.
    regards,
    CrazyCam
  14. Fraser Johnston
    CrazyCam Guest
    Johno wrote:
    Cheers, mate.
    BTW I had a bottle of the Coopers "hi-octane" ale yesterday (7.5%), and
    it was very nice.
    regards,
    CrazyCam
  15. Tell us how to do it right.
    Fraser
    Fraser Johnston, Sep 22, 2008
  16. In aus.motorcycles on Mon, 22 Sep 2008 08:22:44 +0800
    THe spine is a rope. to keep the shoulders up you have to brace the
    spine to make it a braced rope.
    If you just tense the back muscles then it might pull the shoulders
    back but it will pull the back ino a curve and most of the body will
    still be forward.
    So you engage the core muscles - abs and obliques and corset - to
    stabilise the lower back in neutral spine position so it's not
    overarched and the spinal erector muscles have something to pull
    against to keep the upper body where it's supposed to be.
    You then brace the hips in neutral position by using the lower abs and
    hip flexors and upper quads so the legs help to position and stabilise
    the torso.
    The end result is holding the upper body up the way you are supposed
    to rather than leaning on your hands and putting silly steering inputs
    in.
    (And the ability to hold the body straight and where you want it without
    putting too much weight on your hands while bracing the hips and steering
    straight has other uses....)
    Zebee
    Zebee Johnstone, Sep 22, 2008
  17. Fraser Johnston
    My lovely wife's crook back means that she's not getting much use out
    of her Hyosung GT650R. After looking at the website pix of the GT650R
    and GT650S, it seems to me that replacing the clip-ons with riser bars
    should be quite doable:
    http://www.hyosung.com.au/Products/GT650R.html
    http://www.hyosung.com.au/Products/GT650S-Tourer.html
    Swapping the screen, handlebar brackets, upper brake line, clutch &
    throttle cables should do the trick. Now I just have to get her to
    test ride a GT650S before I start spending money...
    BT Humble, Sep 22, 2008
  18. Or you just ride ridiculously fast so air pressure takes the weight
    off your wrists. Works for me.
    Kevin Gleeson, Sep 22, 2008
  19. Fraser Johnston
    bikerbetty Guest
    Well.... when you have a bike, anyway..... <evil wicked grin>
    betty, running away
    PS does that really work? And does it help with the shoulder twinges, or are
    they just a consequence of me being old and arthritic? Wrists be fine, lower
    back be fine.... shoulders seem stuffed...
    bikerbetty, Sep 22, 2008
  20. Fraser Johnston
    JL Guest
    Yes, and on a naked bike it requires lower speeds than a faired bike
    JL
    JL, Sep 22, 2008
