It never rains...
Discussion in 'UK Motorcycles' started by Pip Luscher, Jul 27, 2005.
  1. Pip Luscher
    ... but it don't half pour.
    Just recently the Quota's been a bit slow starting - sometimes it
    would churn without firing. A quick flick off/on of the ignition and
    it'd fire.
    Well, yesterday it refused to start at all, but started fine that
    evening. I figured that it was an intermittent relay, which is an easy
    fix, so wasn't too bothered.
    This morning again it wouldn't start, but dicking with the relays got
    it going. So far, so good.
    This evening, I pressed the starter, and, to my surprise, the engine
    turned once before the starter relay started chattering - a sure sign
    of a flat battery. WTF?
    With much messing about, including scraping the relay contacts clean
    to get the ignition working, and a jump start, I got home.
    So it seems that I have a dodgy relay and, totally unrelated, the
    battery's not charging properly. The battery is now on the Accumaate
    but it's not really showig the sort of voltage I'd expect, so it
    *looks* as though it's the battery at fault, but we'll see.
    In a sense that could be good news because the Quota uses a Ducati
    alternator with a matching reg/rec and yes they're expensive and no,
    there are no cheap aftermarket repalcements, unlike Bosch ones.
    The only really good news was that a week or two ago I replaced one of
    the coils and this seems to have cured an intermittent wet-weather
    misfire; the journey home was actually quite pleasant.
