It's all so bloody tiresome.
Discussion in 'UK Motorcycles' started by sweller, May 8, 2008.
  1. sweller
    In an attempt to cure the petrol drinking tramp's problems on Monday I
    had the carbs off (again) to sort out the still sticking slides properly.
    No great shakes, got all the float bowls off, nice and clean. Went to
    remove the diaphragm caps and cheese screws meant I ended up with one
    sheared off.
    Couldn't get a decent purchase so tacked another bolt to the stub with
    the welder. Hey presto! Problem solved.
    Except I hadn't noticed during the comedy set myself on fire routine the
    spatter that has now written off the slide bore on one of the carbs.
    Managed to score a replacement set - but they turn out to be from a P7
    and are completely different (Keihan as opposed to Mikuni). They have a
    push pull throttle and carb heaters. A new set of cables are £40 without
    even thinking about the carb heating problems.
    Can I get another set of Mikuni carbs for less than £120? Can I fucking
    arse. GT 750s seem to now be on a par with BSA Goldstars for rarity
    value.
    The Guzzi's 30 year old wiring loom is becoming more random so I'm not so
    keen on doing Slovenia on that.
    Incidentally, why do breakers have the shonkiest websites known to man?
  2. sweller
    antonye Guest
    Do you know what size Mikuni they are? The old Ducati SS and
    Monsters both use 38mm Mikuni CV carbs that may be of some use?
    antonye, May 8, 2008
  3. sweller
    Simon Wilson Guest
    Boring out/sleeving not an option?
    Simon Wilson, May 8, 2008
  4. Um, I have a distinct recollection that your old GT750 is, in fact, a P7
    model. Which means the ones you've been sent aren't.
    The Older Gentleman, May 8, 2008
  5. sweller
    Eddie Guest
    IIRC, it's a P5.
    Eddie, May 8, 2008
  6. sweller
    They cut off all the good buts first.
    Duh.
    _______
    Ace, May 8, 2008
  7. sweller
    I had a long conversation with Alf's Kawasaki about model changes - P7
    is, apparently, post 1991 or 1992 (I've already forgotten). The bike the
    Keihans came off is a 1993 machine.
    As luck would have it I have a guaranteed set of Mikunis off a running
    bike coming from Doncaster £70. Part Finder turns up trumps.
  8. Ah, I stand corrected.
  9. sweller
    Big Dave Guest
    If you need UR on that, I can pick them up and I should be seeing
    Lozzo in the not too distant future...
    Big Dave, May 8, 2008
  10. sweller
    JB Guest
    I've got a set of Mikunis that would be fit (possibly). I'll bet they're the
    same bodies too. BS-series off an XJ900.
    JB
    JB, May 9, 2008
  11. sweller
    frag Guest
    I guess the £40 for the cables isn't looking too bad then.
    And surely the carb heating is just a matter of some T pieces and
    narrower pipe to divert some of the cooland round them?
    frag, May 10, 2008
  12. sweller
    Something like a drain from his catheter so not only does he avoid
    stops but he stops his carbs freezing at the same time? Bargain.
    Andy Bonwick, May 11, 2008
  13. sweller
    To fit carbs I'm not sure are going to work? And I need a twist grip.
    I've managed to pick up a guaranteed set of Mikunis, cheapest so far.
    Should be back in business.
    The carb heaters are electric glow plug arrangements. Diverting coolant
    would be an idea but as the problem is the coolant, cold air, I don't
    think it'd be such a great idea.
    sweller, May 11, 2008
  14. sweller
    I'll look up some numbers and dimensions.
  15. sweller
    On an air-cooled bike?
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, May 11, 2008
  16. sweller
    Catheter? Shirly in leather jeans one simply pisses down the leg
    Hog, May 11, 2008
  17. sweller
    frag Guest
    Ah, I assumed you meant that the cables and heating were all that were
    needed.
    Nice, sorted in the simplest way.
    Ok. I did think that in the future if more problems crop up you would
    then have carbs that had spares more readily available.
    frag, May 11, 2008
  18. sweller
    frag Guest
    You're expecting me to think things through again aren't you?
    frag, May 11, 2008
  19. sweller
    You should have made up a manifold and fitted a big old SU.
    platypus, May 11, 2008
  20. sweller
    Anything will work better than non-existent coolant. I don't think
    Frag knew that the GT750 is air cooled.
