I've got my blinker on - I've got the right of way!
Discussion in 'Australian Motorcycles' started by James Mayfield, Aug 16, 2004.
  1. I think I've found a new thing to be my number one pet hate.
    People who truly, utterly, and completely believe that they have the right
    of way to move into your lane (over the top of you no less) just because
    they have their blinker on.
    Every morning I get some idiot or another doing it (the Woodville Rd, Church
    St, M4, Parra Rd intersection is notorious for it).
    They want to merge left, into my lane. They look (well, there is some saving
    grace). See me there. Put there blinker on. And begin to move over. Then
    when I honk etc, they look at me as if to say "What are you honking me for
    you crazy bastard. Didn't you see my blinker? Clearly I have the right of
    way."
    I've even had a guy pull up next to me at the lights before, and tell me how
    lucky I was he didn't hit me. "You would have had to pay for all the
    damage." he said. "My blinker was on, I had the right of way."
  2. In aus.motorcycles on Mon, 16 Aug 2004 14:01:37 +1000
    Was thinkig about this this morning, watching people do the sydney thing
    of zoom up the inside to the parked car then reef hard right.
    That there is legally no such thing as "right of way", but only duty to
    give way is true but almost unknown.
    You both have a duty to avoid a crash, he also has a duty not to change
    lanes unless its safe to do so.
    Your chances of enforcing this unless you are a Big Truck is minimal,
    such is life in the modern roadsafety environment...
    Zebee
    Zebee Johnstone, Aug 16, 2004
  3. It's not a new thing for me. This has been pissing me off for years.
    Just because they have a blinker flashing they think they have the
    right of way. Anywhere!
    In NZ the rule is that you may change lanes using the indicator and
    only if there is sufficient room (between the traffic in the lane you
    intend moving to) without causing hassle to other drivers.
    Not sure what the Aussie/VIC rules are, but when I'm in the van, with
    the frontal threatening bullbars, I don't give 'em space, but on the
    bike I preserve myself by being alert enough to brake if/when they
    start to cross over into my space.
    Arseholes, the lot of 'em.
    Very few of them will allow bikes space, but the ones who do, I always
    give them a thumbs up thank you.
    Kind regards
    Dave Milligan
    Dave Milligan, Aug 16, 2004
  4. James Mayfield
    Stan Gifford Guest
    In the UK where I learnt the following was drummed into me -
    Mirror, Signal, Manouver
    (And it doesn't mean look into mirror - then signal - it meant look into
    mirror and then if it is safe signal!).
    Stan
    Stan Gifford, Aug 16, 2004
  5. Mirror, Signal, Manouver
    Wouldn't signal be better off going earlier? If you signal _just_ before you
    manouver, you aren't giving people long enough to see it and react before
    you have moved. What if you missed something when you "mirrored"?
  6. James Mayfield
    Dale Porter Guest
    Signal first. Always signal first. *Then* check for safety. If it's not safe, keep the indicator on
    while checking for safety.
    The turn indicators are there to warn people of your intentions to turn or change lanes. As such
    they should be used well before the actual move is made so that other road users are well aware that
    you're going to try and make the move.
    Dale Porter, Aug 16, 2004
  7. James Mayfield
    TB Guest
    You think that's bad? Replace said car with Statesman and trailer. I've
    given up getting/staying angry over these lunatics (albeit after some
    colourful stress relieving language that I'd never use in front of polite
    company).
    All you can do is check your mirrors and haul back/out of their way. To them
    you'll be a *kathump*. To you it'll be a lot worse.
    People should be taught that driving/riding is a privilege, not a right. All
    this crap happens with it's seen as a right.
    TB
    (The guy in the statesman was in no hurry to get out of the way either..
    even after I horned)
    TB, Aug 16, 2004
  8. James Mayfield said....
    And my pet hate are those who ignore your indication to merge and refuse
    to allow you room to move over.
    One's as bad as the other.
    Martin Taylor, Aug 16, 2004
  9. James Mayfield
    Stan Gifford Guest
    Hey don't ask me - better minds than mine came up with this (The british
    equ of the RTA :) ).
    I think it means look in the mirror
    If something coming or not safe sit tight
    else
    turn on indicators
    {Then I reackon there should be another mirror step here...)
    Then manouver
    Stan
  10. James Mayfield
    atec Guest
    Im finding of late kicking the rear vision mirror off doesn't always
    rate consideration by the car driver , almost like they just didn't
    notice.
    atec, Aug 16, 2004
  11. Stan Gifford said....
    So, if a car's where you wish to go, by not indicating, you're stuck in
    that lane. By indicating, you're telling them that you wish to move
    over, and hopefully, they'll be courteous enough to let you in.
  12. James Mayfield
    TB Guest
    They're probably too busy watching the In Car DVD player. Those things can
    get distracting when they get bigger than 300mm..
    TB
    TB, Aug 16, 2004
  13. Surely the vehicle moving over the dotted lines (and therefore
    changing lanes or merging from a closed lane) must give way!
    Therefore it's a matter of waiting for a gap.
    NOT a matter of creating a gap!! or just barging in because they've
    got the indicator on.
    That's my interpretation of this discussion.
    Kind regards
    Dave Milligan
  14. James Mayfield
    Stan Gifford Guest
    courteous< But I am in Sydney.
    I think it's swings and roundabouts. WHilst it ain't perfect, someone
    occupying the same space as you is even less perfect.
    Stan
  15. James Mayfield
    Huh? Have you found the override code for your V-chip?
    Clem
    Knobdoodle, Aug 16, 2004
  16. James Mayfield
    atec Guest
    I have seen that , and truthfully the glazed eyes were a worry.
    atec, Aug 16, 2004
  17. James Mayfield
    rodent Guest
    First of all Dave, i've rode for 23 years and still ride...
    Tomorrow when i'm driving my truck and i see a bike or two riding the white
    line or the emergency lane with no indicators on, i'll try to remember your
    comments......
    "NOT a matter of creating a gap!! or just barging in because they've got the
    indicator on."......
    And i'll close that gap a bit, just to suit your way of thinking :)
    Try waiting for a gap in a truck pissant.....you get bored after 2kms
    cheers
    roddent
    rodent, Aug 16, 2004
  18. James Mayfield
    TB Guest
    Working on it...
    TB
    just call me a "hacker"
    TB, Aug 16, 2004
  19. Dave Milligan said....
    You're correct. I was talking about courtesy and if someone indicates,
    to allow them to merge or move over, if it's safe to do so.
  20. James Mayfield
    SmeeR1100s Guest
    SSSSSSSSoooooooooooooooooooo easy to manoevre around a truck then blast
    past.
    u block up one side then all we do is fly past from the other before u
    have time to scratch.
    I don't think you have ridden for 23 years if you think the way you do.
    SmeeR1100s, Aug 16, 2004
