Jet wash
Discussion in 'UK Motorcycles' started by David Mahon, Nov 21, 2005.
  1. David Mahon
    David Mahon Guest
    Jet washes - good or bad?
    Despite all my intentions of only riding in the dry, even at 1pm today
    with wonderful Sunshine, it's still so cold that the frost has turned to
    damp patches, which remain in shady areas. And as the bike is new, I
    can't help but take it out when I've got some time off. Fortunately I
    haven't seen the gritters out my way, yet.
    So, I've heard bad things about jet washers - that they strip the paint
    from your wheels and cause untold amounts of damage (despite never
    seeing any similar damage to our old 4x4). But then I've also seen them
    used in bike mags (along with steam cleaners) without trouble.
    So - use 'em or leave 'em alone? And are the home type pressure washers
    any better (Halfords / Karcher / etc) and if so, which is worth buying?
    As an aside, are those products like FS365 anti-corrosion spray any more
    useful than snake-oil?
  2. David Mahon
    fotoman Guest
    FS365 is superb and does what it says on the tin.
    fotoman, Nov 21, 2005
  3. David Mahon
    muddy Guest
    Keep it away from the radiator though.
    muddy, Nov 21, 2005
  4. David Mahon
    Wik Guest
    Lucky you; I've seen gritters out already in Herts, Beds and Suffolk.
    The key thing is to avoid blasting the electrics and anywhere there's a
    bearing involved; wheels, swinging-arm, head-race, etc. That said, I've
    seen dealers using them with almost no regard for this.
    Some of the best advice I've had on the anti-corrosion thing is to sling
    a bucket of *cold* water over the bike as soon as you get home.
    Your call, bearing in mind the above.
    No idea which is the best but Karcher are almost a household name.
    FS365 is good stuff as you'd expect given the manufacturer. Can't
    comment on any others 'cause I ain't used 'em.
    Wik, Nov 21, 2005
  5. David Mahon
    MikeH Guest
    BTDT and been pinned under the bike on the sheet of ice the morning after.
    MikeH, Nov 21, 2005
  6. David Mahon
    Eddie Guest
    1. Hose down bike on drive (using "shower" nozzle, rather than "jet");
    2. Put bike in garage;
    3. Put salt/grit on drive.
    Eddie, Nov 21, 2005
  7. David Mahon
    MikeH Guest
    Yeah, yeah, we can all be clever with hindsight :)
    It actually occurred to me what I had done just the bike went down, but
    I wasn't quick enough with the salt.
    MikeH, Nov 21, 2005
  8. David Mahon
    Exactly what the fotofella says: I sprayed Elly's CBR6 with FS365 two
    or three times a week as she used it right through winter and there
    was no visible corrosion afterwards, despite only having cleaned it
    properly twice over that time. It rocks, and thanks to dwb for
    suggesting it in the first place - and to Scottoil for supplying a
    litre of it FOC at the BMF with a Scottoiler as a marketing ploy: it
    certainly worked.
    Pip, Nov 21, 2005
  9. David Mahon
    Dan White Guest
    I got the 5 litre refill container, and the front and underside of my car
    gets a treatment every week too.
    Dan White, Nov 21, 2005
  10. David Mahon
    And Bucks and Berks last night. Just as well really, temp gauge in the
    car reckoned -3 this morning when I went to work.
    ogden, Nov 21, 2005
  11. David Mahon
    Mine had -3 last night on leaving SO's in Bracknell. By the time I got
    home (Harrow, approx 30 miles) it was +4!
    CT, Nov 21, 2005
  12. David Mahon
    Snowleopard Guest
    car reckoned -3 this morning when I went to work.[/QUOTE]
    Glos - managed -5.5 on the way to work this morning.
    Snowleopard, Nov 21, 2005
  13. David Mahon
    Ben Blaney Guest
    Still 20C outside. I've switched the AC to "heat" rather than "cool"
    to maintain 22C inside.
    Ben Blaney, Nov 21, 2005
  14. David Mahon
    ogden said...
    -2 on the way towards the A1M this morning.
    Lozzo, Nov 21, 2005
  15. David Mahon
    Gyp Guest
    I told you it was a bastard to clean, didn't I?
    Oh and yes, <bear mode> FS365 rocks </bear mode>.
    Not wishing to keep going on about it, the Kawasaki's not built anywhere
    near as well as the Beemer or the Harley. Taking the Zed out on salted
    roads I'd want to absolutely fucking drench it in FS365 a couple of
    times (and leave it for the water to evaporate) before going anywhere.
    Gyp BOTAFOT#99, BotToS#4, UKRMT5BB, DIAABTCOD#28, HYPO#4
    '81 R65RS - SORN but not forgotten
    '89 R80RT - intercontinental ballistic tourer
    '97 XLH1200 - weapon of muff disruption
    '04 Z750 - oh look, something from this millennium
    Take out the chemical loo to reply
    Gyp, Nov 21, 2005
  16. David Mahon
    ginge Guest
    22 is too warm for me. 18-19 is ideal.
    ginge, Nov 21, 2005
  17. David Mahon
    ginge Guest
    Glos - managed -5.5 on the way to work this morning.[/QUOTE]
    Beats me. only -3C, but, with only 20 yards visibility at about 10AM
    this morning. Made driving "fun"
    ginge, Nov 21, 2005
  18. David Mahon
    Eatmorepies Guest
    I use a 30 quid B&Q one - now. I have an expensive high flow rate one that I
    used on enduro bikes but I bought the cheapy one to clean bicycles.
    It (the cheapy one) doesn't have the power to penetrate seals but it does do
    the business on surfaces. I spray the bike with a bit of Mucoff and then
    wash it with the cheapy pressure washer. Any surfaces that need a bit more
    attention get a bit more Mucoff and a brush with a paint brush - then, more
    of a go with the pressure washer, dry the bike and put it away.
    John
    Eatmorepies, Nov 21, 2005
