Jinx
Discussion in 'UK Motorcycles' started by Eddie, Jan 25, 2006.
  1. Eddie
    Eddie Guest
    As I was riding out of "The Commune" this morning, I was congratulating
    myself on the excellent job I'd done of bleeding the brakes, pondering
    that the 9R's gear linkage hadn't done the usual winter trick of seizing
    up with crud, and thinking that I should do some preventative
    maintenance before it happened.
    Get on to the main road, let's click it up into third... oh... arse...
    wiggle gear lever down slightly, click it up, *that's* third... now for
    fourth... ah, yes, I can see a pattern here, wiggle lever down slightly,
    up, and click. And so the journey to work continued, with all gear
    changes being planned well in advance.
    Ho hum, looks like I'll be doing some belated gear linkage maintenance
    tonight.
    Remind me not to think that it's a long time since I snapped a chain...
    Eddie, Jan 25, 2006
  2. Eddie
    Spete Guest
    A quick google didn't bring anything up, so I think your time is due...
    Spete, Jan 25, 2006
  3. Eddie
    Eddie Guest
    LA LA LA LA LA, I CAN'T HEAR YOU!
    Eddie, Jan 25, 2006
  4. Eddie
    It'll be the pivot point at the footrest. A quick polish with
    scotchbrite then some copperslip and the job's done.
    Andy Bonwick, Jan 25, 2006
  5. Eddie
    Eddie Guest
    Yeah, I know.
    Something like that, anyway. Took longer to get apart than I expected,
    as someone had used half a tube of red Loctite on the footrest bolt, and
    I couldn't be arsed to find the blowtorch.
    Dead posh, it is, that pivot. Got a rubber seal on either end of it.
    Quite surprised, I was. God Bless Kawasaki Heavy Industries.
    I also noticed that the C-clip that holds the footrest pivot in place
    was about to make a bid for freedom; that could have been interesting.
    Eddie, Jan 26, 2006
Similar Threads
Loading...
