Job Done
Discussion in 'UK Motorcycles' started by curium, Jan 24, 2004.
  1. curium
    curium Guest
    I have purchased one shiny new SV650S in blue complete with Datatool system
    3 and scottoiler for £4300 all in. Collect next saturday.
    I took their demo bike for a ride up the uxbridge road and my thoughts were;
    - very smooth fuel injection from stop.
    - 1st gear goes on for a lot longer then CB500, had to remind myself to
    shift up. can see myself spending a lot of time in 1st in town as it does
    the job.
    - VERY different sound makes it hard to hear if i'm in the wrong gear.
    - very smooth accelaration from stop, unlike the CB.
    - no 'rush' when you get to a certain rpm, just a steady pull. this makes it
    slightly less 'exciting' but more predictable.
    - it didn't feel as 'chuckable' as the CB, maybe i just need to gain
    confidence with it.
    - back stepped out slightly on a down shift, guess i need to match up my
    revs better.
    - felt like more power then i would need as it never felt on the limit
    - comes with dunlop (i forget the exact model)
    - gear box felt nice, although i only got upto 3rd.
    - not much room under the rear seat.
    - exhuast looks like it will need lopping off if i want a new can. could be
    a problem come MOT time :(
    - rear mudguard/number plate hanger is hideous and needs lopping off.
    The salemen recommended Suzukis specialised insurance, so i shall ring then
    and see if they can beat bennetts. I now need to purchase a "**** off and
    die thief ****" lock
    I expect you'll all want to place bets on how long before i lob it down the
    road :)
  2. curium
    Oldbloke Guest
    <SNIP>
    Nice one, now DFC. :)
    Oldbloke
    My Bike - 2000 Honda CB500
    M'boy's Bike - 1990 Suzuki TS50X
    i Bike - MotoRumi Junior Gentleman
    BOTAFOT #140, DIAABTCOD#26
    "He's like Robbo's chubby kid brother"
    Oldbloke, Jan 24, 2004
  3. curium
    muddycat Guest
    Conga rats. I replaced the rear fender with a Competition Werks kit.
    Much nicer.
    muddy
    Testing the limits of gravity since 1947.
    icq - 219328929
    muddycat, Jan 24, 2004
  4. curium
    dwb Guest
    You what? You LISTEN for your gear changes????
    My SV had a rush - from about 7000RPM - would be surprised if the FI model
    doesn't have some sort of sweet spot...
    Yes, you really do.
    Yes, you really do.
    Only one?
    Do you read the replies you get to your posts? I stated that was the case.
    Most manufacturers supply a sleeve into which you can stick your
    standard exhaust and two jubilee clips to tighten it all up - Immediately
    transforms it to standard. 10 minute job at most.
    **** no - you're going to blow it up long before that.
    I really must stop replying to your posts... I'm starting to appear
    obsessive...
    dwb, Jan 24, 2004
  5. curium
    SteveH Guest
    Doesn't everyone?
    SteveH, Jan 24, 2004
  6. curium
    dwb Guest
    Not at the bottom of the rev range absolutely not - I see if the bikes got
    any bloody power!
    Ear plugs - quiet helmet...
    dwb, Jan 24, 2004
  7. curium wrote
    Why buy the slow one?
    Ah, I see why now.
    38 days.
    steve auvache, Jan 24, 2004
  8. curium
    David Thomas Guest
    Hold up, I am missing something here.. when i bought my used bandit it came
    with a carbon can with pipe and the original, both connect at the collector
    box, when I change between them it is a sod and fucks the collector box
    gasket.
    Sound like your saying some exhaust connect at the can? interesting!
    scuse bad grammer... semi-pissed
    D
    David Thomas, Jan 24, 2004
  9. curium
    Ginge Guest
    Scorpion can.
    I don't see the problem myself. :eek:)
    Ginge, Jan 24, 2004
  10. I'd rather not tempt fate.
    Can I recommend one other essential purchase - *please* go and get some
    further training. Your riding history to date is not what you'd call
    marvellous. It would not be good news for you or your insurance record
    if you do anything serious to yourself or your new bike.
    Paul Corfield, Jan 24, 2004
  11. curium
    Ginge Guest
    Get some *good* crash bungs.
    Ginge, Jan 24, 2004
  12. curium
    David Thomas Guest
    Should start my further training at the end of Feb, "silk purse out of a
    sows ear" springs to mind.
    D
  13. curium
    Nice one!
    Get yourself down to your local master locksmith and save a bundle on
    branded M/C stuff.
    I was recommended (by 2 off) the Viro 4230 chain lock like this
    www.bikerchain.co.uk/bikerspec.htm#4230 and 1.5 metres of 10mm hardened
    chain. The lock is a combination of steel hardened right through and brass
    and it deforms under impact. I was told this design makes it resistant to
    single stage attack by cutting\grinding\freezing etc.
    As for chain, 8 to 10mm seriously hardened is all it's worth doing. Only
    high end hydraulic croppers will go through it and a decent grinder/diamond
    blade will have 2mm or 20mm. Anything bigger is a bitch to carry anyway.
    Again the locksmith can supply.
    If I'm worried I use this combination to immobilise and secure the bike to
    street furniture through the rear wheel/swinging arm and an Abus Granite
    type U shackle through the front wheel/disks around the front forks.
    Is now the time to fit a cheapo can and a set of ARD colour impreg pattern
    bodywork?
    Hog, Jan 24, 2004
  14. curium
    Ben Guest
    Same here. Except the Thou is confusing me because at 4k rpm it
    sounds like the 750 at 8k. Just as well it's got so much torque.
    And quote of the day today from a ZX636R rider stopped at the traffic
    lights in Henley:
    "**** me, that thing is quick"
    I was pottering :)
    Ben, Jan 24, 2004
  15. Nice one.
    Four months ;-))
    The Older Gentleman, Jan 24, 2004
  16. curium
    dwb said...
    I change up whenever I fucking feel like it. You just *know* when's the
    right time.
    Lozzo, Jan 25, 2004
  17. curium
    muddycat Guest
    And there's the rev limiter for the times you forget.
    muddy
    icq - 219328929
    muddycat, Jan 25, 2004
  18. curium
    deadmail Guest
    I'd agree with that and tbh I'm not particularly conscious of changing
    up, why I do it or when I do it.
    deadmail, Jan 25, 2004
  19. curium
    I do it, usually, because the valves have started bouncing.
    sweller, Jan 25, 2004
  20. curium
    SteveH Guest
    I think he might be referring to his Guzzi.
    SteveH, Jan 25, 2004
