JP: Rear wheel drive volvo's...
Discussion in 'UK Motorcycles' started by Owen, Jan 28, 2004.
  1. Owen
    Owen Guest
    Interesting handling in the snow sir... :)
    PS: haven't forgotten about the radio...
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, Jan 28, 2004
  2. Champ wrote
    What you on about? All mine were RWD.
    I'd stick to knowing about bikes if I were you.
    steve auvache, Jan 28, 2004
  3. They last a long time.
    Plenty of 740s, 760s, 940s, 960s still around.
    Not to mention the T5, pretty fast for a bus.
    Old Fart at Play, Jan 28, 2004
  4. Owen
    Dan405 Guest
    T5 is FWD :) The older ones (before they made the quick stuff like the T5)
    were mostly RWD. The 360 2.0 has the be the best one :)
    Dan405, Jan 28, 2004
  5. Owen
    Old Fart at Play said...
    And the old 340 series, which is what Owen has.
    Lozzo, Jan 28, 2004
  6. Owen
    Dan405 said...
    Overpowered for the handling and brakes, by a long long way.
    Lozzo, Jan 28, 2004
  7. Owen
    Dan405 Guest
    Which makes it the most dangerously fun :)
  8. Owen
    Dan405 said...
    I very nearly flung a brand new 360GLT across a Cambridgeshire field
    many years ago when I was picking it up to have an alarm installed. I
    ran out of brakes, so turned the car into the corner at way too fast a
    speed. It went all sideways on me and mounted the verge, wriggled lots
    and eventually straightened enough for me to force it back on to the
    road, just in time for the second part of the S bend.
    I had to go back to our workshop via a jet-wash.
    Lozzo, Jan 28, 2004
  9. Owen
    OH- Guest
    Many people used to put some 20 to 60 kilos of ballast in the
    trunk to gain a bit of traction. The only trouble is that once you
    loose it in a corner the extra weight in the rear makes it even
    more interesting.
    OTOH it works both ways this FWD / RWD thing. At first I
    felt that FWD was a bastard in snow and loose gravel as I was
    used to influence turn rate in tight corners with the throttle.
    OH-, Jan 28, 2004
  10. Then it's a good job that I didn't mention it. :)
    I must have been thinking of the 960 turbot.
  11. Owen
    Champ said...
    Fully laden Transit, that's what you want
    Lozzo, Jan 28, 2004
  12. Owen
    atec77 Guest
    http://cust.idl.com.au/athol/default.html
    the volvo Athol has built would indicate otherwise .
    atec77, Jan 28, 2004
  13. Champ wrote
    Snowmobile.
  14. Lozzo wrote
    Snowflake with a dislodged plug cap.
  15. Owen
    Lozzo, Jan 28, 2004
  16. Owen
    Salad Dodger Guest
    Blackbird.
    Well, not so much "fun", but it definitely maintains your attention.
    Salad Dodger, Jan 28, 2004
  17. R80RT. Yes, it whited out about 10 minutes before I was due to leave the
    office.
    pseudoplatypus, Jan 29, 2004
  18. Owen
    Pete M Guest
    In
    Heh, I used to take the spare wheel out and run on the least amount of fuel
    possible... Beeeeg time sideways....
    Pete M
    Alfa 164 TS,
    Mercedes 500 SEL,
    Scouse Git extraordinaire.
    Liverpool, Great Britain
    Pete M, Jan 29, 2004
  19. Owen
    atec77 Guest
    so what's your point ?. its a volvo , t goes very well and outpaces
    most anything locally or may I suggest at your end , remove the broom
    from your nether regions thanks.
    atec77, Jan 29, 2004
  20. Owen
    I'd suggest in reply that you got a fucking clue about anything before
    posting. The 340 is nothing like the 240 series. It's like comparing a
    Honda C90 with a Honda Blackbird. Anyone can shove a fucking great V8 GM
    motor in a big car and outrun sports cars in a straight line. As
    standard the 360 handles like shit and runs out of brakes.
    If you are going to persist in posting here, then try also getting a
    clue about how to do it properly, there's a link in my .sig to the
    ukrmcbt. Read, digest and act upon it please.
    Lozzo, Jan 29, 2004
