Just can't get the staff.
Discussion in 'UK Motorcycles' started by Muck, Jun 14, 2007.
  1. Muck
    Oh boy..
    My gearbox layshaft came back the other day, from the 'expert'. The
    people that had pressed the old cog onto the new shaft used copperslip
    to help get it on there. Also, they marked the outside edge of some of
    the gear teeth, meaning that there are burs on some of the teeth that
    need to be taken off.
    I mean.. ffs. Copperslip. I thought you had to use anaerobic adhesive
    and not a bloody lubricant, plus damage to the teeth.. some expert.
    Needless to say, if nasty things happen when the thing is together and
    running, I shall be taking it back.
    Muck
    Muck, Jun 14, 2007
  2. Muck
    Yeh, I know.. I can get a good 2nd hand gear cluster for £40, so if it
    comes to that... I'll do it. Right now though, I don't really care that
    much, as my gearbox could outlast me. Depends on the biopsy result
    though.
    Muck, Jun 14, 2007
  3. Muck
    Buzby Guest
    Muck wibbled:
    Been there, done that and don't like it. I'm crap with rebuilding gears
    and only marginally better at being ill. Hope it swings your way.
    Buzby, Jun 14, 2007
  4. Muck
    Cheers geeza, maybe I'll suddenly get all the luck that's passed me by
    recently. Anyway, the chap putting the gearbox together is going to
    debur the gears, it's only on a very small part of the teeth and easily
    removed with skilled fingers like his.
    I watched him modify a spacer on the suspension, and was amazed at his
    skill with a hacksaw and grinding wheel. No way could I have cut that
    spacer so perfectly with a hacksaw. The solid bush kit slipped in just
    right. :) Should get rid of that hinge in the middle feeling mid corner.
    Muck, Jun 14, 2007
  5. Muck
    TOG Guest
    If you know a useful geezer like that, would you mind posting his
    contact details?
    TOG, Jun 15, 2007
  6. Muck
    I've not got anything but good words to say about him over the years
    I've been going there[1]. The shop he owns has a 4 or 5 week waiting
    list[2] for the workshop, that shop is Bikes of Brighton, his name is
    Paddy. The number is 01273607635 .
    [1] Since I was 18 and had my DT50MX
    [2] I think.. you'll have to ask him about that.
    Muck, Jun 15, 2007
