Just out of interest like
Discussion in 'UK Motorcycles' started by steve auvache, Aug 26, 2005.
  1. How easy is it to hot wire a bike?
    Is it one wire? 2? Are they the same for all makes and models of bike?
    With half a clue how long would it take to test each likely wire in turn
    until it was right?
    The answers to these and a myriad other similar questions elude me.
  2. steve auvache
    Eiron Guest
    Honda Express moped - paperclip in the connector block to the ignition
    switch.
    LC250 - tap the plastic lock barrel - it falls off, thus enabling the
    ignition.
    Haven't tried any others.
    Eiron, Aug 26, 2005
  3. In uk.rec.motorcycles, Eiron amazed us all with this pearl of wisdom:
    TS50X and DT125LC, pull the connector block apart that runs from the
    ignition switch, kick, rev, ride off.
    AOL.
    Whinging Courier, Aug 26, 2005
  4. steve auvache
    Steph Guest
    I used to start my old GS550 by putting a piece of chewing gum wrapper
    under the top 2 fuses in the box (some scrote had screwdrivered the lock
    in the past, and if I used the keys they'd bounce out half way down the
    road).
    With practice it took me less than 30 seconds to remove the side panel,
    insert the paper, replace the panel and push the start button.
    Shame I can't remember who taught me how to do it...
    Steph, Aug 26, 2005
  5. steve auvache
    antonye Guest
    Bridge two female connectors in the ignition connector
    on mine. I did it with a pair of pliers to check when
    I lost the key. It now works off a toggle switch in
    true race fashion.
    Some may not be this easy. I understand (from Champ)
    that the ZXR expects lower than 12v across two terminals
    and so it needs to have a resistor in there to work,
    but then all you need to know is which value resistor
    and it's just as easy.
    Encoded ECUs seem to be the way - they take a number
    given from the key and if it doesn't match the bike
    doesn't start. As it's built into the ECU there isn't
    much you can do to bypass it.
    antonye, Aug 26, 2005
  6. steve auvache
    Eatmorepies Guest
    Suzuki SB 200. Pull the black and white wire off the electronic ignition
    box. It earths the unit unless the ignition key is switched. I learned this
    because Janet lost her key when she followed my to the Dyfi Enduro instead
    of coming with me in the car.
    John
    Eatmorepies, Aug 26, 2005
  7. steve auvache
    Tosspot Guest
    Till you lose the f'ing key.
    Tosspot, Aug 27, 2005
  8. steve auvache
    When I raced bangers, predominantly 70's Triumphs, Fords and assorted BL
    (I realise they're not bikes) I didn't bother hotwiring as such as I
    could get the steering lock off and access the ignition switch (sans
    lock) in a minute without breaking stuff.
    To my surprise I found exactly the same approach worked on an S reg
    Kawasaki ZX750. It took a little longer but this is without breaking
    things and gets round the problem of the voltage checking resistor.
    sweller, Aug 29, 2005
