Just so I don't...
Discussion in 'UK Motorcycles' started by Beav, Jul 30, 2010.
  1. Beav
    Beav Guest
    Spend **** knows how long looking in the wrong place...
    My brother asked me to collect and fix his bike (Bandit 1200 with the half
    fairing thing)
    Apparently this thing smokes and when I asked him to describe the smoke
    (blue, black, white) he said it's blue and worse when he first starts it,
    but it eases off although it doesn't clear completely. I'm not sure I
    believe him when he says "Blue" coz he'll answer a question just so he
    doesn't look like a **** by saying "I dunno, I never gave it a thought"
    which is more likely to be the case as he's not exactly mechanically
    inclined and wouldn't think the colour of the smoke was important.
    He also says it runs rough but gets better as it warms up. So... I'm
    thinking the first line of attack is the carbs (clean, check float heights
    and balance) followed by valve stem oil seals if the carbs prove not to be
    the problem. If it's not the valve stems oils seals, then it's going to be
    the rings/bores which I really don't want to get into replacing but if needs
    must and all that and I'll alread have the head off anyway.
    Having never owned a Bandit, but plenty of shite stuff that smokes like
    fucker when running rich, I'm wondering if this is a trait of the Bandit
    (running rich and smoking).
    This bike doesn't have a crankcase breather either, but it *did* have a
    modified oil filler cap with a tube running up to the air box region where a
    bottle collected any outpouring of oil which could then dribble back into
    the bottom of the motor when it wasn't running. Cap now lost, but as it's
    not standard anyway I really don't want to put another one like it back on.
    I'd prefer to run a normal crankcase breather and will when I know where the
    original would've been situated.
    Idea's from the FONT?
    Beav, Jul 30, 2010
  2. Beav
    @hurricane:
    give it a full service, removing any "improvements" as you go
    wessie, Jul 30, 2010
  3. Beav
    crn Guest
    My first move would be to whip out the plugs, check colour, and do a
    compression test. Serious shit like rings/bores will show up as a
    black plug and low compression. Having eliminated the most expensive
    options it then comes down to mixture or valve guides as you say.
    If the smoke really is blue it means oil is being burnt.
    A set of stem seals often makes a big difference - but you know all that.
    crn, Jul 30, 2010
  4. Beav
    SIRPip Guest
    What year is it? This may seem like a strange question, but there was
    a fundamental change with the 'K' bikes (before the current
    water-cooled engine) that gave rise to much smokiness with some of them.
    I'd agree entirely with your thoughts: you'll have to eliminate
    carburation problems first and it's the easiest starter offer, too. It
    may, rather bizarrely, be worth dropping the exhaust off and checking
    which pot(s) it is that's smoking: if he's habitually warmed it up on
    the sidestand the leftmost is always favourite for a bit of borewash,
    it seems, the rightmost for a bit of oil starvation, conversely.
    All Bandits IME are set rich out of the factory. If the bike is on
    standard can and filter it will run rich at small to medium throttle
    openings, only getting anywhere near stochiometric at full chat. A bit
    of black chuff now and again is fairly normal, but blue isn't, as you
    know. White is right out of the question, unless the geezer's a senior
    Cardinal - in which case he's also entitled to wear horns on his helmet.
    The standard breather on all models runs to a spigot moulded into the
    front centre top of the airbox. If that spigot hasn't been sealed once
    the breather was disconnected then there's a fine source of rough
    running. I think catch tank things like this, or worse, the nasty
    little chromey filter-onna-hose jobbies are to be reviled and the users
    of same to be mocked. Unless fitted to a race bike where cleanliness
    of the air charge entering the air box is vital for mixture management,
    of course - or if the bike has been properly modded and there isn't an
    airbox any more; that's a good case for such contraptions.
    Yeah, watch the apostrophes, fatty.
    SIRPip, Jul 30, 2010
  5. Beav
    Beav Guest
    It's a 2002 air/oil cooled.
    Yeah, they're going to get a cleaning anyway coz brother's a fucking animal
    when it ocmes to looking after his stuff. I bet the air cleaner has never
    seen the light of day either.
    Good thinking. Exhaust header will be removed and hopefully all the fucking
    studs will remain as studs and not as two-piece lumps of corroded shite.
    Nope, some after market oval shaped chromey thing. No name that I can see.
    Obviously not fitted by brother.
    He swears it's not white and until the battery has a decent charge (it's on
    charge as I type) I won't know for sure.
    But where does it run *from*?
    I'll be checking the airbox for open spigotry then :)
    I had a could of spares and couldn't find a use for them, so I lobbed one
    out and it found its way here:)
    Beav, Jul 30, 2010
  6. Beav
    Beav Guest
    Sensible approach. It will be done.
    Beav, Jul 30, 2010
  7. Beav
    Beav Guest
    Yeah, I just don't really want to get into removing the head and pistons,
    but I will if I have no alternative. I was always under the impression that
    Bandit motors were pretty bullet proof and this bike hasn't got astronomical
    mileage on it. so worn rings and/or stem seals isn't what I signed up for
    Ah well. I'll start the work tomorrow when brother brings me his workshop
    manual For a change it's something that'll be brand new anyway.
    Beav, Jul 30, 2010
  8. Beav
    SIRPip Guest
    Ah. From memory, it was questionable pistons and their fit in the
    bores. Reports of smoking were widespread in 2001/2002 and gave rise
    to the infamous response from SuzukiGB: "Consumption of a litre of
    engine oil over a distance of 1000 miles can be considered normal". Or
    something like that.
    Anyway, there's a link here to a rather wordy but interesting example
    of a Bandit with a smoking problem:
    http://www.sukbog.co.uk/gallery/misc/lenny/lenny.html
    The cast rectangular 'box' that sits in the centre of and on top of the
    cam cover. There's a spigot running out of the left side about halfway
    along it. The standard breather hose runs straight from that, through
    a 90 degree turn rearward, between carbs 2&3 and straight into the
    airbox. Total hose length no more than ten inches.
    That's cool, man, I can do shiny. No airbox, you gotta do something
    with the condensed fume. I've got some canisters full of charcoal in
    the back of shed#2 off an American-spec bike that we lightened the
    fairing of, if you'd like 'em ;)
  9. Beav
    SIRPip Guest
    My Bandit had less than 18,000 on it when the engine finally gave up.
    I think that in their original GSXR incarnation they were pretty sound
    (for their day and the power they put out) but as soon as people start
    dicking around with them it puts undesigned-for stress into them and
    they start to fail.
    I've got a standard motor in mine now and it does all I need it to: if
    I really want a chunk more grunt I'll drop a tooth off a sprocket
    first, and failing that I'll stick some Gixer cams and carbs on it.
    **** dicking around with ignition advancers and jetting kits and
    individual air filters. Or buy a more powerful bike.
    It isn't just the motors, though - I'm going to swap my original
    gearbox from the blown motor into this one, as the current 'box is
    getting severely rattly. The RF900 garden ornament has a dodgy 'box
    too - won't stay in second - although that could be a worn selector
    which the Gixers were prone to. I've got a complete engine to go in
    that, too ... next time Loz wants to borrow my trailer ;-)
    Ah, the old "Can you just ... " family/mates approach. Oh, how I love
    to hear those words.
  10. If you want a set of stem seals, let me know. I am pretty sure I have
    a new set left over from a top end gasket set I bought a couple of
    years ago.
    Speedgazebo MOTP #1, Jul 30, 2010
  11. Beav
    Beav Guest
    Much appreciated Sir and I'll be contacting you for sure. Well if they need
    replacing, that is.
    Cheers
    Beav, Jul 31, 2010
  12. Beav
    Beav Guest
    Well more investigation turned up what I think (hope) is the cause of the
    smokiness. Remember, this isn't a high mileage bike (18650) and it's only
    been smoking its tits off for a short while, so I doubt it's one of those
    Bandit motors that smoked after the initial running in period and it's
    simply a case of shite maintenance.
    I removed the seat, tank and front fairing and went straight for the easy
    bits first. Air filter and plugs. I have to say I've never in my life seen
    an air filter as clogged as this one. I suspect it's never been changed
    since the bike was bought. Next the plugs. Black as the hobs of hell, all 4
    of 'em, so...
    Rang brother and told him to get a new air filter and a set of plugs and
    before I go any further, they'll be fitted and the bike fired up. I'm of a
    mind that the smoking won't be an issue when the fucking engine can breathe
    fresh air instead of neat fuel.
    This is (apparently) standard apart from the can which is a "Viper" as I
    discovered when I got some of the crap off it, so if that's the extent of
    the modifying, the worst I can expect is a lean runner, not a rich runner,
    but as it's not a mega expensive can, I can't see a re-jet being needed. I
    fucking hop not anyway, or I'll be looking for a standard can on th' owd
    eBay.
    When I last rode this particular Bandit, the 'box was really smooth and
    anyway, it's not mine so I don't really give a **** :)
    Not just friends and family either. We get it every day from our trade
    customers, along with that other gem: "While you've got paint in the gun,
    can you?" as if the fucking paint costs us **** all.
    Beav, Aug 2, 2010
  13. Beav
    SIRPip Guest
    That'll certainly help. Dare I ask how long it's been since the oil
    was changed?
    It won't need jetting. Plug chop it if you want to be sure, but I have
    no doubt it'll be fine. However, should you find a need for a standard
    can I can certainly lay my hands on a suitable example.
    SIRPip, Aug 2, 2010
  14. Beav
    Beav Guest
    You dare and for once, not that long ago. It's still oil coloured as opposed
    to black and stinky.
    That snippet of info is stored and I thank ewe. Now all I've got to do is
    wait for lazy fucker brother to get the bits.
    Cheers
    Beav, Aug 3, 2010
