K100 shaft wear ?
Discussion in 'Australian Motorcycles' started by melchizedek, Jul 30, 2006.
  1. melchizedek
    melchizedek Guest
    Is there any easy way to check big mileage K100 BMs' for wear in the
    drive shaft? Is putting it in gear ( engine stopped of course) and
    rocking the bike back and fwd. a good indication ?
    Melchizedek.
  2. melchizedek
    sanbar Guest
    Turning the rear wheel by hand while the 'box is in neutral will tell
    you a lot. It's not so much shaft wear as in the uni joints tightening
    up once the needle bearings start to go. Any stiffness indicates worn unis.
    The shaft-drive driveline is usually pretty direct, and what you do at
    the throttle is almost immediately reflected at the back wheel.
    The shaft drive is the least of your worries, tho.
    - sanbar
    sanbar, Jul 30, 2006
  3. Not really, the only way to be sure of the condition of the splines is to
    remove the rear drive and look at them. There is always some play if you
    rock them back and forward.
    By Big miles, you mean how many?
    Al
    Alan Pennykid, Jul 30, 2006
  4. over 100,000 K.
    M.
    isaac_the_blind, Jul 30, 2006
  5. 100,000 is nothing on a properly maintained K100. Many do 300,000km without
    major repairs of any sort. At 100,000kms though the splines on the shaft
    could be worn, UJs aren't much of an issue on K's unlike paralever
    R80/100GS's. I've changed around 4 shafts due to spline/pinion wear over 4
    different bikes(mine/my wifes), lubrication seems to help, but if you've got
    a bike that chews splines cause of some misalignment(bent swingarm or
    something not fitted right), it will chew splines.
    The last K series I bought had 140,000kms on it, I bought it after a brief
    testride only, sold it 50,000km later fitted with a sidecar still running
    beautifully.
    Al
    Alan Pennykid, Jul 31, 2006
  6. melchizedek
    Sprint Guest
    Can you have the oil analized for comtaminants, metal?
    I've never owned a shaftie, just putting up a suggestion ... might be too
    costly to do as an exersise?
    Sprint :)
    Sprint, Aug 3, 2006
