K100RS - Tall Bike ?
Discussion in 'UK Motorcycles' started by Brownz @ Work, Jan 14, 2008.
  1. Brownz @ Work
    Didn't I just say they WERE better than a SOBoxer in these situations?
    Hog, Jan 15, 2008
  2. Brownz @ Work
    All you need to set up an old K100 is a set of vacuum gauges and a CO2
    meter.
    Hog, Jan 15, 2008
  3. Brownz @ Work
    Oh I beg your ever so pudding.
    Only Bear couldn't manage something so simple at home.
    Hog, Jan 15, 2008
  4. Looked at it tonight, honest bloke - honest bike.
    He's looked after it and serviced it regulary.
    A little worn in a couple of places, but starts on the button and sounds
    sweet with no smoke.
    Zorst has a wee hole where the guard was refitted a little over zealously,
    no rust though.
    Still on tip toes, so I think someone mentioned a hagon shock that'll lower
    it - must hunt around for one of those !
    Being an '89 F-Reg that makes it an 8V / 987cc right ?
    Brownz \(Mobile\), Jan 15, 2008
  5. Brownz @ Work
    Sounds good. They all whine, it's the layshaft off the crank to the
    gearbox.
    They all do that sir
    It';s a special order from Hagon
    It is indeed and a sweet lump.
    Hog, Jan 15, 2008
  6. Brownz @ Work
    deadmail Guest
    Well the 8V is more robust than the 16v and also easier to service. 70k
    is nothing on the engine, I've taken one to about 130k and then gave up
    on it because of cycle parts. However... I'd also agree that 900squid
    is probably as far as I'd want to go if I were in the market for an RS.
    deadmail, Jan 15, 2008
  7. Brownz @ Work
    Molly Guest
    Molly, Jan 16, 2008
  8. Nice one,
    I've ordered : Hagon shock absorber (K75/K100 8v short length) SUA50849B
    £150.00 from Motoworks - it should be spot on then.
    Brownz \(Mobile\), Jan 17, 2008
  9. Brownz @ Work
    Steve Parry Guest
    In
    Don't forget you can slide the forks a bit lower in the yokes too.
    Steve Parry
    07 K1200GT SE
    95 BMW F650
    87 Yamaha FS1
    Sukida SK90PY
    91 Kawasaki AR50
    07 VW Passat SE Estate for comfort
    www.gwynfryn.co.uk
    Steve Parry, Jan 17, 2008
  10. Brownz @ Work
    Well done Brownz. **** I used to be the K series saddo around here. I get
    rid of them and they become the new Clit Bike.
    Call Hagon back and get them to send a fork spring upgrade kit with your
    shock. They need it anyway but the Hagon shock is firmer and even more
    mismatched with the standard forks.
    It is easy enough to put the springs in. If you can be bothered mix 5&10w
    fork oil to get 7.5w or just use 10w if you can't be arsed.
    With the new shock and the springs the 100RS will handle quite nicely. Talk
    to a good tyre place, one of the manufacturers recently launched a range of
    radial tyres with some retro sizes.
    EBC HH pads make them stop respectably too for a bit of extra disc wear.
    Hog, Jan 17, 2008
  11. <Salutes>
    Ta for all your advice.
    Will order the springs pronto.
    The chap's just fitted new EBC pads all round as well as doing an oil
    service.
    Thanks for the pointer too Steve.
    Still trying to track down a PDF manual. Anyone ?
    Brownz @ Work, Jan 17, 2008
  12. Brownz @ Work
    Molly Guest
    I did this on my GSXR750, it made a big different and also improved the
    handling.
    Molly, Jan 17, 2008
  13. Brownz @ Work
    Geoff Guest
    Geoff, Jan 18, 2008
  14. Brownz @ Work
    Steve Parry Guest
    In
    I had Avon Azaros on my 8 valve K and they were awesome
    Steve Parry
    07 K1200GT SE
    95 BMW F650
    87 Yamaha FS1
    Sukida SK90PY
    91 Kawasaki AR50
    www.gwynfryn.co.uk
    Steve Parry, Jan 19, 2008
  15. Brownz @ Work
    Aye well that is a radial tyre. It may be the Pilot Powers I heard
    about.
    Be careful though, the K needs a radial tyre with a high degree of
    straight line stability. The original Pirelli MP7 semi radial was
    supplied on the 1985/6 model 100RS Ltd and then on the 16v 100RS.
    Hog, Jan 20, 2008
