K5 GSXR 1000 frame fault?
Discussion in 'UK Motorcycles' started by BGN, Jun 7, 2006.
  1. BGN
    BGN Guest
    Stolen from aus.motorcycles:
    <http://www.wsbtv.com/news/9314629/detail.html>
    It would appear that the horn is drilled into the frame and the
    weakness caused by the hole in the frame can cause the bike to snap in
    two. There's a video news report on the site too.
    If the article is to be believed Suzuki sent a man around to the
    dealer where the bike was being stored and said they would fix bike
    but when the bloke mentioned his $7,000 worth of medical bills they
    went quiet.
    I don't see why the owner of the bike hasn't slammed a law suit on
    Suzuki if he's confident the frame just snapped. More to the story?
    I hadn't seen it mentioned on UKRM and a quick search on Google Groups
    doesn't bring up any hits.
    BGN, Jun 7, 2006
  2. BGN
    Ballistic Guest
    “I was moving my brother’s stuff...."
    Does this mean he had the back loaded with too much weight? I'm also
    surprised that a 25mph off could put somebody in intensive care. Maybe
    more believable if he wasn't wearing a helmet.
    Ash
    UKRMFBC#8 BOTAFOT#82 BOTAFOF#41 HMC#5 FTB#0
    Gone: ETV1000 Caponord
    http://www.theredline.co.uk
    "If everything seems under control, you're just not going fast
    enough." -- Mario Andretti
    Ballistic, Jun 7, 2006
  3. BGN
    Gyp Guest
    Reading it again I suspect that he drilled the hole to fit the horn and
    the frame snapped along the line of the new hole
    Weren't Suzuki happy to fix it until he mentioned his horn hole (so to
    speak)?
    Gyp, Jun 7, 2006
  4. BGN
    Cab Guest
    Read again. The rider and his Dad spotted the hole in the frame.
    But the article isn't that clear on why Suzuki didn't want to do
    anything, until you watch the video clip. It appears that Suzuki
    dropped contact, when the rider asked about his $7000 medical bills. I
    suppose that this could have been an admission of liability and Suzuki
    didn't want to go down that road
    Cab, Jun 7, 2006
  5. BGN
    Mark Reid Guest
    My bet is that his mum reversed over it on the drive.
    Mark Reid, Jun 7, 2006
  6. BGN
    Beav Guest
    Well after passing through a mailbox, he ended up a good 50 yards down the
    road from the point where the bike snapped, as did the bike, plus there were
    gouges in the road for a fair few metres, he went straight to Intensive Care
    and then spent a few weeks in hospital.
    Not bad for a 20mph off.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 7, 2006
  7. BGN
    Cab Guest
    That's 'cos he's a poof.
    Cab, Jun 7, 2006
  8. BGN
    antonye Guest
    Watch the video and you'll see it's the original mounting hole
    for the bolt that holds the horn (or the plate the horn sits on)
    in place.
    FWIW, methinks he probably wasn't too good at landing
    the front wheel, and had caused quite a lot of fatigue to
    the bike. One slam too many in this case.
    antonye, Jun 7, 2006
  9. BGN
    Ralf Mayer Guest
    Ralf Mayer, Jun 7, 2006
  10. BGN
    dwb Guest
    I'm not sure I would view that as acceptable though - if so, I would
    expect the frame on my bike to fail any time now considering the speed
    bumps we have in my area.
    dwb, Jun 7, 2006
  11. BGN
    antonye Guest
    Maybe Suzuki didn't do their testing properly? It's not like a
    motorcycle manufacturer hasn't got it wrong in the past.
    Best you get shot of your bike now, and buy an SUV or something...
  12. BGN
    dwb Guest
    Okay, serious question - what would you expect to fail if you performed
    ham fisted wheelies all of the time?
    I would expect one or more of the following to exhibit problems :
    1) Fork seals
    2) Forks themselves
    3) Head bearings
    4) wheels
    I would not, in a million years, expect the frame to go BEFORE any of
    these other items.
    Why? You seem to have made it very personal, I was merely pointing out
    that abusing the front wheel would seem 'normal' and certainly not
    something that should cause the _frame_ to collapse.
    dwb, Jun 7, 2006
  13. BGN
    antonye Guest
    Only if there wasn't a fault with the frame - the weakest component
    will fail, and in this case it may be the frame rather than the forks/
    fork seals/ wheels/ etc
    Again, unless there was a fault with the frame.
    I'm not making it personal, just offering an opinion.
  14. BGN
    Beav Guest
    I thought it was a Gixxer, not an ER-5
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Jun 7, 2006
  15. I would do a visual inspection from time to time. It was probably well
    cracked before it broke off.
    eric the brave, Jun 8, 2006
  16. There was something last year relating to the same thing. I don't recall
    if it was the same model. Nasty crack up the ally just behind the
    headstock and total disconnection.
    Grimly Curmudgeon, Jun 9, 2006
