thanks to the encouragement and tips i received here last month, i completed the drive shaft and clutch spline lubes without a hitch. so i thought i'd push my luck with some questions about the front suspension on my '92 k75s. i've mentioned before that it takes bumps remarkably hard (even bottoming out at times, i believe.) according to the records of the guy who had the thing before i did, he had the fork springs (along with the seals, spacers, et al) changed a little less than a year ago and the bike's been ridden less than a thousand miles since. per advice offered here previously, i'd like to start the troubleshooting by changing the fork oil. unfortunately i've noticed that the thing is leaking oil onto both forks at the top of the sliders. so i feel like i ought to replace the fork oil seals before changing the oil. further complicating things, the leak and the rough handling are making me wonder if the mechanic installed the forks correctly. this and previous events with different shops have brought me to the point where, unless i do the work myself, i'll be plagued with doubts that the work has been done right. so now i'm thinking about dismantling, inspecting, and reinstalling the forks. problem is, i don't know what the hell i'm doing. i've taken a cursory look at the clymer's guide and gathered the impression that it's not too complicated. on the other hand, i also looked at randy g's fork alignment treatise (see Duane Ausherman's BMW website,) and it convinced me that i have neither the facilities, tools, nor know-how for the job. in any event, my goals are (a) to make sure the forks are assembled and operating correctly, (b) to change the fork oil, and (c) to change the fork oil seals. with that in my mind, here are my questions: #1: if i take the forks off the bike, how difficult is it to get them back on properly? i don't understand or have the tools to do all that i saw in randy g's patient, well organized explanation. should i just take it in to a new mechanic? if so, can you recommend someone in san francisco? #2: in case you encourage me to do this myself, what oil should i use? are they any parts (other than the oil seals) i ought to replace while i'm there. #3: any other tips? also: i should probably have mentioned that i'm not sure if the forks are stock or aftermarket. all input appreciated.
