kawasaki 91 zzr250
Discussion in 'Australian Motorcycles' started by tiger06, Jun 15, 2006.
  1. tiger06
    tiger06 Guest
    Hi all,
    I have a 91 zzr250 and i have found that i can hear like a tick tick
    sound when im riding and it gets lowder the faster i go. is this normal
    or do i have some problems? a mate said it could be sticky lifters.
    any help would be great
  2. tiger06
    J5 Guest
    could be a buggered chain
    J5, Jun 15, 2006
  3. tiger06
    bikerbetty Guest
    I had a tick tick sound happening till I got the cam chain tensioner
    adjusted (I think that's what it's called). It was especially
    noticeable when idling, but it was there all the time - didn't notice
    it getting louder with speed, though, so it might've been something
    completely different from your 'tick tick'...
    betty
    bikerbetty, Jun 15, 2006
  4. tiger06
    Hammo Guest
    IMNSHO, the ZZR 250 sound bloody terrible at idle and then just gets worse.
    If it is a new noise, I'd be concerned. Simply remedies are along the lines
    of:-
    New oil and filter
    Good hard run (once warmed up, obviously)
    Checking chain tension (you don't actually say if the noise is idle or slow
    riding)
    Check wheel bearings
    Brake calipers and other things that have things pass through, or rotate
    faster as road speed increases.
    Hammo
    Hammo, Jun 15, 2006
  5. tiger06
    Jacko Guest
    Check the exhaust is tight where it bolts to the cylinder head, that can
    sometimes create a ticking sound.
    Had a ticking sound on my FJ1200 and one of the pipes was loose.
    Jacko
    Jacko, Jun 15, 2006
  6. tiger06
    Theo Bekkers Guest
    Sounds very painful.
    Theo
    Theo Bekkers, Jun 15, 2006
  7. tiger06
    I had a '94 GPX250 with a similar symptom. After checking the valve
    clearances, replacing the camchain tensioner, and replacing the head
    all failed to cure the problem, I sold it.
    BT Humble, Jun 16, 2006
  8. tiger06
    tiger06 Guest
    na chain is fairly new tension is good, there all the time whether im
    idling or not. what sort of dosh am i lookin at if its tapets ?
    cheers for all feedback
    tiger06, Jun 16, 2006
  9. If it's there at idle, then it's not wheels or primary drive chain. If
    it's not there at idle, but only present when moving, suspect wheel
    bearings or the chain. If it changes with engine speed, suspect the cam
    chain tension: the chain may have stretched beyond the ability of the
    tensioner to compensate. If it only changes with bike speed, not engine
    speed, and it's not the wheels or chain, get a mate to run alongside and
    see if you can pinpoint *where* the noise is coming from.
    Andrew McKenna, Jun 16, 2006
  10. It's the crocodile...
    Bumblebeeman1150, Jun 18, 2006
  11. tiger06
    The Biker Guest
    The Biker, Jun 19, 2006
