KTMs - not as tough as they're cracked up to be
Discussion in 'UK Motorcycles' started by ogden, Jan 17, 2011.
  1. ogden
    Jim Guest
    Flat tyres?
    Jim, Jan 31, 2011
    #41
  2. ogden
    yes, but I don't think that's reason the thing is feeling sluggish.
    It really is incredibly hard to move.
    I've moved it from the back patio to the side of the house - it's
    visible now from the street - I hope someone nicks it.
    darsy, Jan 31, 2011
    #42
  3. ogden
    no, it's not that either.
    darsy, Jan 31, 2011
    #43
  4. ogden
    Adrian Guest
    Or it's in gear.
    Adrian, Jan 31, 2011
    #44
  5. ogden
    hah.
    darsy, Jan 31, 2011
    #45
  6. ogden
    Mups Guest
    Subsidence, and you now live at the bottom of a hill.
    Mups, Jan 31, 2011
    #46
  7. ogden
    ts Guest
    Subframe broken and wedged between wheel and swing arm?
    ts, Jan 31, 2011
    #47
  8. ogden
    Pete Fisher Guest
    In communiqué
    Fubar wheel bearings.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 31, 2011
    #48
  9. ogden
    crn Guest
    Flat tyre.
    crn, Jan 31, 2011
    #49
  10. ogden
    Sticky brake pistons.
    Krusty, Feb 1, 2011
    #50
  11. ogden
    SIRPip Guest
    That's be favourite, followed by Pete's suggestion of rusty wheel
    bearings.
    SIRPip, Feb 1, 2011
    #51
  12. ogden
    Pete Fisher Guest
    Indeed. I had mentally included sticky pistons under manky brakes. The
    YZ front ones made even a pip squeek weight crosser an effort to push.
    Instant improvement on times was achieved when I got new seals in the
    caliper and master cylinder.
    Pete Fisher, Feb 1, 2011
    #52
  13. ogden
    I reckon it just needs an Italian tune-up.
    darsy, Feb 1, 2011
    #53
  14. ogden
    to be serious for a moment, it's making a sort of "screeesh" noise
    when pushed, and I reckon the "brake caliper" suggestion is correct. I
    don't think it's the bearings, because IME that sort of problem[1]
    makes it feel lumpy-bumpy[2] as well as stiff.
    [1] they went on my old TRX.
    [2] this is a technical term.
    darsy, Feb 1, 2011
    #54
  15. ogden
    It will be, & won't take more than a few minutes to pop the calipers
    off to prove.
    I know the Japs aren't renowned for being liberal with the grease, but
    there's no way wheel bearings are gonna rust to that extent on a
    modernish road bike unless you've gone mental with a pressure washer.
    Krusty, Feb 1, 2011
    #55
  16. ogden
    Pete Fisher Guest
    In communiqué
    If you can get each wheel off the ground far enough to spin diagnosis
    should be fairly simple. Not an easy task with such a behemoth unless
    you have the requisite paddock stand I'll grant. Fairings generally
    exclude the trolley jack option.
    #56
  17. ogden
    Pete Fisher Guest
    Now you have gone and spoiled by attempt to get darsy's bike teetering
    on a pile of bricks.
    True.
    #57
  18. ogden
    Question is, can darsy remove calipers or will he need to get a man in?
    ogden, Feb 1, 2011
    #58
  19. ogden
    It typically involves using one spanner to remove six bolts to get all
    three calipers off[1], which shouldn't be beyond even sir.twatty.
    [1] At least off enough to check if that's the problem.
    Krusty, Feb 1, 2011
    #59
  20. ogden
    hah - I have a proper bike lift/stand thing.
    Though as you mentioned in another post, the fairing is an issue.
    darsy, Feb 1, 2011
    #60
