Kw to Hp fomular please.
Discussion in 'Australian Motorcycles' started by Aido, Jan 11, 2004.
  1. Aido
    Aido Guest
    As the heading asks.
    Aido, Jan 11, 2004
  2. Aido
    Damien Guest
    0.74kW = 1hp (approx)
    there's a slight difference between imperial and metric horsepower, but the above will get you close enough
    Damien
    GPX250 (stolen) -> CBR600
    Damien, Jan 11, 2004
  3. Aido
    Tony Morris Guest
    1 hp is equivalent to 0.7457 kw.
    Tony Morris
    (BInfTech, Cert 3 I.T., SCJP[1.4], SCJD)
    Software Engineer
    IBM Australia - Tivoli Security Software
    (2003 VTR1000F)
    Tony Morris, Jan 11, 2004
  4. Kevin Gleeson, Jan 11, 2004
  5. Aido
    Moike Guest
    typing "convert kilowatt to horsepower" into google gives
    "1 kiloWatt = 1.34102209 horsepower"
    Moike
    (You can do most conversions this way,
    typing "convert 120 kilowatts to horsepower" into google gives
    "120 kiloWatts = 160.922651 horsepower")
    Moike, Jan 11, 2004
  6. Aido
    Sprint Guest
    KW x 1.341 = HP.
    Sprint :)
    Sprint, Jan 11, 2004
  7. Aido
    Biggus Guest
    Biggus, Jan 11, 2004
  8. Aido
    Theo Bekkers Guest
    Surely you can come up with a couple more decimal places?
    Does BInfTech mean Bloody Interfering Techo in IBM-speak?
    Theo
    Theo Bekkers, Jan 11, 2004
  9. What about ps -> kw?
    James Mayfield
    "Insert witty comment here."
    James Mayfield, Jan 11, 2004
  10. Aido
    Mike.S Guest
    ps -> hp is
    1.03 = 1
    Mike.S
    Mike.S, Jan 11, 2004
  11. Aido
    Doug Cox Guest
    ps is metric horsepower. The difference is about 1%.
    1ps/hp = ¾kw.
    Doug Cox.
    Work to ride, Ride to work...
    Doug Cox, Jan 11, 2004
  12. Actually, ps if pfundstark. From germany. (Yes, I know that it's the same as
    metric horsepower, I'm just being a nerd.)
  13. 1 kW is equivalent to 1.341022 hp
    Al
    Alan Pennykid, Jan 12, 2004
  14. In aus.motorcycles on Mon, 12 Jan 2004 14:57:51 +1100
    Spagthorpe spares are bloody hard to get you know!
    Zebee
    Zebee Johnstone, Jan 12, 2004
  15. Aido
    John Dwyer Guest
    The best that I can obtain, corrected to three decimal places is
    1 HP = 0.746 KW
    and
    1 PS = 0.735 KW
    Several sites are available by putting
    conversion PS HP
    into Google search.
    John Dwyer
    John Dwyer, Jan 12, 2004
  16. Aido
    Aido Guest
    Thanks Peoples.
    I think there's enough info there to get me outa trouble.
    Aido, Jan 12, 2004
  17. Aido
    Jorgen Guest
    Or hestekrefter, if you want to go a bit further up north.
    j
    Jorgen, Jan 12, 2004
  18. Aido
    glitch1 Guest
    "James Mayfield"
    PS is (German ) Pferdestaerke which is the direct translation for horsepower
    or hp.
    Only the actual measurements are marginally different, the word means
    exactly the same.
    cheers
    pete
    glitch1, Jan 12, 2004
  19. Aido
    Gene Nygaard Guest
    Only if you specify how you define the pound force, which doesn't have
    an official definition.
    If you borrow the standard acceleration of gravity which is official
    for defining kilograms force (obsolete units that are not part of SI,
    the modern metric system), then to a couple more digits you have
    1 hp = 0.745 700 kW
    As you might be able to figure out, the calculations aren't much
    harder if you include those last two digits!!!
    Gene Nygaard
    Gene Nygaard, Jan 12, 2004
  20. Aido
    Nev.. Guest
    So for fun you just cruise google groups and search for keywords which will
    let you prove that you know more about force, mass and measurements of such
    forces and masses than anyone else and then you join in a discussion of how to
    convert one measure of force to another with impressive sounding catch phrases
    like "kilograms force" and "standard acceleration of gravity"... and you still
    didn't answer the question better than anyone else, and they're just a bunch
    of rough biker types.
    And just in case anyone was wondering about SI, the modern metric system...
    http://ourworld.compuserve.com/homepages/Gene_Nygaard/si.gif
    Nev..
    '03 ZX12R
    '02 CBR1100XX
    Nev.., Jan 12, 2004
