KX80 Oil problem
Discussion in 'Australian Motorcycles' started by ROB, Apr 3, 2005.
  1. ROB
    ROB Guest
    Hi .My son has a 1985 KX80 e3 and it runs well but the gearbox oil seems to
    disappear from the box and end up dribbling through the exhaust pipe as a
    black gunge and covers the right-hand side swingarm. I know the cylinder is
    a sealed section , is the oil making it's way in and if so where, is it the
    crank seal? For that is the only thing I can think of, for the oil to make
    its way through to the exhaust pipe. The bike starts well and runs well so
    it seems it is not burning the oil. Does anyone have an idea which will
    help. Thanks Robert
    Robert Harrell
    INIT Mobile Computer Services
    www.init.com.au
    0403511278
    0266795589
    ROB, Apr 3, 2005
  2. ROB
    Rod Bacon Guest
    Having been down this road before....
    Don't spend any money on a 20 year old bike. Keep putting oil in it until it
    stops working, then bury it in a big hole...
    Rod Bacon, Apr 3, 2005
  3. ROB
    -:Install:- Guest
    Crankshaft seals.
    -:Install:-, Apr 3, 2005
  4. ROB
    jim garvey Guest
    hi
    there is a way to test the crank seals.put castrol R in the gearbox after
    draining the oil out.if it is burling the oil from the gearbox you will be
    able to smell the R burning.
    jimg
    jim garvey, Apr 3, 2005
  5. ROB
    ROB Guest
    Thanks you guys I think I will ignore the first comment being a vintage
    cycle enthusiast. I think the seals also. Thanks for the help. Cheers Robert
    ROB, Apr 3, 2005
  6. In aus.motorcycles on Sun, 3 Apr 2005 17:47:31 +1000
    No, spend it all on the 30yo ones instead.
    Zebee
    - waiting for the hoonbike's 30th birthday
    Zebee Johnstone, Apr 3, 2005
