KZ 750 (4) brake issue
Discussion in 'Motorcycle Technical Discussion' started by mauserdude, Sep 8, 2005.
  1. mauserdude
    mauserdude Guest
    I picked up a 1981 Kawasaki KZ 750E (4 cylinder) a couple a months ago
    and have been plagued with front brake issues. It has twin discs up
    front. Here's the story:
    After having the bike on it's side for a weekend to replace the starter
    clutch the front brakes started feeling squishy. I bled the brakes for
    2 hours and it didn't feel better.
    I bought a vacuum brake bleeder and bled the brakes using that, but no
    luck.
    I rebuilt the master cylinder (it looked pretty clean) and re-bled. No
    luck.
    I re-built both front calipers. It was pretty dirty and one of the
    pistons was probably 'stuck'. It took 4 times the compressed air
    pressure to get the right piston out. I cleaned everything with brake
    fluid and replaced all the rubber seals. I put it all back together
    and bled the brakes again. I tried installing brake bleeder nipples,
    but the ones I ordered didn't fit. So I put the stock ones back on.
    The brakes are still squishy. My brother had the idea of using clamps
    to squeeze the pistons slightly and see if that made a difference in
    how the brakes feel. After clamping both pistons they felt pretty good
    (not perfect). Is it possible the piston doesn't have enough travel to
    get good pressure on the back of the pad.
    My question is this. Is it safe to use shims between the piston and
    the pad? Is there anything else anyone can think of to help fix this?
    It's pretty frustrating.
    Thanks for any advice.
    -mauserdude
  2. wrote in @g49g2000cwa.googlegroups.com:
    Replace the brake lines?
    Michael J. Freeman, Sep 8, 2005
  3. Here's a logical strategy for bleeding brakes and getting all the air
    out without buying some aftermarket vacuum pump...
    Idiots? What were the original equipment motorcycle brake system
    engineers thinking of, when they put the air bleeder screws down there
    on the calipers? Were they that fucking STUPID?
    Answer is: yes, they were that dumb. If you want to bleed air out of an
    air over fluid system, you bleed the air out of the HIGHEST point in
    the system, not a lower point!
    Any time I have to bleed brakes, I don't mess with those stupid leaky
    bleeder screws. They are messy and they leak air right back into the
    system you're trying to get it out of. One of those silly vacuum pumps
    can suck air around the bleeder screws, too, as can aquarium air line
    tubing commonly used to bleed brakes by submerging one end in a jar of
    fluid. Messy, messy, messy!
    My method: I unbolt the brake calipers and I put a piece of 1/4 inch
    steel plate between the brake pads. I let the calipers hang straight
    down so the banjo fitting on the caliper is the highest point down
    there. I loosen the master cyclinder bolts and arrange the handlebars
    in a position where the fluid reservoir is HIGHER than its banjo bolt.
    I arrange all the hoses so there are no high points for air to be
    trapped in. When I pump the brake lever the air MUST go up into the
    master cylinder. My brakes remain nice and firm after this careful
    bleeding.
    Aftermarket genius: Poking around on the internet, I found an
    aftermarket brake system company (they make braided steel brake
    hoses), and those geniuses came up with an air bleed banjo bolt that
    fits on the master cylinder and sells for about $15.
    All the owner has to remember is to cover everything up when bleeding
    the upper banjo so he doesn't get nasty brake fluid on his paint. That
    stuff removes clear coat PDQ...
    You don't need to shim the pistons. The pistons are self-adjusting. The
    square-section o-ring that seals the brake fluid into the caliper acts
    as a rubber ratchet. It lets the pistons slide out as necessary, then
    holds them in position. As the disk rotors wobble a tiny bit
    side-to-side from normal run out and a little bearing wear, this knocks
    the pads back a tiny amount, but the rubber o-ring can handle that...
    If you have a whole lot of run out, say one of the disks wobbles
    side-to-side more than 0.012 inches, you might notice that the front
    brakes were very spongy when you first applied them, but you'd probably
    also notice that the front brake lever pulsed in your hand...
    krusty kritter, Sep 8, 2005
  4. mauserdude
    Battleax Guest
    snip
    You had the bike on it's side? I hope this doesn't mean you actually had the
    bike on it's side.
    Battleax, Sep 8, 2005
  5. mauserdude
    John Johnson Guest
    An alternative for the vacuum brake bleeder:
    if your vacuum bleeder can also supply positive pressure (my MightyVac
    can), you can _push_ the fluid in from the low point of the system. Of
    course, this works best when the system is empty to begin with. You'll
    also need to seal the threads on your bleeder screws. I used a couple of
    turns of plumber's pipe tape. Pull the caliper off it's mount so that
    you can hold the bleeder screw at the bottom. Attach everything, open
    the screw and pump fluid in slowly until it bubbles out of the bottom of
    the reservoir. You'll probably still need to do a bit of pumping to
    clear bubbles from the MC, but you also probably won't have air in the
    lines any lower.
    I used this method on my clutch ('94 VFR, swapped out OEM lines for
    braided SS) and got a solid clutch lever in one shot, no re-bleeding
    necessary. Guys on the VFR mailing list I was on often complained about
    having to re-bleed the clutch multiple times. I think that pumping fluid
    into the system with the bleeder screw at the low point was a factor.
    As someone else pointed out, some sponginess can come from old brake
    lines. If yours are original to the bike, new lines should move (close?)
    to the top of your list.
    Later,
    John
    John Johnson, Sep 9, 2005
