lahndahn
Discussion in 'UK Motorcycles' started by Simon Wilson, May 11, 2009.
  1. Simon Wilson
    Simon Wilson Guest
    My first commute into the smoke happened today.
    1) The M4 bus lane is brilliant fun
    2) I have no idea of the speed limits after the end of the M4
    3) I need to learn where the cameras are
    4) Much improvement on filtering skills needed
    5) Filtering is almost impossible in many places, roads too narrow.
    5) A Pan European is a bit too big
    6) London drivers actively try to stop you filtering, on the M4 they
    move to give you room (if they see you)
    7) Darsy's ten minutes from the elevated section of the M4 to Tottenham
    court Road is a tad optimistic IMHO. Took me thirty.
    8) I hope I didn't get a fine for going in the bicycle/bus lane
    Going home is the reversal of getting there[1]
    [1] Except for the one way bits.
  2. Simon Wilson
    Catman Guest
    You need a smaller bike.
    See 4
    Hmm. Never really had that problem.
    Sounds about right, but Darsy rides like a ****
    www.cuore-sportivo.co.uk
    Catman, May 11, 2009
  3. Simon Wilson
    Nige Guest
    A Pan is too big for that, i was looking at one, but i have just watched my
    journey to work on my bike cam from this morning. A Pan would be just too
    big for the bits i need to do quickly.
    Nige,
    BMW K1200S
    Range Rover Vogue
    Aprilia RSV Mille
    Nige, May 11, 2009
  4. Simon Wilson
    Nige Guest
    I'll look one up, i need something, a sportsbike is a pain in the arse on
    the run i do, but the power is nice :)
    Nige,
    BMW K1200S
    Range Rover Vogue
    Aprilia RSV Mille
    Nige, May 11, 2009
  5. Simon Wilson
    davethedave Guest
    Sometimes using violence.
    And just what colour is your Pan good sir. :)
    Its not too far off. Have you ever seen Darsy in traffic. I saw him once
    on Embankment. Then he was gone in the twinkling of an eye leaving only
    the reverberation of satans own exhaust bouncing off the buildings.
    davethedave, May 11, 2009
  6. Simon Wilson
    You'll get those if you go into London for long enough. That, and slow
    speed skills.
    Depends. You'll get used to it.
    What amuses me is that the ones who try to block you keep forgetting
    that their car just doesn't get any wider when them do the blocking
    move so you just go past on the other side.
    Sir might want to have a look for the motorcycle symbol on said lanes :)
    Timo Geusch, May 11, 2009
  7. Simon Wilson
    Simon Wilson Guest
    Yes. My slow speed riding isn't too bad but still room for improvement.
    Heh. Yes. I got caught by a one bit of road that I wanted to go up that
    only had a bicycle lane in the direction I wanted to go in. Google maps
    isn't accurate on some of the one way roads.
  8. Simon Wilson
    Watch out for the Redspeed camera on the central reservation about
    halfway along.
    40 from the end of the bus lane to, a bit after Hammersmith, maybe Earls
    Court. I think.
    There are too many to remember, just keep your eyes open.
    Filtering is possible just about everywhere, you're just not spotting
    the gaps.
    You're giving them a chance to try to stop you? Weak.
    Bus lanes are fair game if they're on red routes. The fine for
    contravening a cycle lane is only 30 quid and carries no points (a
    "friend" was once nicked in one) so hardly worth worrying about.
    ogden, May 11, 2009
  9. Simon Wilson
    serf Guest
    Congrats. It gets better with practice. The first time I rode in from
    Croydon to Oxford Circus, I shat bricks. Took around two weeks to
    really get to grips with it.
    Depends what you are trying to achieve. If you want to duck and dive
    every time the slightest gap appears, then yes. On the other hand if a
    more comfortable and relaxed leisurely amble through the traffic
    suits, with more time to read the road ahead and plan those periodic
    killer overtakes, then IWHT the ST1100 pretty near perfect. Having
    recently gone from CB500 to Pan, I find it does require a different
    mind-set.
    Most don't usually. Perhaps you had a bad day for this.
    Was there a picture of a motorbike on the blue sign? A lot of riders
    now assume that all bus lanes are open to them and don't check.
    Watch out for complacency when you have done the journey for a few
    weeks.
    serf, May 11, 2009
  10. Simon Wilson
    B 650 Guest
    Agreed, until you get onto marylebone/euston road, when I found it very
    difficult indeed. Embankment is much more fun nowadays...
    B 650, May 11, 2009
  11. Simon Wilson
    Dave H. Guest
    "Simon wrote
    Just wach the brake lights...
    HID lamp on high beam helps a bit - oncoming traffic pulls over, drivers
    moaning "God, my eyes, I'm blind!"
    Not a lot bigger than a ZZR11 is it? Though I make do with a topbox,
    panniers nearly double its width...
    Sir wants a Steibel Nautilus "audible warning of approach which is
    continuous and not strident" - puts the fear of god up 'em / makes everyone
    else stare at 'em thinking "must be driving like a twat" - even makes daft
    pedestrians step smartly back onto the kerb when the red man shows. I might
    fit a second one.
    Might be worth investigating the parallel routes?
    There's a map of the ones you can use on the TFL.gov.uk website
    But more of the M4's NSL :eek:)
    Dave H.
    Dave H., May 12, 2009
  12. Simon Wilson
    dog Guest
    usually they are just a bit less observant than average, possibly due to
    stress or genetics. never attribute to malice that which can be explained
    by incompetence.
    getting louder pipes often helps.
    dog, May 12, 2009
  13. Simon Wilson
    Simon Wilson Guest
    Aye, clocked that, ta.
    And then 30 everywhere I guess?
    I'll try harder sir.
    Orly? Someone here told me he got two 60 quid fines the same day. On a
    scooter, so maybe that was why.
    Much better this morning, it makes a huge difference if you can get to
    the front for the traffic light Grand Prix - 'cos you can then stay at
    the front.
    /Simon
    Simon Wilson, May 12, 2009
  14. Simon Wilson
    Quite. I can't remember a single incident of someone actively stopping
    me from filtering[1] but there are hundreds if incidents where they
    will drift across because they're on the phone, doing their make-up,
    doing the crossword, having a shave, asleep, etc., etc.
    [1] Of which I could be 100% sure.
    CT, May 12, 2009
  15. Simon Wilson
    Pretty much, yeah. The curse of the 20 mph limit hasn't really hit
    central London yet.
    My friend really is a very close friend indeed, and he was on a gixer
    thou when he was nicked in a cycle lane. 30 quid, no points.
    Totally. It amazes me how slow people's reactions are when the light
    goes amber. And don't even get me started on fucking scooters. Or the
    one cyclist who, rather than jumping the red, decides to wobble
    ambivalently around at the front of the queue blocking any faster
    passage. Grr.
    I've been using the tube over the last week after noticing the mileage
    on the thou - between the french run, a couple of FOTs and three months
    of 7-mile-each-way commutes through central London I've racked up an
    entire service interval. Not good.
    ogden, May 12, 2009
  16. Simon Wilson
    Is this "humour" or are you a total cock?
    ogden, May 12, 2009
  17. Simon Wilson
    Nige Guest
    eh? 90% of that post is utter horseshit.
    Nige, May 12, 2009
  18. Simon Wilson
    When I did it, it was on an R30 supermoto - somewhat more filter-happy
    than a Pan.
    darsy, May 12, 2009
  19. Simon Wilson
    that'd have been the R30, I imagine.
    I'm very out of practice riding generally at the moment, but the one
    aspect I still seem to be able to do is filter like a twat.
    darsy, May 12, 2009
  20. Simon Wilson
    just north of Euston Road, all around Somers Town: 20mph everywhere.
    darsy, May 12, 2009
Similar Threads
Loading...
