Laptop repairs
Discussion in 'UK Motorcycles' started by Lozzo, Apr 29, 2008.
  1. Lozzo
    Who?
    My old steam driven Compaq Armada E500 (stop sniggering at the back)
    refuses to boot up. I use it down in the garage when I need an online
    manual, or to read a cd one. I know it needs a battery, but it used to
    work fine off the mains charger until it stopped booting up.
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 29, 2008
  2. Lozzo
    Derek Turner Guest
    Oh FFS, what happens when you try? beep codes? does it POST? if so, what
    OS is it meant ot boot?
    Derek Turner, Apr 29, 2008
  3. Lozzo
    It's meant to boot in Win XP Pro. it gets as far as the screen with the
    flag and scrolling horizontal bar, then goes to a backlit plain dark
    screen. At this point the innards start making frog type noises and it
    jkust hangs there for a couple of minutes before shutting down and
    starting again. When you first fire it up it defaults to a screen
    telling me to choose the mode to start, i.e 'Safe mode' etc. If I pick
    either dsafe mode it scrolls a load of code lines and hangs then starts
    frog noises. if I pick last known config or start in windows it does
    the flag screen bit.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 29, 2008
  4. Lozzo
    Higgins Guest
    Greybeard, IIRC.
    Higgins, Apr 29, 2008
  5. Lozzo
    Ah yes, I remember now - but this thing is ancient, I wonder if he'll
    touch it.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 29, 2008
  6. Lozzo
    zymurgy Guest
    Sounds like the hard drive is shagged, or the OS is corrupt. Try a
    reinstall, followed by a new hard drive.
    P.
    zymurgy, Apr 29, 2008
  7. Lozzo
    Derek Turner Guest
    <fx: donning flame-proof suit>
    OK so it POSTs OK and only collapses when it tries to load WinXP Pro. If
    you have another computer that works I would suggest d/l'ing a 'live CD '
    of any linux distro. I'd use www.linuxmint.com, but then I would,
    wouldn't I. PCPro recently had an ISO of SuSE on its cover CD. It really
    doesn't matter which distro you choose, Puppy linux is a nice small one.
    Boot from the live CD and see if the rest of the laptop is working. If so
    it's either a corrupt Windows (re-install) or possibly a shagged hard
    disk (the live CD should have the tools to test this). Take appropriate
    action. If you don't have the facilities to d/l a distro I will happily
    burn and send you a CD if you send me a snail-mail addy. Genuine offer,
    no strings attached.
  8. Lozzo
    Greybeard Guest
    I can always have a look.
    If it's a hard drive, then shouldn't be too difficult, if it's the
    controller or other motherboard problem it probably won't be worth playing
    with.
    Is there any data on it that you "must have" and haven't got backed up?
    Fixing ancient pooters, (DEC stuff springs to mind!) & modern stuff, is what
    we do.
    email addy works if cleared and you should have my mobbly in your archive
    someplace.
    I owe you a favour anyway ;o)
    Greybeard
    FLHR -03 UK (95 cu-in Stg 2. Big Boy2!)
    Trumpet Trophy 1200-03
    Garmin Zumo 550, To get me home!
    ukrm@foxtails[dot]co[dot]uk
    Greybeard, Apr 29, 2008
  9. Lozzo
    zymurgy Guest
    Cool, gissa job. I can do that.
    I'm probably one of the few on here that has played with a DEBNA,
    KFQSA or a QBus MIcroVAX
    Apart from Auvache of course.
    P.
  10. Lozzo
    crn Guest
    Sounds like the disk has died.
    Replace disk and reinstall, recover from the backups that you carefully
    preserved.
    crn, Apr 29, 2008
  11. Lozzo
    I lost the will to live right about here.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 30, 2008
  12. Lozzo
    There's bugger all of any interest on it, totally blank as far as I'm
    aware. I'll arrange a time and place to meet via email.
    Cheers
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 30, 2008
  13. Lozzo
    Dan L Guest
    Perhaps it's overheating - try blowing through the vent holes with a
    can of air.
    Dan L
    Too much time to think, too little to do.
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6/7)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Apr 30, 2008
  14. Lozzo
    Greybeard Guest
    I like the last bit!
    <VBG>
    Greybeard
    Greybeard, Apr 30, 2008
  15. Lozzo
    Greybeard Guest
    That it makes it very easy then.
    I'll try an install of XP Pro, that'll show up any disc weaknesses, I can
    sort a disk if needed after that.
    Let me know when, where, how & what at your convenience.
    Greybeard
  16. Lozzo
    Greybeard Guest
    That could be the case, as the little fans so cause the heatsinks of lapdog
    to block up solidly.
    But it normally takes a little longer than initial boot to overheat and
    shutdown.
    Symptoms don't seem quite right for overheat though.
    Greybeard
  17. had the same problem on my acer , had to have the hard drive changed
    because there was a faulty sector on it .
    just change the hard drive reinstall windows and you should be ok
    keep your old hard drive , for a £10.00 you can get g tech enclosures
    , stick your old hard drive in that and you should be able to retrieve
    most of the infomation on it
    steve
    steve robinson, Apr 30, 2008
  18. More burntmail's territory, that.
    GS850x2 XS650 SE6a
    "It's a moron working with power tools.
    How much more suspenseful can you get?"
    - House
    Grimly Curmudgeon, Apr 30, 2008
  19. "One of", yes...
    Dr Ivan D. Reid, Apr 30, 2008
  20. Lozzo
    KM Guest
    Lozzo wrote:
    || Who?
    || to work fine off the mains charger until it stopped booting up.
    If its got 2 DIMMS, try swapping them over.. it looks like there may be a
    duff block of memory if nothing else has changed. Either that or the disk
    may be going tits up.
    KM
    FJ1200 FZS600 GSX400F
    http://www.czd.org.uk
    KM, May 3, 2008
