Latest GT Fault
Discussion in 'UK Motorcycles' started by sweller, Apr 10, 2008.
  1. sweller
    GT750 does an odd thing.
    GT750 starts ok on the choke, runs ok on the choke. Choke in.
    A few minutes later it starts to run like shit (feels like a coil has
    died), choke back out, still runs like shit, choke back in, still runs
    like shit.
    ....then after a few minutes it runs perfectly and continues to do so.
    This was mentioned a couple of weeks ago and it was thought maybe cracked
    insulation on the coil allowing moisture but I've changed the coils and
    sealed them.
    It's had new HT leads, caps and plugs, although it had been stood for a
    couple of years the carbs had petrol in them when I drained them (except
    No.3 as the drain screw wouldn't undo) It seems related to engine
    temperature and hasn't always done it.
    Ideas?
  2. sweller
    it's shit.
    darsy, Apr 10, 2008
  3. sweller
    Possibly that's why I like it.
  4. sweller
    TOG@Toil Guest
    It could be a coil giving up again. When the first coil died on it, I
    was confused because the symptoms were *exactly* like a fuelling
    problem, to the extent that juggling with the choke seemed to have an
    effect on it. It didn't die instantly: it played up intermittently for
    quite a while first. And then it went zonk, dead.
    When the other coil started playing up in the same manner, I was ready
    for it :)
    FYI: the same coils are fitted to loads of Kawasakis of that era. But
    beware if you're sold Z/GT/GPz550 coils, because while they are indeed
    identical, the HT leads are a bit shorter because of the smaller
    engine *and they don't fucking reach the outer plug caps*.
    DAMHIKIJK,OK?
    However, the HT leads are actually interchangeable rather than sealed
    into the coils, so you can swap 'em over.
    A cheaper option is just to get some aftermarket high output coils,
    which are half the price. When I owned that GT, genuine Kwacker ones
    were £70-odd. Luckily I managed to pick up NOS ones in an autojumble
    for about £15.
    Anyway, back to the original question. It's a coil.
    TOG@Toil, Apr 10, 2008
  5. sweller
    That's what's confusing me as I'd say exactly that - I've already swapped
    them over with a spare one but the interesting thing is it doesn't die
    when hot (which is what normally happens) it runs perfectly!
    I'll rob the pair off the Turbo and try them.
  6. sweller
    Ask SD, he knows about these things.
    Lozzo
    Suzuki SV650S K5
    Honda CBR600 FW trackbike
    Yamaha SR250 Spazz-Trakka
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 10, 2008
  7. sweller
    TOG@Toil Guest
    That's what I thought it was when the coil first went on me!
    Easy to check: just turn the tap to Prime and try it like that.
  8. sweller
    Bah. The FGFOF(1) DDT(2) (related directly to GPS(3)) says it's a
    sticky choke cable.
    Runs on choke when cold. Choke (apparently) in, butterflies actually
    still closed. Engine warms up, runs too rich, tries to conk. Choke
    (apparently) in and out, no effect. Vibration/heat/time causes the
    butterflies to eventually open, bike runs fine - until next time the
    choke is used.
    Easy tests - start in the morning without choke and see if it still
    happens the same way. Alternately (or additionally) use the choke
    when it's hot, then slap it in when the engine starts to splutter and
    see if it stops spluttering immediately.
    1. Fickle Ginger Finger Of Fate (TM)
    2. Distant Diagnosis Tool
    3. Geordie Pointing System (4)
    4. "Torn reet! Torn lift! Gan strayt ower, man!"
    Pip, Apr 10, 2008
  9. sweller
    TOG@Toil Guest
    Except that the GT doesn't have a choke cable: push-pull slide jobbie
    on the carb bank.
  10. sweller
    You know, my theory was fine - right up until you said that. all the
    Kwackers from that era had that, didn't they? Buggrit.
    Pip, Apr 10, 2008
  11. sweller
    TOG@Toil Guest
    Have you got a cat you can kick? :)
  12. sweller
    I've got a Spic here - will that do, d'you think?
    Pip, Apr 10, 2008
  13. sweller
    No, this one kicks back.
    Lozzo
    Suzuki SV650S K5
    Suzuki GSXR750 L
    Suzuki TS50X
    Suzuki TS50X
    Lozzo, Apr 10, 2008
  14. sweller
    <sniggers>
    <points at slippers>
    Pip, Apr 10, 2008
  15. Shit in the carbs.
    Whinging Courier, Apr 10, 2008
  16. sweller
    Chris H Guest
    <sigh>
    Piss in the tank.
    Chris H, Apr 10, 2008
  17. sweller
    TOG@Toil Guest
    The GT certainly does.
  18. Don't tell me really should've said "seriously"?
  19. sweller
    Slippers Guest
    What ?
    Slippers, Apr 10, 2008
  20. sweller
    Eddie Guest
    Boredom in the meme.
    Eddie, Apr 10, 2008
