leaky
Discussion in 'UK Motorcycles' started by darsy, Sep 20, 2004.
  1. darsy
    the 7r. Only a little bit of oil, but I suppose it's not a good sign.
    Certainly it's not loosing it at a rate that affects the sight guage,
    but over the weekend a little patch of oil appears - right under the
    middle of the bike.
    Any ideas what might be causing it (i.e. any known problems of this
    nature with Kwak 750s), or is it a case or taking the bodywork off,
    cleaning it up, and trying to see were oil is oozing out of?
    darsy, Sep 20, 2004
  2. darsy
    Been lubing your chain?
    platypus, Sep 20, 2004
  3. darsy
    dwb Guest
    Checked the sump plug?
    dwb, Sep 20, 2004
  4. darsy
    This is darsy here.
    Pip, Sep 20, 2004
  5. darsy
    Ditto, response to dweeb.
    Pip, Sep 20, 2004
  6. darsy
    yeah, before every ride, but with Castrol Chain Wax - the stuff on the
    floor is definitely engine oil.
    darsy, Sep 20, 2004
  7. darsy
    heh - I might well be a mechanical numpty, but oiling and adjusting the
    chain is one of the things I do actually do on a regular basis.
    darsy, Sep 20, 2004
  8. darsy
    Loosing? You should be ashamed.
    If it is really a tiny amount, I'd not worry about it - stick a bit of
    cardboard under it to keep the oil off your floor and enable
    assessment of the actual quantity. Let it develop a bit and then it
    should be easier to see where it is coming from.
    Or stick a Triumph badge on it and accept leakage as a fact of life.
    If you're really feeling keen - get the bodywork off, squirt the
    engine/gearbox/anything else that is oily with Jizer or Gunk, hose it
    off and let it dry, then run it up and see if you can spot it.
    The lazy man's way is a bit similar to fucking a fat bird ...
    Pip, Sep 20, 2004
  9. darsy
    **** that, man - get a Scottoiler in.
    Pip, Sep 20, 2004
  10. darsy
    dwb Guest
    <ashamed>
    dwb, Sep 20, 2004
  11. darsy
    Nah, OCD.
  12. Push rod oil seal just in front of the clutch. HTH
    eric the brave, Sep 20, 2004
  13. darsy
    push it where?
    darsy, Sep 20, 2004
  14. darsy
    porl Guest
    Hehe...mlwaaaaah
    porl, Sep 20, 2004
  15. darsy
    There's a few places where it could be coming from, but as describded
    by others, there's only one way to find out :
    - take the fairing lowers off
    - thoroughly degrease the engine
    - run the motor to warm up the oil
    - park it
    - wait.
    Possible candidates are:
    - sump plug (if so, this is a worry. You do not want it to come out
    while riding along. DAMHIK, IJK,OK?
    - clutch push rod oil seal - just above the gearbox sprocket. It's
    all hiddne behind a cover, so will look like it's coming from the
    chain/gearbox sprocket
    - Gearbox sprocker shaft
    - clutch cover
    - points [1] cover
    [1] of course, they're not points anymore, but everyone still seems to
    use this term.
    Champ, Sep 20, 2004
  16. darsy
    sounds complicated.
    more complicated. I'm guessing if the sump plug comes up when you're
    riding, it dumps all the oil over the rear shock/tyre, causing a
    brown-trouser moment?
    darsy, Sep 20, 2004
  17. darsy
    That's *exactly* what happens. On my first ZXR750 (in about 1989) it
    dumped the oil all over the rear tyre - I leant it into a gentle
    lefthander and the back just slide. Fortunately, as it slide, the
    bike leant over, moving the tyre contact patch sideways, to a bit of
    tyre that didn't have oil on it (the oil was a 2 inch wide stripe down
    the middle). So, I regained some traction, and corrected, but of
    course, as the bike came upright, it got onto the oily bit of the
    tyre, and now, with some momementum, it stepped out in the other
    direction.
    After 3 or four of these I found myself roughly upright, but on the
    wrong side of the road and heading for the kerb. Fortunately, there
    was a dip in the kerb at just the right place, which I rode up, and
    along the pavement for 50 yds before finally coming to rest.
    Champ, Sep 20, 2004
  18. darsy
    Ben Blaney Guest
    lucky ****.
    Ben Blaney, Sep 20, 2004
  19. darsy
    darsy, Sep 20, 2004
  20. darsy
    pity you're not as good a rider as some, as clearly the sensible action
    in the above circumstances would have been to pull a rolling stoppy
    until you came safely to rest.
    darsy, Sep 20, 2004
