Lean running and backfires on deceleration
Discussion in 'Motorcycle Technical Discussion' started by lubecki, Jan 26, 2006.
  1. lubecki
    lubecki Guest
    OK, so I know that a lean-running engine tends to backfire on a
    trailing throttle (under engine braking, when you close the throttle at
    speed). But I've been wondering - how does it happen? What exactly
    causes the backfire, and why does it only happen at closed throttle?
    Why on a lean-running engine? What exactly happens in the engine?
    Anyone know?
    -Gniewko
  2. There are always unburned hydrocarbons in your tailpipe. When you chop
    the throttle and running lean this means an excess of oxygen available
    for combustion in the exhaust stream. That + the localised hot spots
    inside the system ignite whatever fuel remains in the exhaust thereby
    making a popping noise on deccel. In and of itself this does not harm
    your engine, rather because it is an indication of lean and running so
    can burn your exhaust valves everyone thinks it to be a bad thing.
    Tuning your bike richer means an excess of fuel and very little to no
    oxygen. Thus the unburned fuel passes through the pipe without ever
    igniting. So you can think of the popping as a sort of environmental
    control on your bike, combusting excess fuel that would have otherwise
    not gotten burned.
    I have noticed on the T5 gen motors there is very poor efficiency.
    Tune them "right" for max power and they have a lot of unburned HCs in
    the exhaust stream. Japanese performance motors do not stink as badly
    as a properly tuned triple.
    Greek Shipping Magnets, Jan 26, 2006
  3. lubecki
    Alfred J. Guest
    Most riders probably wouldn't know much about the breakdown and
    disassociation of hydrocarbon fuel molecules during combustion, but
    almost everybody knows that all the fuel doesn't burn, some of it gets
    kicked out the exhaust pipe unburned and the EPA is against that ever
    happening, so manufacturers are going to fuel injection to stop the
    problem that carburetors have.
    Carburetors always suck some fuel through the idle circuits or around
    the tapered jet needle even if the throttle is closed, and that's a bad
    thing for air pollution and backfiring.
    But even fuel injected motorcycles could backfire on trailing throttle,
    if enough unburned mixture manages to recombine into burnable
    molecules. Honda investigated
    hydrocarbon recombination for a fuel-efficient 2-stroke they ran in the
    Dakar Ralley several years ago. It was a 400cc 2-stroke that got an
    amazing 40 miles per gallon when conventional 2-strokes only get 20
    mpg.
    So, whatever the fuel supply may be, carburetors or fuel injection, an
    engine has ways
    of getting a burnable mixture into the wrong part of the engine, i.e.,
    the exhaust pipe.
    Besides the unburned hydrocarbons in the exhaust pipe (it may take
    several revolutions of the engine for enough unburned mixture to build
    up), the backfire also requires an ignition source. This may or may not
    come from the spark plug, which may fire a waste spark during the valve
    overlap period on carbureted engines.
    This is less likely to be the case on fuel injected engines which would
    usually fire only one spark, and that spark would be on the compression
    stroke only.
    However, a source of ignition for backfiring could also come from a
    hot, glowing piece of carbon in the combustion chamber, or the ground
    electrode of the spark plug can glow hot enough to light off any
    mixture near it.
    Alfred J., Jan 26, 2006
  4. lubecki
    Tim Kreitz Guest
    Like any good sportbiker, the first thing I do whenever I buy a new
    motorcycle is to store away its portly, restrictive stock exhaust and
    install an aftermarket pipe. In the case of my ZX7R, the bike was
    already lean from the factory, and freeing-up the back pressure made it
    go even leaner, causing backfire on roll-offs. So I installed a BMC
    filter and a big, fat, Factory Pro jet kit.
    Doing so improved the bike's mid and high range performance
    dramatically, and it's actually slightly rich all the way through the
    rev range now. But you know what? It backfires just a bad as it ever
    did. Go figure.
    Cheers,
    Tim Kreitz
    2003 ZX7R
    2000 ZX6R
    DoD #2184
    http://www.timkreitz.com
    Tim Kreitz, Jan 26, 2006
  5. lubecki
    Hank Guest
    According to these folks, it's not excess oxygen that
    causes it, but unburned fuel. Also, the unburned fuel
    isn't ignited by hot spots in the in the exhaust system.
    Other than that, great reply!
    http://www.mikuni.com/tg_backfires_in_exhaust.html
    Backfires in Exhaust
    Note: It is normal for many high performance exhaust systems to
    moderately backfire or pop when the throttle is closed from
    mid-to-high rpm. In fact, one should expect a well-tuned high
    performance engine to "pop" and "crackle" when the throttle is
    closed at high rpm.
    The popping is a result of the air/fuel mixture becoming very lean
    when the throttle is closed and the engine is rotating well above idle
    speed. It is also necessary that the exhaust system have rather open
    mufflers.
    Why This (normally) Happens:
    1) When the throttle valve is in the idle position, fuel does not
    flow out of the main system (needle, needle jet, main jet). Fuel is
    only delivered to the engine by the pilot (idle) system.
    2) The combined effect of the closed throttle and elevated engine rpm
    is to create a fairly strong vacuum in the intake manifold. This
    vacuum, in turn, causes a high air flow rate through the small gap
    formed by the throttle valve and carburetor throat.
    3) Under these conditions the pilot (idle) system cannot deliver
    enough fuel to create a normal, combustible air/fuel ratio. The
    mixture becomes too lean to burn reliably in the combustion chamber.
    It gets sent into the exhaust system unburned and collects there.
    4) When the odd firing of the lean mixture does occur, it is sent,
    still burning, into the exhaust system where it sometimes ignites the
    raw mixture that has collected ---- the exhaust then pops or backfires.
    http://www.physics.byu.edu/research/energy/htm7.html
    Hank, Jan 26, 2006
  6. lubecki
    Alfred J. Guest
    One thing that should be pointed out is that while the throttle may be
    closed, leaning up the mixture, and it may take several revolutions of
    the engine to build up a burnable mixture in the pipe, the engine will
    still be running at a high enough RPM for the ignition advance curve to
    be advancing the ignition. So, if you have an ignition system that
    fires a waste spark, it's going to fire that spark during the valve
    overlap period on one of your four cylinders, and that's enough to make
    the exhaust backfire.
    Alfred J., Jan 27, 2006
  7. Angels and trumpets, Hankerstain is talking motorcycles!
    snip
    I used to subscribe to that theory. But it doesn't explain how EFI
    which can turn off the fuel completely on closed throttle still pops
    on deccel and yet the pops go away when you enrichen it. If anything
    making it richer should make it pop even more according to their
    theory.
    Ergo the only reasonable explanation is the free oxygen. Which there
    is lots of in a lean burn. I mean hello they use downstream oxygen
    sensors to determine stochiometric.
    Richer = too much fuel present to ignite and no popping even though
    you're dumping even more of it unburned into the exhaust. But the free
    oxygen is consumed. And shit don't burn in the absence of an oxidizer.
    Greek Shipping Magnets, Jan 27, 2006
  8. lubecki
    Zechariah985 Guest
    Conversely, oxygen doesn't oxidize anything without some kind of shit
    to oxidize.
    I know about what it takes to burn shit. I have actual experience
    burning shit at various rates, including sub-stoichmetric, stoichmetric
    and with excess oxygen. It's certainly a lot easier to do if you have
    the latter two conditions.
    Back to "backfires on deceleration":
    It's true that there are upper and lower limits of explosibility or
    burnability for hydrocarbon molecules. You can look up the LEL and UEL
    for various hydrocarbon gasses and see which ones have the widest
    range, but those tables are always for
    *gasses*, not for liquid hydrocarbon molecules which will disassociate
    under high temperature and then *recombine* as they cool, allowing the
    molecule that was once torn apart by heat to form again and be an
    acceptable fuel for the spark it finds if there is enough air to
    oxidize it.
    Zechariah985, Jan 27, 2006
  9. lubecki
    Hank Guest
    I talk bikes plenty of times, Demie! But they're
    not all I talk about. Life has so much to offer,
    so why limit our areas of interest?
    I suppose EFI can turn off fuel completely on closed
    throttle, but it doesn't. If it did, the engine wouldn't
    idle.
    Also, according to the explanation in the link,
    enriching the mixture makes the popping stop because
    the mixture is now rich enough to burn more completely
    during high rpm closed throttle operation. They say
    that an already lean mixure gets too lean to burn in
    the cylinders during high rpm closed throttle operation,
    so the unbrunt mixture doens't ignite until a bunch of
    it accumulates in the exhaust.
    I've gotta go with Mikuni's explanation over yours.
    Nice try, tho....
    Here's what happens to steel framed buildings exposed
    to raging infernos for hours on end.
    http://davesweb.cnchost.com/nwsltr69c.html
    On 9-11-01, WTC7, a 47 story steel framed building, which
    had only small, random fires, dropped in perfect symmetry
    at near free fall speed as in a perfectly executed controlled
    demolition.
    http://911research.wtc7.net/talks/wtc/videos.html
    http://wtc7.net/articles/FEMA/WTC_ch5.htm
    "You're doin' a heckuva job, Brownie!" - bu$h, a few days
    before his FEMA chief, Micheal Brown was forced to resign
    because of his gross incompetence.
    "The tools that enable Cuba to save lives and preserve
    human dignity during hurricanes are socialist values
    and organization." - Dr. W.T. Whitney Jr
    Ever wonder who benefits from the 150 MILLION
    U.S. taxpayer dollars spent each DAY in Iraq?
    http://www.commondreams.org/views04/0223-08.htm
    http://www.corpwatch.org/article.php?list=type&type=21
    "They are waging a campaign of murder and destruction. And
    there is no limit to the innocent lives they are willing to
    take... men with blind hatred and armed with lethal weapons
    who are capable of any atrocity... they respect no laws of
    warfare or morality."
    -bu$h describing his own illegal invasion of Iraq.
    http://www.robert-fisk.com/iraqwarvictims_mar2003.htm
    Hank, Jan 28, 2006
  10. lubecki
    Manjo Guest
    I hope this adds to the thread:
    My KAW Vulcan 1500-88 has twin Keihin CV carbs.
    Each carb has a pilot screw that meters fuel to the carb's slow or idle
    circuit.
    When I chop the throttle, the intake butterfly valve just behind the
    air filter closes and the main jet needle drops down to close off fuel
    flow from the main jet. The slow-idle circuit that has been flowing
    air-fuel to the engine since start-up is then the only circuit feeding
    the cylinder.
    All the carb'd Vulcan 1500's can have popping and backfires when
    chopping the throttle at high rpm's. The solution has been to turn OUT
    the pilot screw on each carb to INCREASE fuel flow to the slow/idle
    circuit. This works for all these bikes, with very few exceptions.
    There's also a coasting enricher on each carb that cuts air to the
    idle circuit on deceleration to decrease airflow to the circuit for a
    richer air-fuel idle mix.
    My theory (read:guess :) is that a too lean idle air-fuel mix has an
    uneven/partial burn in the combustion chamber. Unburned fuel makes its
    way into the exhaust pipes and is ignited by: a hot pipe; a hot carbon
    spot in the pipe; air leak into the exhaust pipe; and (my favorite :)
    all the above.
    Manjo
    Manjo, Jan 28, 2006
  11. Because not everything under the sun is interesting.
    I meant as you're coasting on closed throttle in gear. The fuel map
    obviously squirts gas in when the rpms are at idle but not necessarily
    if it's at 4,000rpm.
    Yeah but you can have an overly rich mixture which also puts loads of
    unburned HCs in the exhaust stream. And it doesn't pop. Why? The only
    explanation is a lack of available oxygen to complete the combustion.
    Mikuni is still talking carbs. Half of what they said doesn't even
    apply to EFI (like fuel metering on closed throttle).
    But I'm not surprised you seemingly latched onto one source of
    information and are clining to it as though your life depended on it!
    Greek Shipping Magnets, Jan 29, 2006
