left curves
Discussion in 'Australian Motorcycles' started by F Murtz, Jan 9, 2011.
  1. F Murtz
    F Murtz Guest
    Why do left leaning curves feel more comfortable than right.
    Is it just me or is it because the oncoming traffic is on the right.
    Even with no traffic it feels more comfortable leaning and curving left.
  2. F Murtz
    Minx Guest
    I agree. Sometimes I go a whole day without turning right. Meet the
    nicest people.
    Minx, Jan 9, 2011
  3. F Murtz
    Theo Bekkers Guest
    Yes I agree. I think partly because of what you say but also that when you
    are turning left the road camber is working with you. You require a larger
    angle of lean relative to the road surface to turn right. I suspect people
    ring on the right may have the opposite problem.
    Theo
    Theo Bekkers, Jan 9, 2011
  4. F Murtz
    Theo Bekkers Guest
    Don't join the Liberal Party then. Then again, most Politicians of all
    parties go around and around and around.
    Theo
  5. Looks like a rational explanation. Are there any readers of this group who
    ride in a country where the traffic drives on the right who can comment?
    Lone Haranguer, Jan 9, 2011
  6. F Murtz
    Peter Guest
    Might it have something to do with one testy/breast being larger than the
    other.
    Maybe dressing to the right might help.
    :p
    Peter, Jan 9, 2011
  7. In aus.motorcycles on Sun, 9 Jan 2011 18:57:22 +1100
    It was an FAQ in wreck.moto I think. Dunno it ever made it to the
    FAQ but it used to get discussed a lot.
    And it's often asked in superbike school too.
    My understanding is that camber isn't the answer, that people who ride
    on the right side of the road feel lefts are easier too.
    The Superbike school explanation is that a right hander means you are
    countersteering with your throttle hand and this makes it much harder
    to be smooth and you put in unwanted steering inputs that make the
    bike feel worse. Plus it is instinctive not to want to put that force
    through the throttle hand.
    That it isn't camber is shown by the fact most people feel the same
    way on a racetrack when they can use all the track.
    That it isn't the feel of oncoming traffic is shown on the track, and
    in countries that drive on the right feel the same thing.
    So the throttle hand explanation seems the most sensible so far.
    Zebee
    Zebee Johnstone, Jan 9, 2011
  8. That's it. The effect is multiplied on dirt roads.
    - soakes
    Stephen Oakes, Jan 9, 2011
  9. F Murtz
    F Murtz Guest
    So at least I am not the only one.Even if I don't know why, still
    ,food for thought.
  10. F Murtz
    TimC Guest
    Going left, if you screw up, you go into the right hand lane, which
    you might be lucky enough to get away with, particularly out bush.
    But if you screw up going right, you will more likely find yourself
    plunging down the hillside. That's if you're like me and do all your
    riding out bush. Plus, going right, you might be tempted to lean your
    head into oncoming traffic. If you want to allow your head margin for
    error, then you'll be using less of the lane, which gives you even
    less room to screw up - going left, it's not usually a problem if your
    head sticks out past the gutter, so psychologically, you allow
    yourself to use more of the lane.
    Cue the time I headed down the mountain after work, and took the
    ungaurded sweeping right hander on my bicycle at 60km/h when a bump
    upset me and I ended up travelling down a 20cm wide gravel patch for
    50metres, trying desperately not to do anything that might cause me to
    slide out and fall off the cliff. No, brakes didn't seem to be an
    option. A couple of harleys rounded the corner and would have been in
    the prime position to see me fly off the side had I not gracefully
    gotten back onto the tarmac just when I did. I don't like that
    paricular corner on any of my bikes. There's crap on the other side
    of the road that causes cars to want to pull into your lane too.
    TimC, Jan 9, 2011
  11. F Murtz
    Theo Bekkers Guest
    That's very interesting indeed Zebee.
    Theo
  12. F Murtz
    G-S Guest
    I too find rights (when hurrying along) more work and harder to get
    correct than lefts.
    Zebee's explanation is the first one that really makes sense!
    G-S
    G-S, Jan 9, 2011
  13. I disagree Geoff
    With a left hander, you are working against the camber and with a right
    hander, you are going with the camber, or whichever term you wish to use
    Take any racetrack for instance, with banking, the higher the banking, or
    positive camber, the faster you can go, then try doing the same speed, or
    even three quarters of that speed on a negative camber road and you will
    tend to slip, or seem to slip away, making you go slower
    George W Frost, Jan 9, 2011
  14. Didn't we have a long thread on this about ten years ago?
    I don't recall any definitive answer, but we did get responses from
    riders who were on the other side of the road and it was still that
    left turns are more comfortable. So your throttle theory seems to be
    as good as any.
    I recall making a comment back then that hooking into a right-hander
    puts your head closer to possible oncoming traffic and you feel
    uncomfortable, but that doesn't work if you are riding in the right
    lane.
    Kevin Gleeson, Jan 10, 2011
  15. F Murtz
    Barry Taylor Guest
    "George W Frost" wrote in message
    I disagree George - either the roads you navigate are on a different planet
    or your definition/understanding of camber differs from that which is
    common on planet Earth.
    the only racetrack I have ridden is PI. and there the banking rises to the
    right
    for left hand corners (just like the camber on most roads I have experienced
    albeit not so pronounced)
    and for right hand corners the banking rises to the
    left - which is the exact opposite of what occurs on the open road when
    cornering right from the left hand lane across the crown of the road
    I'll report back later on this year after I have ridden the TT course
    on the Isle of Man if things are different in the Northern Hemisphere
    a friendly growl from the bear on the Zephyr that roars
    __ __ __ _ __
    /__/ / /__/ /_ /_\ /_ /
    /_ /_ / /__/ /__ / \ / \ ....Kawasaki Zephyr
    barry j taylor < >
    ~~~ ~ _@
    ~~ ~ _- \,
    ~~ (*)/ (*) . . . bjbear on his treadly
    Barry Taylor, Jan 10, 2011
  16. Make sure you don't mix up camber and banking. Camber is going to make
    no difference whether you are riding on the left or right side of the
    road. It is going to make a difference if you are meant to be on the
    other side of the road, be it left or right. But that doesn't explain
    why right hand road riders still feel better in a left hand turn. I
    think Zebee has got possibly the closest explanation yet.
  17. I thought the same thing as you on that point
    George W Frost, Jan 10, 2011
  18. F Murtz
    Nev.. Guest
    I've always felt the opposite. Right curves are easier than left.
    They're wider and longer so you can carry more speed, owing to that
    they're more forgiving if you're carrying too much speed. Making an
    error on a left hander sends you into the oncoming lane whereas on a
    right hander you're likely to stay out of the oncoming traffic.
    Oncoming traffic is more likely to cross the centre line when you're on
    a left hander than a right hander, although you're more likely to cross
    the centre line on a right hander than a left hander if you choose a
    poor line.
    I rode about 40% of my total bike mileage for 2010 in the USA and once i
    was used to riding on the other side of the road I didn't feel any more
    or less preference to riding bends in either direction. The only
    hesitation I had was with left bends, but only because when I was
    looking through the corner, it seemed like oncoming vehicles were taking
    very wide lines and running onto my riding line but I'm sure that was
    just an optical illusion while my brain adjusted to seeing situations in
    reverse, because when i got to the apex of the corner I did not feel
    that was the case at all.
    Nev..
    Nev.., Jan 10, 2011
  19. F Murtz
    Nev.. Guest
    Oh goodness gratious no! There is definitely no problem with the
    throttle on my Royal Enfield when i am going to get some chutney for my
    chapati, good Sir!
    Nev..
    Nev.., Jan 10, 2011
  20. F Murtz
    Marty H Guest
    but I feel the same way on a push bike....
    left or right handed (as in which side of the brain you use) have any
    impact?
    mh
    Marty H, Jan 10, 2011
