Looking for an ID pass holder
Discussion in 'UK Motorcycles' started by Chris, Sep 16, 2006.
  1. Chris
    Chris Guest
    I've drawn a total blank on this so it's time to pick the collective
    brains of UKRM.
    I have started working at a company that checks ID passes on the entry
    gate. Trouble is how do I keep it handy for inspection? I've tried two
    techniques so far, neither ideal:
    - on neckchain. Will get draughty having to unzip my leathers as winter
    rolls in. Plus doing them up again could be difficult on the move[1]
    - in tankbag. Two fumbles in 3 weeks even with summer gloves...
    A suggestion from one of the other guys was to sew the holder onto the
    arm of the jacket - but he has textile gear, and I really don't want to
    do that to a decent set of leathers....but it got me thinking....
    ....is there some sort of passholder gizmo on the market that I could
    use? An arm-mounted ski pass holder or something?
    Anyone got any suggestions?
    <thinks about the typical UKRM responses>
    let me rephrase that....
    "Anyone got any *sensible* suggestions" ;-)
    Failing that, I guess it's a case of carrying it in the top of the
    tankbag, and making sure the pass is firmly tied on for when I drop the
    damned thing!
    [1]They seem to be shrinking this year. Must be the hot weather we've
    had, or something....
    Chris, Sep 16, 2006
  2. Chris
    Eddie Guest
    < snip >
    If you come up with any bright ideas, let me know.
    Our car park is protected by those rising ramps. During normal working
    hours they're left down all the time, but at other times you're meant to
    wave your pass at the detector so you can get in.
    Sod that, when there's an easy way to ride onto the pavement and get
    round it. Nobody around, so I don't see what the problem is.
    Just about to walk into the building, when there's an announcement on
    the outside tannoy: "This is security. Do you think you could manage to
    use the roadway in future?"
    Yeah, right.
    Eddie, Sep 16, 2006
  3. Chris
    Velcro it onto the tankbag if you always use the tankbag.
    Andy Bonwick, Sep 16, 2006
  4. Chris
    Tosspot Guest
    Tosspot, Sep 16, 2006
  5. I wouldn't trust it to still be attached by the time I got to work -
    however, you could use something like that attached to the inside of
    tank bag pocket. That way if you do drop it, no fumbling needed.
    Dnc
    B12, ZZR11
    A6 2.5TDi V6 Quattro Sport
    DoetNietComputeren, Sep 16, 2006
  6. Chris
    Chris Guest
    Chris, Sep 16, 2006
  7. Chris
    Chris Guest
    Slight problem...no map pocket. But thanks for the suggestion.
    Chris, Sep 16, 2006
  8. Chris
    Cab Guest
    Buy one with a map pocket. Problem sorted.
    Cab, Sep 16, 2006
  9. Chris
    Gyp Guest
    Stop.
    Unzip leather
    Get pass out
    Show pass
    Put pass away
    Re-zip leather
    Drive off
    No problem
    The best solution to this I've found was when I used to wear a Belstaff
    waxed cotton oversuit [1]; the pass was round the neck, tucked into the
    outside top pocket; on arrival at work I popped the push-studs with one
    tug and pulled the pass out with the chain with a second tug.
    [1] Do they still make them? I'm starting to think that wearing waxed
    cotton is a good idea.
    Gyp, Sep 16, 2006
  10. Chris
    Colin Irvine Guest
    There is at least one arm-mounted ski pass holder on the market, 'cos
    I have one. The elastic's a bit worn, otherwise you'd be welcome to it
    as I never use it. Try a ski or mountain sport shop.
    Colin Irvine, Sep 16, 2006
  11. Chris
    I used to keep the garage door opener in a chest pocket. I'd give the
    button a poke as I came round the corner and the door would be open when I
    reached it. Great in the rain.
    ....until it catches fire.
    platypus, Sep 16, 2006
  12. Chris
    Gyp Guest
    A risk I'm willing to take
    Gyp, Sep 17, 2006
  13. Chris
    Yupp. Prolly got a couple of these hanging around somewher, although
    my ability to go rooting around in the loft is a little limited at the
    moment.
    Basically it's just a plastic envelope with an elastic strap.
    Thankfully most ski resorts are electronic now, so this sort of thing
    is not required. The danger of them being that if you leave it on the
    jacket and take the jacket off, hanging it, say, on your chair in a
    mountain restaurant, you're quite likely to lose the whole thing.
    Quite embarassing going back to the lift company office and getting a
    replacement pass, when it was free in the first place ;-)
    I usually[1] shove it, on its neck-strap, into the pocket of my
    tankbag. Quite easy to get out by just grabbing the strap and pulling.
    [1] Add past tense as required.
    _______
    Ace, Sep 17, 2006
  14. Chris
    Adie Guest
    we have the same thing. I put mine in the map pocket. I'm going to ask
    for a spare unusable card [1] so that I can still leave it round me
    neck but still get on site.
    [1] ie a card that wont get me in through the electronic turnstile but
    has the pic on it.
    Adie
    Triumph ZX9R / GSF1200 bandit (for sale) / CG125
    keeper of the FAQ for my sins
    Adie, Sep 17, 2006
  15. Chris wrote
    I have followed the thread and as yet no one has suggested that you
    should treat this in the same way as you should treat toll collection
    for bikes.
    Bury what they need to see as deep as you can inside your protective
    clothing and make the cunts behind you wait patiently in the queue while
    you fish it out and put it all back again neat and tidy. It will
    actually take you less than a minute to do all this but it will cause
    such disruption and chaos at the barrier that eventually they will find
    a way to remove you from the queue and allow you to ride through
    unimpeded.
    steve auvache, Sep 17, 2006
  16. As it's a security gate, I doubt they will. More likely they'll let a
    queue form behind you, or have you move to one side.
    Dnc
    B12, ZZR11
    DoetNietComputeren, Sep 17, 2006
  17. DoetNietComputeren wrote
    The whole point is to have a queue form and get other people to do your
    complaining. Moving you to one side is discrimination and gives you
    good reason to complain.
  18. Chris
    Chris Guest
    Chris, Sep 17, 2006
  19. I did that at Motorola in Swindon (the old site) - the side gate to the
    car park was controlled by ID badge but there was an always-open
    pedestrian gate by it.
    I always used to ride through the pedestrian gate until Security made a
    formal complaint to my manager about it. Apparently I was
    "circumventing site security". I pointed out that they knew who I was,
    knew where I parked my bike (in the bike area surprisingly) and knew
    who my manager was so obviously it wasn't that much of a problem..
    That was the start of my feud with security at Motorola..
    Phil
    Phil Launchbury, Sep 19, 2006
  20. Chris
    Eddie Guest
    I suspect their main objection here will be that I shouldn't be riding
    on the pavement, rather than any security issue.
    I /think/ I can stay on the road and squeeze past the rising ramp, so
    I'm going to give that a shot next time. Watch out for the "ZX-9R
    Fairing Repair" post...
    I've already got a hefty document drafted in case things escalate.
    Eddie, Sep 19, 2006
