M6 Toll Road - Part 2
Discussion in 'UK Motorcycles' started by Benny, Jul 16, 2005.
  1. Benny
    Benny Guest
    Used the road on the way up to the Lakes, first impression was a nice road,
    sorry a nice "fast" road.
    Couldn't really welly it because of the tank bag and backpack, and saved 29
    miles off the journey.
    Now, on the way back, no tank bag and backpack, bloody hell, I could easily
    seen how fast the gixxer went as there was next to no traffic but
    unfortunately I had to stop for fuel and when I got out, there was more
    traffic, so didn't carry on.
    Would I use it again? Yes, because of the milage saved and that I didn't
    have to look at Brum, otherwise I would probably have to stop twice to fill
    up.
    Benny, Jul 16, 2005
  2. Benny
    Andy Hewitt Guest
    I find that amazing, if you look at a map, it's impossible to see where
    you'd save that. Both sections of the M6 there look about the same
    length.
    Andy Hewitt, Jul 16, 2005
  3. Benny
    Dr Zoidberg Guest
    Agreed. I think it's only a couple of miles difference , and certainly not
    29.
    It's the time saved rather than the distance that makes it worthwhile (if I
    can claim it on expenses)
    Alex
    www.drzoidberg.co.uk
    www.sffh.co.uk
    www.ebayfaq.co.uk
    Dr Zoidberg, Jul 16, 2005
  4. Benny
    Christofire Guest
    A local (to the area) lurker emailed me and told me it's actually
    longer than the M6 route.
    I think they're both the same, to within a mile.
    M6 Toll to M6 Toll on the M6 is 28 miles according to:
    http://www.cbrd.co.uk/motorway/6.shtml
    M6 Toll end to end is 27 miles according to:
    http://www.cbrd.co.uk/motorway/6toll.shtml
    Either which way, I think the OP has failed to take into account that
    if the original route is 28 miles and his new route is 27 miles then he
    saves a mile, not 29 miles.
    <belms>
    Christofire, Jul 16, 2005
  5. Benny
    Benny Guest
    I took a slight detour than normal on the M25 (compared to way up) on the
    way home, and the milage was 311 (at home). Normally without toll road it is
    330.[1]
    [1] Done this trip many times over 15 years.
    Benny, Jul 16, 2005
  6. Benny
    Andy Hewitt Guest
    So that's 19 miles anyway. And obviously not all in the Toll section
    then? :)
  7. Benny
    riccip Guest
    Per mile it's the most expensive toll road in Europe.
    riccip
    riccip, Jul 16, 2005
  8. Using the patented Mavis Beacon "Hunt&Peck" Technique, riccip
    Disgusting. If the toll was set directly from Brussels, we'd be much
    better off.
    and Ducati Race Engineer.
    Enfield 500 Curry House Racer "The Basmati Rice Burner",
    Wicked Uncle Nigel, Jul 16, 2005
  9. Benny
    Eiron Guest
    I used the old M6 through Brum twice yesterday and saved seven pounds.
    The toll road doesn't save any miles at all.
    The matrix signs need some interpretation.
    "Toll road clear" means that the old road is clear.
    "M6 congestion between J4 and J5" means that you might slow down a bit
    but it will only delay you by a minute.
    Eiron, Jul 16, 2005
  10. Benny
    riccip Guest
    Apparently our Brussels masters are applying pressure to force
    the M6 toll into line. At last! I might see something back for
    the £252 my household pays directly into EU coffers every year.
    But hang on. The EU wants to "regulate" our tolls, so the
    Dartford Crossing, which I use more often, would go up.
    riccip
  11. Using the patented Mavis Beacon "Hunt&Peck" Technique, riccip
    <examines keepnet>
    Yeuch!
    <throws it back>
  12. Benny
    riccip Guest
    Same here. Tried it once for novelty and that's it.
    On two wheels there's never much delay. On four it's just during
    rush hours. Those "congestion" signs are switched on almost
    permanently during daylight hours, even when there's no delay
    whatsoever. Even the road layout is carefully designed to funnel
    you directly onto the toll road unless you keep your wits about
    you. As a consequence you see some dangerous swerving back onto
    the M6 when drivers suddenly realise what's happening.
    riccip
  13. Benny
    PeterT@Home Guest
    Benny proposed
    You didn't leave that tank bag on a bus in London though, did you?
    PeterT@Home, Jul 17, 2005
  14. Benny
    riccip Guest
    Just to add that Brussels is insisting VAT be levied on all
    tolls, backed by the European Court (no surprise there).
    Currently British toll charges for roads and bridges are not
    subject to VAT. However, when the EU VAT-model is adopted it now
    seems certain that VAT would have to be put on all charges
    (including the London Congestion charge). Not only that but also
    the EU is demanding that these taxes should be passed to Brussels
    retrospectively for the last 6 years plus interest (a second
    report suggests 4 years).
    The London Congestion charge would become £5.87 with VAT
    (commuters will pay an extra £209 pounds annually). Remember also
    that the "success" of the LCC means it will be spreading to
    cities across the country over the next few years so with VAT you
    can expect fees of around £1500 p/a for the privilege of getting
    to work.
    The M6 Toll Road, the Severn and Forth bridges, the Saltash
    bridge, and the Dartford Crossing will all be affected. In
    Dartford's case 50 million vehicles a year use it and 6 (or 4)
    years back-tax on that lot will be hefty sum running into
    £££-billions. The Humber bridge which is barely viable would
    probably face financial disaster and if charges were passed on to
    motorists this would mean that the increase would fall foul of
    British law which limits increases in tolls to the rate of
    inflation.
    Should that occur it's possible the European Court might rule in
    Britain's favour but on past experience don't hold yer breath!
    riccip
    riccip, Jul 17, 2005
  15. Benny
    frag Guest
    riccip scribbled:
    But its a very nice road. Bugger all traffic on it, no bloody
    roadworks, traffic jams or Birmingham. Winner all round!
    And the £3.50 or £2.50 toll if you use it late, is peanuts really.
    frag, Jul 17, 2005
  16. Benny
    frag Guest
    riccip scribbled:
    So we'll really see a return on that investment then...
    Should never have built the bleeding Channel Tunnel, what good is
    Europe for apart from getting to other places through it?
    frag, Jul 17, 2005
  17. Benny
    frag Guest
    tallbloke scribbled:
    I don't think they are. When I went up it I never saw 1 using it (must
    have been many 100s in the equivalent M6 stretch). On way back I saw 1!
    frag, Jul 17, 2005
  18. Benny
    tallbloke Guest
    Maybe just at peak times when the M6 is chokka.
    tallbloke, Jul 18, 2005
  19. Benny
    zymurgy Guest
    Or the complete and utter doughnut who parked on the white lines
    deciding which road to take. Then proceeded to pull back into the lane
    I was hemmed in on. In a great gurt white van. Cue much skidding,
    flashing of headlights and copious horn.
    Cheers
    Paul.
    zymurgy, Jul 18, 2005
  20. Benny
    riccip Guest
    Shite, makes you mad when that happens but you come to expect it
    in that area after a few hairy moments. As you know the majority
    M6 through-traffic is shoe-horned into 2 lanes while 3 virtually
    empty lanes run to the toll booths. Ridiculous.
    http://tinyurl.com/du6qh
    They *should* have done it so there's a slip road to opt for the
    toll road, but then even less ppl would use it. Why should they
    worry about a silly thing like motorway safety?
    riccip
    riccip, Jul 18, 2005
