Magneti-Marelli Fuel Injection questions....
Discussion in 'Motorcycle Racing' started by Dave, Aug 12, 2005.
  1. Dave
    Dave Guest
    I am trying to figure out the theory for syncing and timing a bike (MV
    Agusta F4) with Marelli IAW16M ECU (the one with the big plug for EPROM
    change and fuel trim trimpot.) I have the workshop manual and the engine
    manual, but they are internally inconsistent and contradictory.
    As I see it, there are 2 separate objectives - balance and mixture.
    The air bleed screw seems to affect both balance and mixture. since it adds
    more or less air for the same throttle position sensed.
    The throttle linkage adjustments do the same, since there is only one TPS.
    My bike only has one CO spigot on the pipes, so there is no way (that I know
    of) to read CO of a particular cylinder.
    So it seems like you could have 1 cyl relatively rich and another one
    relatively lean, and the reading might average out and look OK.
    Is this where sync comes in? I suppose the theory is to tune for equal
    vacuum 1st, then adjust CO and assume that equal vacuum=equal mixture.
    On my bike, cyl 1 pulls more vacuum at 2000-3000RPM than 2-3-4 do, even
    after balancing vacuum at idle. If I try to compensate by opening the bleed
    screw, it seems like I risk leaning out that cylinder (more air, less gas)
    So I suppose I need to figure out why that cylinder pulls more vacuum. I
    suppose the intake valve might need a shorter shim. if it were shimmed too
    much, I suppose that might yield more intake duration and thus more vacuum?
    I understand how to do all the adjustments at idle, but not how to know if
    things are OK at higher RPM, where it really matters. My understanding id
    the ECU diagnostic software (which I don't have) can adjust fuel trim as
    a percentage, vs. the fixed time adder of the trimpot.
    Any wisdom would be welcome. There are no dealers in my area, so this is
    going to have to be DIY. I have a gastester and a mercury manometer.
    Dave, Aug 12, 2005
  2. Dave
    auscars Guest
    You need to speak to Dwain at Ocean Grove in Victoria Australia
    He cracked all the electronic codes on all the Italian bikes with
    interface etc
    Glad to have helped
    [Contact him via the MV Agusta Forum, Google is your friend!]
    auscars, Aug 12, 2005
