Mechanical aptitude test
Discussion in 'UK Motorcycles' started by AndrewR, Oct 11, 2007.
  1. AndrewR
    AndrewR Guest
    Stolen from a Fiat Coupe forum poster, who stole it from a Peugeot 205GTi
    forum, who ... well, you get the gist, it's doing the rounds, but I don't
    think it's been here yet.
    A test on basic mechanical principles (which made 'O' level physics seem a
    very long way away)
    The pass mark is 80% - I'm a fuckwit with anything mechanical and got 66%,
    so anybody lower than that should feel very bad indeed.
    Complaints on coupe forum suggest that one of the answers near the end is
    wrong, so beware.
    http://www.forddoctorsdts.com/quizzes/MechanicalAptitude.php
    AndrewR, D.Bot (Celeritas)
    Aprilia RSV-1000R, Kawasaki ZX-6R, Fiat Coupe 20v Turbo
    The speccy Geordie twat.
  2. AndrewR
    geoff Guest
    Whatever ...86%
    I'd prolly do better if I wasn't a bit pissed
    geoff, Oct 11, 2007
  3. AndrewR
    I'm just glad there were a few electrical questions.
    I knew there was a reason I delegate to a man
    Turin Brakes sum up my score...Emergency 72
    seventy two...seventy two...seventy two...
    wessie, Oct 11, 2007
  4. AndrewR
    Colin Irvine Guest
    Took about 10 mins - 88%.
    Colin Irvine, Oct 11, 2007
  5. 76% .... and I am quite trolleyed, but did finish 2nd in a sports quiz
    tonight - woot !
    Brownz \(Mobile\), Oct 11, 2007
  6. AndrewR
    Now, now. You've got 6 days left to get your head around this mechanical
    shit.
  7. AndrewR
    Iridium Guest
    Lost the will to live after about 8 questions. I like to think I'd have got
    more than 50% though heh.
    Iridium, Oct 11, 2007
  8. AndrewR
    86% (430 points), after 3/4 of a bottle of Chianti Classico Riserva.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    Krusty, Oct 11, 2007
  9. AndrewR
    470 points, 94%. Can't be that difficult.
    platypus, Oct 11, 2007
  10. AndrewR
    Paul - xxx Guest
    92% Could have done better if I had been awake.
    Paul - xxx, Oct 11, 2007
  11. 74%. Oops.
    The Older Gentleman, Oct 11, 2007
  12. AndrewR
    AndrewR Guest
    Question 48, about why air enters a normally aspirated engine.
    The quiz has the correct answer as being "suction from the piston going
    down", but "atmospheric pressure" is a better answer it has been argued.
  13. AndrewR
    AndrewR Guest
    Ah well, you see, I did it sober and got 66% and then did it again last
    night, after I'd had a few (but without gaining any additional knowledge)
    and got 78%.
  14. AndrewR
    Pete Fisher Guest
    400 points = 80% in the cold early light. I found the cog gearing and
    pulley leverage questions the hardest.
    | Pete Fisher at Home: |
    Pete Fisher, Oct 11, 2007
  15. AndrewR
    cat Guest
    410 points 82%
    I should have concentrated that hard at school :/
    I agree that on the induction question that the air moves because
    atmospheric pressure is higher than the pressure in the cylinder. This
    *sucking* thing is a load of crap.
    cat, Oct 11, 2007
  16. AndrewR
    Rich B Guest
    Is the correct answer. The descending piston creates a partial vacuum
    in the cylinder, but it's the atmospheric pressure (now greater than
    the pressure in the cylinder) that pushes the air in. That's the
    "physics" answer, I guess. The "mechanics" answer is that as long as
    the air gets in there, who gives a flying **** whether it's blown or
    sucked.
    As it were.
    92% - but a lot of it you could get by common sense and doing a lot of
    twirly movements with your fingers on the screen.
    Rich B, Oct 11, 2007
  17. AndrewR
    Gyp Guest
    88%
    I would have argues that the later question with the big fulcrum in the
    middle was incorrect as there was only a viable answer if you took it
    that the force was acting at the extreme edge of the mass not the centre
    Gyp, Oct 11, 2007
  18. Cog gearing was easy for me - pulleys are a closed book to me, and I'm
    crap with electrickery as well.
  19. AndrewR
    CT, Oct 11, 2007
  20. AndrewR
    Passed with 82%. I rock.
    ogden, Oct 11, 2007
