mechanical f'wit award
Discussion in 'UK Motorcycles' started by Simon Wilson, Jun 24, 2008.
  1. Simon Wilson
    Simon Wilson Guest
    I probably deserve one.
    I've been working on an old three cylinder diesel engine, what was
    smoking somewhat. Having been pretty pleased with my progresss so
    far[1], I got a bit more adventurous. Although it was no longer emitting
    huge great clouds of white smoke , there was still quite a lot of blue
    smoke and heavy breathing from the rocker cover. 'Valve seals' I
    thought, and ordered some up. As the valve springs are relatively light
    and quite easy to compress them without any special tool, I thought I'd
    do it without taking the head off. First cylinder at tdc, change both
    seals without any losing anything across the garage floor or down inside
    the engine. Result. This is going to be quite easy. Second cylinder, I
    had a bit more trouble, pressing the spring down took the valve with it.
    Judicious use of the starter motor[3] and I got cylinder 2 at TDC. Valve
    spring off, valve seal off and... the valve dropped down a bit. No
    worries, the piston will stop it any second now won't it? Won't it? For
    some reason I just watched it, didn't reach out to grab it, as the valve
    disappeared all the way down and I heard it tip over as it hit the piston.
    Now I've got the take the whole head off to get it out. I took the
    injector out to see if I could see the valve through there and somehow
    jiggle it about, but no luck.
    arse, *arse*, *ARSE*
    [1] refurbished injectors and properly adjusted valve clearances[2]
    [2] valve clearance was about -0.25" on one cylinder
    [3] turning the crank by hand needed a lot more disassembly
  2. You're only going to have to do what yo know you should've done in the
    first place ;-)
    BTDT.
    Whinging Courier, Jun 24, 2008
  3. Simon Wilson
    zymurgy Guest
    Oh nice [1]. What is it off / connected to ?
    You know that it wasn't at TDC then, don't you ;)
    Top tip here if you don't have an air compressor and adaptor holding
    the valve closed is to put a length of soft rope down the injector
    hole to hold the valve in place. [2]
    P.
    [1] Is there such a thing as a 'dieselhead' ?
    [2] When it's at TDC, that is (!)
    zymurgy, Jun 24, 2008
  4. Simon Wilson
    Simon Wilson Guest
    A Kubota compact tractor
    Do now, yes :(
    I knew this.
  5. Simon Wilson
    gazz Guest
    So whilst you have the head off, you may as well whip the sump off and take
    the pistons out to replace the rings, or say **** it and fit new pistons and
    liners, and whilst you have the pistons out you may as well replace the big
    end bearings, be silly not to do the main bearings at the same time, as well
    as the oil pump, water pump wont go amiss and so on....
    or is that just me who ends up doing things like that? :)
    gazz, Jun 25, 2008
  6. Simon Wilson
    Simon Wilson Guest
    Nope, not just you. Water pump bits[1] are on order. Also valve guides.
    I have thought about doing the rings/deglaze too, but the sump looks
    like a PITA to get at.
    [1]Surprisingly, several spares are available for the pump, including
    bearings, seal etc.
    Simon Wilson, Jun 25, 2008
  7. Simon Wilson
    zymurgy Guest
    Ah, ok. I was thinking maybe a boat.
    If you come across a small diesel, let me know, as i've always
    hankered after putting one in a bike. I also happen to have about 3
    CB250N rolling frames it would go in (!)
    Thinking about it, this would work only for a DI, or a petrol engine,
    where you have direct access to the CC.
    Cheers,
    Paul.
    zymurgy, Jun 25, 2008
  8. You sick, sick puppy. I recommend you get treatment asap at your local
    two-wheeled recovery centre.
    Phil
    Phil Launchbury, Jun 25, 2008
  9. I recommend the 3-cyl Daihatsu 1L turbo lump and put it in a modified
    Beemer frame, using the Beemer box. 60bhp and a similar rev range, so
    performance is about the same as standard.
    GS850x2 XS650 SE6a
    "It's a moron working with power tools.
    How much more suspenseful can you get?"
    - House
    Grimly Curmudgeon, Jun 25, 2008
  10. Simon Wilson
    zymurgy Guest
    Haha, I'm either carrying on a great British tradition of
    eccentricity, or i'm looking at new and wonderful ways of scaring
    myself silly. Probably both.
    Cheers,
    Paul.
  11. Simon Wilson
    crn Guest
    Why bother contrapting one, just import one from India.
    ISTR they use a Kobutu engine in an Enfield frame. But ICBW.
    Maybe one of the importers is bringing them in already ?.
    crn, Jun 25, 2008
  12. Simon Wilson
    Because he can, obviously.
    v you the point v
    _______
    Ace, Jun 25, 2008
  13. Simon Wilson
    zymurgy Guest
    Well, even if I can't molish it enough together to work properly, it
    could moulder in some corner of the garage as a monument to (one) mans
    stupidity.
    P.
  14. Simon Wilson
    snip>
    Can I interest you in a Wessex sidecar? Very rare, apparently quite
    desirable and much cheapness to anyone I know.
    Andy Bonwick, Jun 25, 2008
  15. Dreadful thing.
    GS850x2 XS650 SE6a
    - House
    Grimly Curmudgeon, Jun 26, 2008
  16. Simon Wilson
    Dan L Guest
    A few years back myco were changing the unit what keeps the inflatable
    dome up at Ealing lawn tennis club.
    The old unit had a hardly used Hatz diesel engine in it, which was
    unbolted and removed to save weight. If there had been enough room in
    the boot of my Golf I'd have had it, but as there wasn't it went to the
    scrapyard.
    Dan L
    Too much time to think, too little to do.
    http://thebikeshed.spaces.live.com/
    2002 Triumph Sprint RS 955i (It's big, and it's black)
    1996 Kawasaki ZR1100 Zephyr (Gone, but not forgotten)
    BOTAFOT #140 (KotL 2005/6/7/8)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Jun 28, 2008
