Meteor alert
Discussion in 'UK Motorcycles' started by SIRPip, Aug 12, 2010.
  1. SIRPip
    Jim Guest
    $ is 7 bit safe
    £ is not
    Jim, Aug 13, 2010
    #41
  2. SIRPip
    prawn Guest
    This. Though WTF he uses UKP is beyond me. ISO 4217 is your friend.
    prawn, Aug 13, 2010
    #42
  3. SIRPip
    Cab Guest
    Nah, that's the other one.
    Cab, Aug 13, 2010
    #43
  4. SIRPip
    Salad Dodger Guest
    Fortnight.
    Salad Dodger, Aug 13, 2010
    #44
  5. SIRPip
    SIRPip Guest
    You've got your work cut out there, big fella.
    SIRPip, Aug 13, 2010
    #45
  6. SIRPip
    SIRPip Guest
    Count me as educated.
    Well, exactly.
    I'm not sure he knows that. I don't ;-)
    #46
  7. SIRPip
    Snowleopard Guest
    On Fri, 13 Aug 2010 07:26:04 +0000 (UTC), "SIRPip"
    Ah.. now I wear mine back-to-front with the extra material over my
    head for that sort of thing.
    Or Star Wars parties.
    Snowleopard, Aug 13, 2010
    #47
  8. SIRPip
    Snowleopard Guest
    On Fri, 13 Aug 2010 01:37:29 +0100, Salad Dodger
    You are!
    Do they both build up huge amounts of static and zap everything in
    sight?
    #48
  9. SIRPip
    petrolcan Guest
    I made a post at 5am once. Beat that!
    petrolcan, Aug 13, 2010
    #49
  10. SIRPip
    Salad Dodger Guest
    The gite side is fine, and new.
    There are only <counts> 23 casement-type windows to do.
    I imagine I'll be let off on parole if I do the upstairs ones.
    #50
  11. SIRPip
    Salad Dodger Guest
    Snowy, they're actual sisters, not euphemistic ones.
    I can't envisage a scenario where they'd rub against each other to a
    sufficient degree.
    #51
  12. SIRPip
    Snowleopard Guest
    On Fri, 13 Aug 2010 21:04:08 +0100, Salad Dodger
    Heh - that's your mind, not mine - I find I create huge amounts of
    static in mine and wondered if it was just me...
    #52
  13. SIRPip
    SIRPip Guest
    Snowleopard wrote:
    [slanket]
    Would you like to play with my light sabre?
    #53
  14. SIRPip
    SIRPip Guest
    That's OK then. Two windows a day and then hit the booze.
    #54
  15. SIRPip
    SIRPip Guest
    It'll be the girls jostling.
    #55
  16. SIRPip
    Simon Wilson Guest
    Good luck with that. We've just spent two weeks also in Grenouilleshire
    chiselling out the cement, lime mortaring around the frames,
    unscrewing/drilling out hinges, taking out the glass, sanding back to
    bare wood, painting, new glass, puttying[1], <fx:counts> four windows.
    On top of the five we've already done, only two more to go and that's
    the front finished. Then it's time to start on the back.
    [1]swmbo's getting pretty good at it now.
    Simon Wilson, Aug 13, 2010
    #56
  17. SIRPip
    Salad Dodger Guest
    This is merely a stop-gap measure. If it needs doing properly, the new
    owners [if they ever materialise] are welcome to get stuck in.
    #57
  18. SIRPip
    Still easier to use GBP if you're using a non-UK keyboard,
    particularly a laptop one with no numeric keypad. And I still tend to
    use Eu instead of the euro symbol for the same reason.
    Ace, Aug 14, 2010
    #58
  19. SIRPip
    boots Guest
    Ctrl + ALT + 4 usually for my different PC
    boots, Aug 16, 2010
    #59
  20. SIRPip
    SaladDodger Guest
    Good news! All the windows open inwards, so no arseing about with
    ladders.
    SaladDodger, Aug 16, 2010
    #60
