Mikuni VM - setup - does not take more than 1/4 throttle
Discussion in 'Motorcycle Technical Discussion' started by vtraudt, Jun 16, 2006.
  1. vtraudt
    vtraudt Guest
    I have a 1980 Suzuki TS 125 with a Mikuni VM type 'round' carburetor.
    It did not start this spring, so I took the carb out and apart, and
    cleaned it complete (never been done).
    The bike now starts (after lots of trying, ultimately tow starting it
    by pulling it with a car).
    But in only takes 1/4 throttle, than chokes and would die if not
    closing the throttle immidiately.
    I had tightened all interal screws, and no start to think that there
    may be a mix screw inside that adjust the air/fuel mix.
    a) can someone please let me know if that is the case?
    b) what screw it is?
    c) how to set it to get the bike going again
    Note: it is a huge pain in the butt to take the carb out and get the
    boot to the airbox back on, so I only want to do that again only once,
    if possible.
    Thanks.
  2. No shit ;-)
    Oh dear, another one.....
    A pound to a penny:
    (a) that you haven't cleaned out the carb properly - really, the way
    modern fuel gus, you need a lot of cleaner and a good source of HP air.
    Or an ultrasonic cleaning tank.
    (b) That you've screwed the pilot adjuster screw right in. Possibly the
    tickover screw too.
    Get a manual and read it. Or get someone who knows what they're doing.
    chateau.murray, Jun 16, 2006
  3. vtraudt
    Leon Guest
    It's probably something wrong with the needle or needle jet, they are
    important at around 1/4 to 3/4 throttle. You need to take the carb
    apart again.
    Leon
    Leon, Jun 16, 2006
  4. vtraudt
    spongehead Guest
    I have an old 82 PE 175 with the same type carb. You can leave the
    airbox off until you get the bike running properly. My bike didnt even
    have one and it ran for years without it. When you get the airbox back
    on, you may have to adjust the air screw.
    There isnt too much to the carb. Needle, seat, float and that round
    brass piece with the holes in it with the hexagon nut (forget what its
    called) should be all thats inside. When you took the carb apart, did
    you also remove the air intake screw and idle screw? If so than thats
    what the problem is if its not the needle and seat. I believe if you
    screw them all the way in than back out a 1/4 turn or so, that should
    be it.
    However, if you had to bump start it, another guess would be the float
    is heavier than it used to be causing little gas to get into the
    chamber, than when you hit the gas, too little gas flows back into the
    bowl causing to choke for lack of fuel. The needle could also be
    messed up, shooting way too much gas soaking the plug. When it is
    running, see if theres gas dripping from a connection point on the
    baffle (if there is a semi-loose connection) just as it comes off the
    engine. Kinda like the drain pipe under your sink. That means too
    much gas and your needles messed up. Look at the tip of the needle.
    If it has a ring around close to the tip, than replace it. In fact
    while youre at it, get a new seat (usually comes with the needle) and a
    new float.
    Hope this answer is better for you than go buy a book or have someone
    else do it.....
    spongehead, Jun 16, 2006
  5. The Mikuni VM tuning manual is available on the Web -- I know because
    I grabbed a copy last year while trying to sort a DT175MX. It's a 1.2 MB pdf
    file; don't recall how hard it was to find...
    Ah, here it is (and many more):
    http://www.mikuni.com/c-manuals.html
    Dr Ivan D. Reid, Jun 16, 2006
  6. vtraudt
    FB Guest
    On VM carbs, the the slot-headed idle mixture screw is right there on
    the side of the carburetor, just upstream of the slide.
    The other screw (it may have a knurled knob so you can turn it with
    your thumb and forefinger) will move the slide up or down a little to
    adjust the idle speed, but the idle mixture screw is an AIR screw.
    It controls the amout of AIR in the idle mixture. So turning it
    clockwise decreases the air in the idle mixture and makes the idle
    mixture richer.
    The correct setting is usually about 1.0 to 1.5 full turns
    counterclockwise from the fully seated position.
    But you may want to completely remove the idle mixture screw and spray
    carburetor cleaner through the passageways to get the gum and varnish
    out.
    FB, Jun 17, 2006
  7. vtraudt
    vtraudt Guest
    Thanks chateau;
    your contribution to the group is very helpful (duh!).
    --> well, that's what YOU are supposed to be
    If we just had more like you (then user groups would be extinct in no
    time).
    volker
    vtraudt, Jun 17, 2006
  8. vtraudt
    vtraudt Guest
    Update:
    The Suzuki starts at the first kick (just can't use any throttle or
    choke).
    Keeps taking only 1/4 throttle, then chokes.
    Volker
  9. vtraudt
    vtraudt Guest
    Spongehead,
    thanks for the constructive suggestions (unlike mr. smartypants).
    --> How can I identify the "air intake screw and idle screw"
    --> that was just a means to get it going. It now starts on the first
    kick. It does not take ANY choke or throttle (otherwise it fouls up
    quickly)
    --> The first times I tried to start the bike the normal way (some
    choke), but flooded it (spark splug totally wet, smell gas, gas
    dripping out of the cylinder/exhaust). Now that I know, it starts well,
    no throttle, no choke. Idle is setup well, and runs well at idle. Could
    it be it is the opposite, meaning too rich, too much gas?
    --> Not sure where to look for that connection point, and the baffle.
    --> the needle has no marks
    --> You are hit it on the head. Thanks for the help.
  10. vtraudt
    vtraudt Guest
    Dear FB:
    --> ok, found it (I took it all the way out once, and there was just a
    hole to the slide).
    --> got this one. the know is knurled. I use it to set the idle at the
    desired speed; the conical portion of that screw moves the slide
    up/down.
    --> I will report back soon. Is the screw on the slide staying in its
    partly loose condition all by itself? (Thats why I tightened it in the
    first place, afraid that it falls out).
    --> Carb was taken apart completely and washed with lots of cleaner.
    All build up, varnish, etc. removed nicely.
  11. vtraudt
    FB Guest
    Maybe that is your whole problem? You tightened the idle mixture screw
    and the engine isn't getting idle mix?
    There should be a small spring on the idle mixture screw. It maintains
    tension on the screw.
    I leaned up the idle mixture so much on one motorbike I feared the
    screws might fall out, so I put a drop of 3M weatherstripping cement
    (gorilla snot) on top of each screw to be sure it wouldn't vibrate out
    and get lost.
    One weird situation I ran into was when the gasoline evaporated in the
    float bowl of a motocrosser. It used pre-mix and the oil had a green
    dye to indicate that there was oil
    in the premix. The green dye formed a solid clump in the main jet.
    It's hard to see gum and varnish inside the internal passages. The VM
    carb sucks idle
    air in through a pilot air jet in the mouth of the carburetor. It sucks
    idle fuel in through the pilot jet in the float bowl. The two flows mix
    downstream of the idle mixtue screw and they discharge through about
    two small ports just downstream of the throttle slide.
    It sounds to me from your description that the engine is starving for
    fuel in the transition from idle to acceleration mode. The VM
    carburetor uses a cutaway slide to help the engine transition from idle
    to acceleration. It probably has the right slide and you can't put the
    slide in backwards.
    The jet needle is attached to the slide. The jet needle has most of its
    effect from half throttle to full throttle, and the idle jet is
    supplying about half of the needed fuel to the engine up to half
    throttle.
    As you open the throttle more and more, vacuum downstream of the slide
    drops off and the flow of fuel through the idle jet decreases to
    nothing at full throttle.
    As the slide opens, more and more fuel flows through the jet
    needle/needle jet combination. The JN/NJ is a variable orifice that
    works in the mid-range of throttle slide position.
    The diameter of the NJ has a lot of effect from 1/8th throttle on to
    fully open. There are two things that can go wrong with the NJ. One is
    that the JN bangs against the hole in the NJ and makes it egg-shaped.
    That causes the mixture to be too rich.
    The other thing that can happen is that the cross-drilled air emulsion
    holes in the NJ get plugged up with gum and varnish. There are two type
    of NJ. One is the air bleed type with the emulsion holes, the other is
    the "primary type" NJ, which has no holes.
    The NJ can usually be removed from VM carbs by pushing it up through
    the hole where the slide goes, or pushing it down towards the float
    bowl side. There may be a rubber o-ring on the NJ.
    The idle jet probably has air emulsion holes, too. Mikuni was probably
    the first motorcycle carburetor company to add emulsion holes to their
    NJ's and the idle jets.
    The holes help mix fuel and air and provide better low speed throttle
    response.
    If you have to remove the idle jet for cleaning, be sure to use a slot
    screwdriver that fits the jet perfectly, otherwise you can damage it.
    FB, Jun 17, 2006
  12. Well, you evidently don't know what you're doing, and I pointed out that
    screwing all the screws in is *not* the way to go about it.
    Also, as has been discussed many, many times before, with modern fuel
    going 'off', what you think is a good carb clean isn't.
    The potential of you getting it wrong again is evidently large, so the
    advice to get someone along who knows what they're doing is good advice.
    You've been pointed in the direction of a Mikuni manual, and FB has
    given some good advice.
    You need to know size of main jet, size of pilot jet (both may have been
    changed in the last quarter-century), size of needle, needle setting on
    the carb clip (there are usually three or four settings), float height,
    pilot adjuster screw setting (one and a quarter turns out is usually a
    good starting point).....
    If all those are correct, and the carb is properly cleaned, then it
    should be OK.
    If you don't know how to check all that - like I said, get a manual and
    read it or get somewone who knows what they're doing.
    There's no shame in ignorance. But mucking around with something when
    you know you're ignorant is stupidity.
    The Older Gentleman, Jun 17, 2006
  13. vtraudt
    FB Guest
    Well *shame* on Volker, for daring to ask for help, then! ;-)
    What do you do when a lost motorist asks for directions, do you tell
    him he's a fool for getting out of bed and getting lost in a strange
    town?
    He doesn't need to know any of that shit, except for the starting
    setting of the idle screw. He's not trying to retune the carb for
    competition, he's just trying to get the friggin' engine to run when he
    opens the throttle past 1/4.
    How else does a person learn, if not by his mistakes or by asking
    knowledgeable people intelligent questions? You're slamming both doors
    in Volker's face, apparently for no other reason than to assert your
    own "superiority".
    The whole idea of rec.motorcycles.tech is that a newbie asks more
    experienced riders technical questions about production motorcycles.
    The NG is not supposed to be a forum for debating suitability of this
    machine over that machine or establishing a pecking order of who is the
    most brilliant being on the planet and who kisses yahoo butt.
    If we wanted to read such profitless debate, we'd go
    to rec.motorcycles or alt.motorcycle and play with the Canadians.
    FB, Jun 17, 2006
  14. Trying to diagnose a mystery carb problem over the internet is like
    asking someone to hold their phone next to a running engine to diagnose
    what the rattle is.
    Yes, he *does* need to know, because with a 25 year-old two-stroke there
    is a fair chance that someone has mucked about with it in the last
    couple of decades.
    OK, it could be an all-original unmessed-with bike, but the odds are
    against it. If it was running perfectly before he took the carb off (the
    OP doesn't say), then yeah, maybe you don't need to check the right jets
    and needle are in it - but I'd still recommend checking the float height
    and needle setting, if he dismantled everything to clean it. If you
    disagree, please tell us why.
    I've bought bikes with carb needles on the wrong setting, non-standard
    jets and incorrect float heights. I've bought bikes that have "just been
    serviced" with *everything * wrong with them.
    Let me tell you a story: two years ago I bought an old GT380 triple off
    Ebay. Looked utterly stock, ran very sweetly, etc etc. But it was
    choking badly above about 6500rpm: seemed to be running rich. First port
    of call was the air filtration. Stock airbox, stock filter cores, but
    wrapped around them was a very strange foam indeed.
    It was carpet underlay. Fucking carpet foam. Closed-cell foam. It was a
    miracle the engine even ran at all. The butchery people inflict on bikes
    defies belief.
    Where does it say that in the charter? You're talking utter bilge.
    Look, you're knowledgeable - you draw laughingly wrong conclusions from
    time to time ('post hoc ergo propter hoc' could be your motto), but
    ne'er mind - but AFAIC there is a golden rule with machinery.
    If you don't what you're doing, don't do it.
    And getting in someone who knows, to show you how it ought to be done,
    is the best way of learning. If you think my recommendation to that
    effect is wrong - well, there we differ.
    There is no substitute for hands-on experience. Asking on usenet is
    often a help, but you're the man who gave that CG125 poster reams of
    utterly useless advice about a carb that his bike wasn't even fitted
    with.....
  15. vtraudt
    vtraudt Guest
    FB: the idle screw has the spring and is working fine. I can adjust the
    idle (and it runs well in idle, from very low RPM to high RPM idle
    speed.
    There is one more screw on the outside of the slide. This one is just a
    screw with a seal ring. This is the one I thought you referred to as
    the air screw. I tried to back it out one turn, but that does not seem
    to change the behaviour of the motor (dying if more than 1/4 throttle
    is used). This is also the one I would be concerned to leave in a not
    tighten position, because nothing would prevent it from falling out. I
    have no idea what that screw is used for. In the parts diagram, it is
    described as "plug" and "washer".
    In the Mikuni manual is a parts drawing for a VM carb, but it shows
    more parts than mine has, particular they show an external screw
    labeled as "Air Screw" and "Spring, Air Adjusting Screw". My carb does
    not have that. It is shown on the oposing side of the idler adjustment
    screw, closer to the air intake flansh.
    I was hoping to find that I had just put the jet needle in a wrong
    groove (in the old days, the needle had several hight positions to
    choose from), but checking it out, it only can be installed in one
    position.
    So I still don't know how on my carb the air fuel ration is
    adjusted/set.
    I will try to send you the parts list of the carb, maybe you can point
    it out for me.
    Volker
  16. vtraudt
    vtraudt Guest
    Chateau:
    I am obviously no expert on Mikuni carbs, that's why I'm here.
    The problem only occurred after I took the carb apart for a cleaning
    (never been done since I got the bike, and likely not before either).
    So I don't have to worry about jet sizes etc (since it was running good
    with original jets).
    Idle is also fine.
    It starts great.
    External adjustments on the carb is only the idle screw. The other
    screw on the outside of the slide is just that: a screw with a washer.
    In the parts diagram named "
    plug" and "washer". I can't imagine that this screw is a setup screw
    (nothing would hold it in place if not tightened"), when removed there
    is just a hole to the slide.
    I also noticed that the Mikuni parts list in the manual shows an air
    adjustment screw, which my carb does NOT have (the manual shows it on
    the opposite site of the idle adjustment screw, close to the air intake
    flange).
    How is the air/fuel mix adjusted on my carb? There don't seem to be
    external adjustment screws (besides the idle screw and the screw on the
    slide, there is only what looks like a drain screw in the bottom of the
    carb).
    Volker
  17. Yes, I can see that on the schematic.
    That drain screw is just that - for draining the float bowl.
    Are you *sure* there isn't an air bleed/pilot screw? There damn well
    ought to be.
    Just a thought - you have got the needle assembly correctly, er,
    assembled?
  18. I had a similar experience a year back. ISTR you were on holiday at
    the time so you may not have seen the post. A DT175MX I'd bought was having
    running problems[1], mainly not returning to idle. Turns out someone had
    replaced the stock filter foam with a bit of oiled double-layer cotton knit,
    the type you (used to) get smoked hams packed in. Fitting the genuine
    article made no odds, however. We then suspected a leaky crank seal, but
    the bike was stolen before we could test that hypothesis. :-(
    [1] This being the reason I'd originally found that Mikuni VM manual.
    Dr Ivan D. Reid, Jun 17, 2006
  19. vtraudt
    FB Guest
    The Sudco Mikuni Carburetor Parts and Tuning Manual shows an exploded
    view of the
    spigot mount type Mikuni carburetor which we all know and love as the
    VM series
    round slide carb.
    The air adjusting screw is # 29 and the spring is # 30. Turning # 29
    counterclockwise leans the mixture.
    # 27 is a plug on the bottom of the float bowl. # 26 is a copper washer
    to seal the plug.
    In flange mount float bowls, the plug is # 43, but is called a "Banjo
    bolt" for some reason known only to Mikuni-san. It is actually used as
    a main jet holder in some VM carbs.
    # 11 is the needle jet, and, if it is the air bleed type it would
    apparently have to be pushed UP through the slide area to remove it.
    Those needle clips only fine tune when the carburetor comes full onto
    the needle.
    Your problem is occurring at smaller slide opening than that.
    It may just be possible that your main jet ( part # 36 ) has fallen out
    of the needle jet and is lying in the float bowl.
    I actually had this happen once. I was trying to pass an 18-wheeler and
    when I tried to use full throttle, the excess full coming through the
    needle jet was drowning the engine.
    The air screw will to that. It's going into the carb body at a 45
    degree angle.
    I suppose that carb has the bypass starting enrichener system shown in
    the inset. #17 (starter plunger) is actually an air valve in a bypass
    passage going around the slide. There is a fuel passage that allows the
    bypass starting enrichener to suck gasoline right out of the float bowl
    when the starter plunger is raised.
    The starting enrichener works worse when you open the throttle. Vacuum
    downstream of the slide drops off and less gas is sucked out of the
    float bowl.
    FB, Jun 17, 2006
  20. Heh. Yes, I remember it well....
    Don't remember the air filter thing, though.
    I'm amazed at what people do to bikers - my son's DT50 had a charging
    problem, after running fine for a while, Turned out there was no
    rectifier in it - it had been bypassed, and there was just the
    regulator.
    I hadn't checked for the presence of a rectifier because - well, you
    don't, do you? I didn't check that the air filter on the DT wasn't made
    of smoked ham wrapping because... you don't, do you?
    The Older Gentleman, Jun 18, 2006
