Mini DV camera
Discussion in 'UK Motorcycles' started by eatmorepies, Aug 31, 2010.
  1. eatmorepies
    eatmorepies Guest
  2. eatmorepies
    Krusty, Aug 31, 2010
  3. eatmorepies
    eatmorepies Guest
    It's plastic. It works though. Took 2 weeks to arrive - as the man said it
    would. Will give it a go this afternoon and try posting a short sample on
    Utube. At the moment (1) I'm bending bits of aluminuim to make a more
    substantial mount system than taping the flimsy plastic lapel clip to the
    fork leg and photographing the sky.
    1. I'm really eating cake and typing.
    John
  4. eatmorepies
    Brownz Guest
    I'm currently adapting a test tube clamp stolen from school in the
    early 80's, cork grips now replaced with superglued rubber pads.
    PS - Maplin have the real (alloy body/proper switches) AEE MD81 on
    Promo at the moment £39.99 delivered. http://www.maplin.co.uk/Module.aspx?ModuleNo=285263
    A lot pricier than the fake ones on eBay at the mo, but a lot nicer
    imo, and this actually works more that 50% of the time, which is more
    than I can say for the cheapo plastic one I received.
    Brownz, Aug 31, 2010
  5. eatmorepies
    Cab Guest
    I'm glad you posted that. I had a butchers at Maplins yesterday and
    couldn't find it anywhere.
    Cab, Aug 31, 2010
  6. eatmorepies
    Cab Guest
    I can quite happily cable tie it to the mushroom or the forks.
    To the rear indicator, it vibrates like a bastard.
    Cab, Aug 31, 2010
  7. eatmorepies
    Cab Guest
    To get rid of it, use virtualdub with the add in downloaded from here:
    http://www.aircommandrockets.com/timestamp.vdf
    Cab, Aug 31, 2010
  8. eatmorepies
    SIRPip Guest
    Woo! I've got a couple of them, but they're mid-Seventies era. They
    come in useful for all sorts of things in the shed, but I'd not thought
    of rubber-padding them. Goodonyer.
    SIRPip, Aug 31, 2010
  9. eatmorepies
    Brownz Guest
    Dead handy aren't they, I have one coverted to a service lamp, I can
    clamp it anywhere on the bike and then angle it anywhere.
    I have another one which is acually two clamped together which I use
    as the occaisional spare hand when needed.
    Make sure you use a decent superglue - something like Loctite 401.
  10. eatmorepies
    SIRPip Guest
    Indeed. Double-ended with what used to be the clamp that attached it
    to the vertical pillar joining the two. A third hand often comes in
    useful when you're working alone.
    Arse. I've just done one, using Evo-Stick and leather strips.
  11. eatmorepies
    My kite has arrived, but not the camera - the plan is to tape the camera
    to my gay flag box kite [1] and using extra long string (I think the kite
    people call it a "control line") take pictures up above the streets and
    houses, my kite climbing high and everyone can see it smiling.
    ....or I may just go on the beach or downs.
    [1] http://www.skyhighkites.co.uk/product_images/l_65_1.jpg
    sweller, Aug 31, 2010
  12. eatmorepies
    eatmorepies Guest
    Is the output better? This cheapo one I've bought produces video where the
    picture seems to wave. Is that likely to be some setting in my pc or the
    original camera?
    I've probably had my 8 quid's worth of fun recording my ride through
    Abergwesyn (mid Wales) and over the Staircase this afternoon. I'd happily
    pay £40 for a mini camera with steady output.
    John
  13. eatmorepies
    that should get you some interesting conversations on the beach round your
    way...
    wessie, Aug 31, 2010
  14. eatmorepies
    Brownz Guest
    Tis an effect you get with CMOS cameras - google "Rolling Shutter".
    I find the more rigid the mount the better - but ymmv.
  15. eatmorepies
    eatmorepies Guest
    I've read the notes and see the problem. I can't see that I can mount it
    more rigidly than I have, it's pretty securely fixed to the fork leg. -The
    problem no doubt lies in the fact that the bike is moving - in many
    directions at once. One chap suggests a faster card, I can't see this
    solving the problem but I'm willing to give it a go - I could use such a
    card in my new camera if it fails to cure the wobble problem.
    I'm also going to have a look at cameras specifically designed for the job -
    sport bullet cams etc.
    Thanks for the information.
    John
  16. eatmorepies
    Thomas Guest
    Thank you, thank you, thank you.
    Not that we hoarders really need vindication for keeping things
    forever.
    Thomas, Aug 31, 2010
  17. eatmorepies
    SIRPip Guest
    While you're there, sort out a real newsreader that quotes correctly,
    'cos it has mangled your last two replies in a horrible manner.
  18. eatmorepies
    Cab Guest
    That only happens for me at high speeds [1]. Mined ewe, I films a bit of the
    train journey today without any issues.
    [1] It's probably more to do with the bike than the camera when it hits the
    "vibration point" (I'll be damned if I can remember what the phrase is in
    English).
    Cab, Aug 31, 2010
  19. eatmorepies
    Cab Guest
    Works for me.
    Cab, Aug 31, 2010
  20. eatmorepies
    Cab Guest
    You can do wonders with virtualdub. And it's free.
    Cab, Aug 31, 2010
