Royal & Sunalliance have provided me with an '04 Suzuki GS500 (1,500 miles on the clock) to use while the ER-5 is in for work. As I've used it for a few days and have covered 150 miles on it I think I'm in a position to write a mini-reviewette: Bad points: .. It's blue. .. Steering might as well not be there. .. Rattles so much my hands go numb over 6,500rpm. .. Dives under braking. .. Rear disc is worse than the ER-5's drum. .. It's underpowered compared to the ER-5 (even when the ER-5 was restricted I'm sure it would outrun this GS500 which I assume the hire firm have restricted) .. Seat is too hard - numb bumb .. Rear brake is binding. .. Headlamp is useless at night, even on full beam as it's aimed too low. .. Steering lock and 'parking light' mode are too close together, if you click it anti-clockwise once too many times you have the parking light on and as there is no 'off' switch for the headlamp there's a possibility of draining the battery. .. Under-seat storage space is even worse than the ER-5's. .. Shocks very stiff - I went over a slightly sunken drain cover today and I will now never be able to father children. Good points: .. Decent front brakes. .. Stock exhaust isn't too quiet at higher revs. .. 20 litre fuel tank. .. Economical. .. Isn't costing me anything. GS500 list price £3349 ER500 list price £3299
