Monster ????
Discussion in 'Australian Motorcycles' started by isaac_the_blind, Aug 6, 2006.
  1. Anyone comment on a 2001 Ducati Monster 900 ??
    A friend is wanting to buy one. Asking $10,000
    Isaac.
  2. isaac_the_blind
    J5 Guest
    yes its an italian bike
    if you require more comments then it would require more
    information on the bike in question
    J5, Aug 6, 2006
  3. Italian ? Are you sure ?
    Isaac.
  4. isaac_the_blind
    Mad-Biker Guest
    for somebody who has spent the last 6 month sending stupid messages and
    cross posting insults why would we turn around and help you!
    by all means, buy a 10,000 ducati its learner legal
    Mad-Biker, Aug 6, 2006
  5. If you are dumb as i suspect then why not just admit it ?
    Being think as a brick is normal in some societies. You could go into
    politics. become an endorsed Liberal candidate. defend Amanda
    Vanstone. Cheer Howard on his birthday. Ride a Honda. drive a
    Commodore. Mummy is calling. Bye bye.
    Isaac.
  6. Yeah, Honda did a really nice job when they released the '01 Ducati
    Monsters, they totally revised the water cooling and the gear drive to
    the cams, and they went to triple row valve springs which lets them rev
    out past 17,000rpm. The fairings came in carbon fibre on the S & R
    models in '01 (the standard models got GRP fairings), and they used
    tool-less dzus fasteners on them (which you might want to replace if you
    park anywhere thats not too secure). The White Power forks on the front
    are great, as are the Nissin 6 pot brakes, but the rear is over-sprung
    for anyone weighing under about 90kg. They really need a set of pipes to
    release the full 4 cylinder howl - Yoshimura and Akropovic both make
    nice aftermarket exhausts for it (though the Akro requires you to lose
    the exup valve which affects the torque at lower rpm, this isn't much of
    a problem since you pretty much always spin these motors up near the
    redline anyway). If you get one with the factory luggage (you can tell
    the factory luggage versions 'cause they'll have the electrically
    adjustable windscreen), check that the cd stacker in the rhs pannier
    hasn't been water damaged - there was a factory recall on the weather
    seals because the originals would let water in while riding in the rain
    if you had the volume up high enough that the subwoofer could vibrate
    the seal open. Make sure it hasn't still got the original Avon Viper
    tire on the sidecar, they're _hopeless_ on dirt. Keep an eye out too for
    cracks around the trailer hitch - a lot of these got used for towing
    caravans, often exceeding the recommended max towing weights. You'll
    occasionally see one that was used for towing a boat too - this was a
    really bad idea, the entire rear suspension and subframe will usually be
    rusted out where they got wet in saltwater backing them down the boat
    ramp (though if it only ever got used for fresh water boating it might
    be OK).
    Glad I could be as much help as you usually are around here, if you've
    got any other questions, you know where you can stick them...
    big
    Iain Chalmers, Aug 6, 2006
  7. isaac_the_blind
    Mad-Biker Guest
    Atleast I know im thick, you haven't worked it out for your self yet
    go troll somebody else's news group for you buying a k100 or ducati or what
    ever racial slur you wish to provoke in here.
  8. isaac_the_blind
    CrazyCam Guest
    Depends....
    what particular model is it?
    If it's a two-valve per, job and has adjustable suspension, and it in
    good nick, it's a bit over priced, but...<shrug> might be OK.
    If it's one of the four valve per cylinder ones....forget it.
    Is your friend a proper hooligan?
    If yes, the Monster might suit.
    If no, then get them to look elsewhere.
    regards,
    CrazyCam
    CrazyCam, Aug 6, 2006
  9. isaac_the_blind
    Boxer Guest
    Them is fighting words.
    Boxer
    Boxer, Aug 6, 2006
  10. isaac_the_blind
    IK Guest
    Paulh Akhbar would be proud...
    IK, Aug 6, 2006
  11. <applause>
    Andrew McKenna, Aug 6, 2006
  12. isaac_the_blind
    john doe Guest
    Isaac, since when have you had friends? are you sure they are your
    friend and its not cause you are the only person they know that rides a
    bike.
    mel told me the italians are worse than the jews because they could have
    fixed the "jewish problem" but didn't.
    good thing your "friend" is not looking at a bmw, cause germans really
    wind mel up...
    failure is not an option with some people
    always happy to help another brother
    JD
    john doe, Aug 6, 2006
  13. Nah. "You wanna fight" is fightin' words.
    Cheers
    PeterC [aka MildThing]
    Before an accident, most city drivers say "****!", whereas most country drivers
    say "Hang on to this stubby, mate, while I show you some awesome driving"
    '81 Yamaha Virago (XV) 750H (work in progress)
    '01 Yamaha FJR1300
    www.dmcsc.org.au
    http://eladesom.com.au/ulysses/
    # 37181
    Peter Cremasco, Aug 6, 2006
  14. isaac_the_blind
    Over the top though; it's not like anyone would actually DO those
    things.......
    Knobdoodle, Aug 6, 2006
  15. isaac_the_blind
    Damn; I was gonna' say that!
  16. isaac_the_blind
    Boxer Guest
    Not for many years Clem.
    Although I have owned ,
    CL175
    XL350
    CB750/4
    XR600
    Boxer
    Boxer, Aug 6, 2006
  17. itz 2nd owner claims 2B a mechanic and has "done all the wurk" himself
    thus no receipts for servicings etc :-( Has LOUD pipes ( remus ?? ) and
    supposedly carbon fibre bits N pieces. Seems a bit pricey but the
    Redbook says an 01 is wurth up to $10,000. HAvent sighted it so dunno
    wot exact model.
    I.
  18. Not a friend really an Associate. There, we've cleaned up that
    little mis conception :)
    Isaac.
  19. But, you didnt did you ?
  20. Racial slur ? What? Ducati. Is that a rude word is some language.
    i.
