More English terms wanted
Discussion in 'UK Motorcycles' started by Radbert Grimmig, Apr 28, 2008.
  1. What do you call it if the engine starts surging or bucking when you
    ride along at a constant, lowish engine speed? Like the four valve
    flat twin beemers used to do for a few years? Is that surging?
    regards
    Radbert
  2. Radbert Grimmig
    Yes. Mine still does it, if the throttle bodies go out of balance
    wessie, Apr 28, 2008
  3. Using the patented Mavis Beacon "Hunt&Peck" Technique, Radbert Grimmig
    Hunting.
    Wicked Uncle Nigel, Apr 28, 2008
  4. Radbert Grimmig
    Beav Guest
    Hunting.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 28, 2008
  5. Radbert Grimmig
    Yes. And they still do it, to a greater or lesser extent.
    Timo Geusch, Apr 28, 2008
  6. Radbert Grimmig
    MikeH Guest
    Adjust the left hound lead until it stops.
    MikeH, Apr 28, 2008
  7. Radbert Grimmig
    Where have you been?
    I've missed your appalling puns.
    Champ
    ZX10R | GPz750turbo | GSX-R 600 racer
    My advice as your attorney is to buy a motorcycle
    To email me, neal at my domain should work.
    Champ, Apr 28, 2008
  8. Radbert Grimmig
    MikeH Guest
    I'm working solid at the moment so I only get time to lurk a bit and
    when I get home family stuff calls more than UKRM.
    MikeH, Apr 29, 2008
  9. Thanks everybody, but there is more.
    I always wanted to know these, so while we're at it:
    - Lastwechselreaktionen. This is what annoys you about the drive
    train/final drive of some bikes when opening or closing the throttle.
    Jerking, felt chain slack, but some people also used this for the
    "lift" effect of crude shaft drives like oldish two-valve beemers had
    up to around '86. I've always translated it to "load change reactions"
    but hated it.
    - "Drehfreude". Is there a noun to go with "free revving"?
    - Can you say "undulating turns" when in fact you mean the bumpy road
    surface?
    - Oh yeah, derogatory terms for nationalities. We call the Americans
    "Amis", which I always felt "Yanks" wasn't doing justice too. Too
    Civil War, too North centered, not enough redneck bashing. Also, for a
    nickname, the German expression is almost tender. We even have sugar
    coated pastry called "Amerikaner". We like 'em here. Well, basically.
    Well, almost.
    Radbert Grimmig, Apr 29, 2008
  10. Using the patented Mavis Beacon "Hunt&Peck" Technique, Radbert Grimmig
    Driveline backlash, I guess.
    Free revving. :^)
    Sounds... odd to me. Can't think of a better term at the moment.
    Yanks is good. We use "Septics" around here, but I don't think that
    would be generally understood (comes from the rhyme with "septic tank").
    You'll have to accept that as just the opinion of an Inselaffe, of
    course...
    Wicked Uncle Nigel, Apr 29, 2008
  11. Radbert Grimmig
    Adrian Guest
    "The usual potholed mess"...?
    "Undulating" implies good, interesting, not-lincolnshire-flat - a road
    that rises and falls as it winds. I don't think that's what's being
    meant...
    Adrian, Apr 29, 2008
  12. Radbert Grimmig
    "Washboard surface" - "lunar landscape"
    You're spot on there.
    Pip, Apr 29, 2008
  13. Radbert Grimmig
    Spot on.
    "Spins the rev counter needle round like a spider on acid"
    Rippled, or where the tarmac has been pushed into linear bumps by
    heavy traffic, "bermed".
    Pip, Apr 29, 2008
  14. Radbert Grimmig
    Colin Irvine Guest
    You can say "turns on an undulating road surface", although if the
    pitch of the bumps is small it would become "corrugated".
    Colin Irvine, Apr 29, 2008
  15. Radbert Grimmig
    zymurgy Guest
    Sweeping bends
    Washboarding
    Paul.
    zymurgy, Apr 29, 2008
  16. Radbert Grimmig
    zymurgy Guest
    "WFO"
    P.
  17. Oh you're all so gorgeous... And another thing:
    What is a "biker" to you?
    Because over here, we usually take it not to mean "garden variety
    motorcyclist" but either the Hells Angels, potbellied, Harley toting
    variety OR the dentists, lawyers and architects who try to harness
    that image for themselves.
  18. WHAT?
    I always took that to mean rather longish, roomy (what's the opposite
    of tight again) turns?
  19. Radbert Grimmig
    zymurgy Guest
    Yep, you're correct. The term undulating infers gradual or non scary
    inclines and declines (descents), so I applied the same to the bend
    description.
    English really isn't that exact sometimes. Other European languages
    are more unambiguous.
    (c/f German and Italian)
    P.
  20. Radbert Grimmig
    zymurgy Guest
    Switchbacks ?
    P.
