most modern bike stand
Discussion in 'Australian Motorcycles' started by createdefuture, Oct 22, 2007.
  1. createdefuture
    Peter Guest
    Peter, Oct 23, 2007
  2. createdefuture
    SteveB Guest
    On Oct 23, 10:49 am, "Shaun Van Poecke" <>
    wrote:
    Probably explains why BMW put a grab handle attached to the sub frame
    just below the seat and in line with the front of the rear wheel. One
    foot on the centre stand and pull UP on the lever and the bike is on
    the stand easily.
    Having said that I am a 85kg, 177cm tall bloke. I don't know how a
    shorter, lighter woman would cope because none have ever tried ;-)
    SteveB
    SteveB, Oct 23, 2007
  3. createdefuture
    J5 Guest
    easy answer is a race stand for $85
    will last forever and even work on bikes without the centre strand
    J5, Oct 23, 2007
  4. createdefuture
    CrazyCam Guest
    True, but, holding the bike with one hand at the back of the bike, while
    positioning, then pushing the race stand up, is a feat requiring a fair
    amount of strength, which is where we came in.
    regards,
    CrazyCam
    CrazyCam, Oct 23, 2007
  5. createdefuture
    Nev.. Guest
    ermmm.. every bike I've ever owned that had a centre stand had a
    lifting handle. It's not rocket surgery.
    Nev..
    Nev.., Oct 23, 2007
  6. True, but not many are in the ideal position! Most that i have owned have
    been way too far towards the rear of the bike. Ideally it would be directly
    above the centre stand, but it looks like a bit of a dogs breakfast.
    Current ride (cbr1000f) has it way too far back, which is the main reason
    this bike can be a pig to get up.
    Shaun
    Shaun Van Poecke, Oct 23, 2007
  7. In aus.motorcycles on Tue, 23 Oct 2007 08:27:02 +1000
    Yes, I can get my old 240-260kg Guzzis on the stand easily. The new
    240kg one, it's a bastard.
    If there hadn't been a side stand I certainly wouldn't have bought it.
    I'm planning on getting a lowering kit which would make the
    centrestand even worse, so now I have a Classic Trailers coupling for
    the trailer meaning I don't need the bike upright to put the trailer
    on, the centrestand is for the parts bin.
    Zebee
    Zebee Johnstone, Oct 23, 2007
  8. In aus.motorcycles on Tue, 23 Oct 2007 16:27:16 +1000
    Not strength, but balance. Trick is to not over-compensate.
    Zebee
  9. In aus.motorcycles on Tue, 23 Oct 2007 00:49:18 GMT
    THere speaks a bloke.
    One with "upper body strength".
    Zebee
  10. createdefuture
    mrmoped Guest
    Not quite Sherlock! It requires a stronger sense of balance because a
    bike standing upright requires little to no physical strength to hold it
    there.
    Most race/paddock stands require very little effort to lift the arse-end
    of the bike in the air.
    Once the bike is balanced (upright) it is relatively simple to roll the
    stand under the swing-arm and lift the bike. Because the bike is already
    upright, both sides of the stand will engage the swing-arm evenly and,
    unless you are a total cluster, there is little to no danger of the bike
    falling over.
    Having said that, using the centre stand does not require a great amount
    of strength or weight - it is a matter of technique.
    Betty
    One needs to look at a couple of things to determine if the correct
    technique is applied or not. Try this:
    Manhandle (or girlhandle if you sit to pee) the bike upright and hold it
    there by the lifting handle (It may not be a handle it could be a hand-
    hold). Place the right foot on the centre stand and push it down until
    both heet of the centre-stand contact the ground.
    The right hand should be on/in the lifting handle and without trying to
    lift the bike with the right hand, transfer your weight from the left
    foot to the right by lifting the left foot off the ground.
    By doing this you transfer _ALL_ your weight to the centre stand and the
    bike will pop up on the stand faster than you can say "Gee, the bike
    popped up on the stand faster than I could say this"
    The hardest part for many people is the act of lifting the left foot off
    the ground to transfer the weight as there is the perception that you
    lose stability and the bike could fall over. If both the pads of the
    centre stand are on the deck then that is highly unlikely to happen.
    Try the weight transfer using a friend to hold the bike steady. You will
    be amazed at how little effort is actually required. Also, if you're
    using a friend to steady the bike, don't use the lifting handle (you wont
    need it to steady the bike) and avoid the "I'll lift this prick up using
    my muscles" syndrome.
    Practice holding the bike in the upright position from the rear and move
    around the rear of the bike. It really is a piece of cake once you get
    the hang of it.
    mrmoped, Oct 23, 2007
  11. createdefuture
    bikerbetty Guest
    Well, I can't comment yet. Am going to have a go tomorrow - Shaun's mention
    of 50kg women having no probs with 300kg bikes has made me feel like I need
    to have another go at my measly 180kg bike, using the technique he has
    described pretty clearly. Watch this space.
    Won't attempt it till tomorrow coz I'm pretty much on my deathbed at the
    moment, and wimpier than usual.... I seem to have picked up a foul cough
    since PI, and all my back muscles are already strained from coughing (the
    silver lining, of course, is time off work - they get very shitty in there
    if you take germs to share. Funny, coz when I was teaching, people wanted
    you to be there even if you were dying, so they wouldn't get saddled with
    your classes!!!)
    Will let you know how I go with Shaun's technique...
    barking betty
    bikerbetty, Oct 23, 2007
  12. createdefuture
    mrmoped Guest
    will be amazed at how little effort is actually required. Also, if
    you're using a friend to steady the bike, don't use the lifting handle
    (you wont need it to steady the bike) with the view of "I'll lift this
    prick up using my muscles" but rather apply a little bit of muscle to help
    get the bike up on the stand. Your weight plus a little bit of muscle is
    all that is needed.
  13. createdefuture
    bikerbetty Guest
    Funnily enough, I've tried this, exactly the way you say..... and it still
    doesn't bloody work, so there's obviously more to it. I've tried it at home
    AND tried it under the supervision of my mechanic. Can you imagine how much
    I hate failing every single time?
    Bike is booked in for its 36000km service on Thursday. I will ask the lovely
    Bruce to try and teach me YET AGAIN. It looks so bloody easy when he does
    it, and I do exactly what he does and NOTHING happens! I think even HE was
    surprised..... (I suspect some kind of bizarre corollary to the fact that my
    buoyancy & mobility in water are wacky as well.... maybe I'm an alien?)
    betty, still trying.....
  14. createdefuture
    mrmoped Guest
    hmmm, I can understand your frutration and where you're coming
    from. I can't dance and despite my wife's patient tutoring I
    still have two left feet (which makes it bloody hard to get
    boots!).
    Mind you, with enough alcohol in me I believe I can outdo fred
    astaire AND ginger rogers ......... perhaps alcohol IS the
    answer.
    I still maintain that most mass-deficient people can master
    the art of getting a bike up on a centerstand. There'll be
    champers all round when we hear the mighty "EUREKA, I've done
    it"
  15. In aus.motorcycles on Tue, 23 Oct 2007 18:57:36 +1000
    It really does depend on the bike design.
    Like I say, I can do a Guzzi with a dry weight of 240kg when it's
    fully loaded and with a trailer on, if it has a properly designed
    stand.
    I find it almost impossible to do the Norge which is the same weight
    but has a badly designed stand.
    Zebee
  16. In aus.motorcycles on Tue, 23 Oct 2007 08:48:46 GMT
    I'm Not Light.
    I am in fact damn near 100kg.
    I've been using bikes with centrestands for a very long time... In
    fact the Yam is the only bike I've ever had without one.
    But I find it bloody near impossible to put the Norge on the
    centrestand because it's a load of crap. Despite having all that
    weight to put on the stand.
    I can put the other Guzzis on their stands with ease, in fact I never
    used the sidestand on the 850T because *it* was a piece of crap. I
    always used the centrestand. A properly designed, easy to use
    centrestand.
    Friend of mine who is an average sized bloke (that is not a shortarse
    like Mr Littler or a verylargearse like Mr Moran) found it shockingly
    difficult too, and he's had more years of experience with centrestands
    too.
    So don't be so sure that Betty's doing it wrong.
    Zebee
  17. createdefuture
    Betty,
    get your mechanic, son or someone to put the bike onto the centre-stand and
    have a look how far off the ground the "up" wheel is.
    If it's more than about half-an-inch THAT's your problem.
    For me it'd be a simple fix to drop the forks through the triple-clamps or
    rotate the rear eccentrics (like BT mentioned) but if the seat-heaight is
    aleady a problem (or borderline) for you then it might be a far bigger
    problem. (And the first question you'd have to ask is "do I fix THIS bike or
    put up with it and make the NEXT bike right"?)
    Knobdoodle, Oct 23, 2007
  18. createdefuture
    One of the easiest bikes I ever tried was my mate's Z1300/6 Kawasaki.
    It was a piece of piss compared to the Yam RD350, Kwakka mach111 and Ducati
    860GTS the rest of us were riding at the time.
  19. createdefuture
    And if it *does* turn out to be due to the centrestand legs being too
    long, I'll get a GS500 centrestand from the wreckers and customise it
    to work properly with your bike.
    I might be mis-remembering this, but didn't you get a suspension
    lowering kit applied to your GS?
    BT Humble, Oct 23, 2007
  20. In aus.motorcycles on Tue, 23 Oct 2007 04:41:47 -0700
    The lowering kit I'm looking at for the Norge will make the
    centrestand just about unusable apparently. So no change then.
    Zebee
