most modern bike stand
Discussion in 'Australian Motorcycles' started by createdefuture, Oct 22, 2007.
  1. createdefuture
    Theo Bekkers Guest
    You expect him to be pregnant as well?
    I've never been one to lift heavy weights, and used to have problems with
    centrestands on my early bikes, even after being shown how easy it is. Then
    one day, it just happened, and it's been easy ever since.
    Theo
    Theo Bekkers, Oct 24, 2007
    #61
  2. createdefuture
    Theo Bekkers Guest
    And if you're a short lassie and some helpful man has 'adjusted' the rear
    suspension to make the seat lower for you, that's not gonna help at all.
    Theo
    #62
  3. createdefuture
    Theo Bekkers Guest
    What the hell is this 'chain' thing and why would have an exposed one on
    your motorcycle?
    Theo
    #63
  4. createdefuture
    Theo Bekkers Guest
    I saw a pile in just those colours (plus green) at Cranbourne motorcycles.
    They were off-road jobbies though.
    Theo
    #64
  5. It's your upper body strength, Theo...
    intact.kneeslider, Oct 24, 2007
    #65
  6. createdefuture
    Theo Bekkers Guest
    Who was it at the dinner who said "I'm from Canberra, it can't get that cold
    in the Bass straight stand". :)
    Theo
    Told ya!
    #66
  7. createdefuture
    bikerbetty Guest
    yes yes.... <eating words> ;-)
    crikey it was chilly!
    betty, whose nose is starting to peel a bit
    bikerbetty, Oct 24, 2007
    #67
  8. It is an arrangement of metal plates rivetted together with spacers between,
    quite clever really
    And quite different from the thing made of oval links formed from wire, used
    for tying things together that you are undoubtedly thinking of
    They are most useful in an industrial environment for the solution of power
    transmission problems; although somewhat superceeded by the timing belt,
    they can be used where sprocket alignment cannot be guaranteed, unlike the
    timing belt that likes a good alignment lest it become shredded.
    Due to the use of modern materials and construction techniques most chains
    run just fine without much care at all...as any maintenance fitter will
    attest
    Exposed chains are fitted to motorbicycles in order to ensure that the
    'chain lube' industry continues to exist.
    Fulliautomatix, Oct 24, 2007
    #68
  9. createdefuture
    Brilliant design too; only 450 moving parts!
    Knobdoodle, Oct 24, 2007
    #69
  10. createdefuture
    J5 Guest
    the 250 here only has a centre stand, but weighing bugger all its pretty
    easy to use
    J5, Oct 24, 2007
    #70
  11. createdefuture
    Moike Guest
    http://tinyurl.com/2fk3mb
    Moike
    Moike, Oct 24, 2007
    #71
  12. In aus.motorcycles on Wed, 24 Oct 2007 11:59:37 +1000
    Hell yes.
    It only has a centrestand, dating as it does from the era when all
    pukka sportbikes had centrestands and only boring average bikes had
    sidestands.
    Zebee
    Zebee Johnstone, Oct 24, 2007
    #72
  13. createdefuture
    CrazyCam Guest
    Hmm, anyone else want yellow 3.00 x 8, and 3.50 x 8 road pattern tyres?
    regards,
    CrazyCam
    CrazyCam, Oct 24, 2007
    #73
  14. createdefuture
    Theo Bekkers Guest
    Not on Friday it wasn't. Still, sipping beer inside our tent whilst being
    served hot fingerfood was tolerable.
    Theo
    Theo Bekkers, Oct 25, 2007
    #74
  15. createdefuture
    Theo Bekkers Guest
    #75
  16. createdefuture
    I can offer you a try at either a CT90 (at 80kg probably good for
    learning the knack!), or a bloated 220+kg GPZ900. Minx's Hyosung
    doesn't have a centrestand.
    BT Humble, Oct 25, 2007
    #76
  17. createdefuture
    Nev.. Guest
    Does it matter how many moving parts there are? Surely that's only
    relevant if they fail.. and they don't fail often enough to warrant a
    bad name for it... and they don't require replacing frequently enough to
    cause financial hardship.. but if you really wanted to save money, when
    petrol is in the region of $1.20/litre, you'd buy a bike with an engine
    which gave better than 30% efficiency. Imagine spending $25 for a tank
    of petrol and then burning it in an engine which wasted $18 worth of the
    energy potential of the fuel.
    Nev..
    Nev.., Oct 25, 2007
    #77
  18. Go for the bloatbike. In fact, there's a kiddy book in it: "Biker Betty
    and the Bloat Bike".
    Andrew McKenna, Oct 25, 2007
    #78
  19. createdefuture
    bikerbetty Guest
    Ooooh, fab idea - and I'll dedicate it to you Andrew, as the Ideas Man!!!!!
    PS Give me a hint - is the Bloat Bike a Goldwing?
    betty, hiding
    bikerbetty, Oct 25, 2007
    #79
  20. createdefuture
    bikerbetty Guest
    Actually, writing the book will be easier than trying to hoick the bloated
    220+kg bike onto its stand, I reckon.... (Can one write with a hernia???
    <chortle>) (Oh I am seeing visions of fabulous illustrations already!)
    I think that starting with the CT110 would be the go, BTH... You know, I
    didn't have any probs getting the GPX250 onto the centrestand....
    betty
    #80
