Motor explosions in decelerating
Discussion in 'Australian Motorcycles' started by News, Dec 13, 2003.
  1. News
    News Guest
    I've got a Yamaha Virago XV535 year 1993. When the motor is warm and when
    i'm decelerating, it's explode and I have difficulties in accelerating and,
    espacially in starting again when i'm stopped because the motor is stopping
    when i'm accelerating in first speed. I have new spark plugs, a new air
    filter. This moto
    has few kilometres (13000). It's dangerous: when i'm turning I believe the
    engine speed is good but it's suddenly accelerating with an explosion. What
    do you thinking about this problem?
    Thanks.
    News, Dec 13, 2003
  2. News
    Johnnie5 Guest
    sounds like it is running lean
    maybe a case of blockages in the carb
    try using some choke when warm and see if it gets any better
    Johnnie5, Dec 13, 2003
  3. News
    conehead Guest
    It sounds like you might need to split the cases.
    Conehead
    "A fellow i see at the auction yards every one and a while has just designed
    a real smart safety device (he won't be sell then at auction-yards he is
    negotiation with the big "houses" read AutoBarn/Repco/K-Mart/SuperCheapAuto
    etc etc to sell them excl. for him)."
    Hatz, in aus.cars, in gibberish mode
    conehead, Dec 13, 2003
  4. News
    Mike.S Guest
    Also if it does make it better, even if it doesnt, DONT ride the bike until the problem is fixed, you
    can burn a hole in your piston if you keep at it without doing so, i know this through missfortune/
    experience. It could be badly tuned, or it could be an airleak between the carbs and their/its boot(s).
    Does the engine idle at a really high RPM and slowly creep up when running sometimes? if so it
    would certainly indicate a leaky carb boot/manifold.
    In any case its a good excuse to rebuild the carbs to make sure of things. :)
    Mike.S
    Mike.S, Dec 14, 2003
