Musings
Discussion in 'UK Motorcycles' started by Ben, Sep 15, 2010.
  1. Ben
    Eiron Guest
    Food of the gods.
    Eiron, Sep 15, 2010
  2. Ben
    Gavin Guest
    Gavin, Sep 15, 2010
  3. The Older Gentleman, Sep 15, 2010
  4. Ben
    Wasn't a cache thing, as I reloaded in two different browsers. But
    it's fine now.
    And the pie? Well, yes, it looks like a home-made pork pie. What
    recipe did you use Paul?
    Ace, Sep 15, 2010
  5. Using the patented Mavis Beacon "Hunt&Peck" Technique, Ace
    "First catch your pig..."
    Wicked Uncle Nigel, Sep 15, 2010
  6. Ben
    Where do people fall in the cured/fresh pork divide?
    I prefer the Melton Mowbray style which is made with fresh pork. Lovely
    with some freshly cooked baby beet, still warm and no sign of vinegar.
    wessie, Sep 15, 2010
  7. Ben
    I made a few when I was a teenager. My dad came home with half a pig and we
    had quite a bit of minced pork to use up.
    I used a recipe from the Rayburn cookbook for hot water crust pastry and
    just experimented with the filling. Plenty of pepper, some sage and a bit
    of cooked apple to give a little sweetness worked well.
    Loads of recipes on google for the pastry.
    e.g. http://www.cookipedia.co.uk/wiki/index.php/Hot_water_crust_pastry
  8. Ben
    Catman Guest
    I always thought that all pies were made with fresh pork, although ICBW.
    AFAIK a Melton Mowbray pie must be hand raised, nothing else, but wibble
    flip.
    www.cuore-sportivo.co.uk
    Catman, Sep 16, 2010
  9. Ben
    Catman Guest
    How odd. Transparent proxy, perhaps.
  10. Ben
    Brownz Guest
    Brownz, Sep 16, 2010
  11. Ben
    davethedave Guest
    Rustic in appearance. A slight leakage of meat juice down one side. A
    fine looking pie.
    davethedave, Sep 16, 2010
  12. Ace escribió:
    I'll dig it out in a bit if I'm not being whooshed again.
    Paul Carmichael, Sep 16, 2010
  13. Ace escribió:
    Here we have it in full, as sent to me by a friend.
    The Filling
    400g Pork mince (I use Mercadonas)
    100g Bacon bits (I use one of the cinta de bacon packs from above)
    1 tsp Sage
    half tsp Allspice (or nutmeg)
    quarter tsp salt
    Pepper to taste
    Mix all this together, (I usually just put a small amount in the Microwave
    for a minute to test for seasoning)
    For the Pastry case you need-
    12 oz Plain Flour
    Pinch salt
    4 oz Lard
    4 Fl oz Water
    1 Egg
    Half pint Jellied stock or Aspic (I boil a pig trotter up then cool the
    stock and skim any fat off)
    Mix flour and salt in a warm bowl. Melt lard gently in a saucepan, add the
    water and bring up to boil. Stir the liquid into the flour with a wooden
    spoon quickly until blended. Turn onto a floured surface and knead until
    smooth. Use at once don't allow to cool.
    I use a 2lb honey jar as a mould, cover the outside with cling film and
    chill.
    remove a quarter of the pastry for the lid and keep warm. Press the
    remaining pastry into a circle and place over the upturned jar, pressing it
    gently to reach the shoulder of the jar (try and keep it the same thickness,
    approx half inch)
    Cut a double thickness of greaseproof paper the depth of the jar and wrap it
    around the pastry case and tie with string.
    Place the jar onto a baking sheet and slide the jar out and cling film. Pack
    the pork mix into the case (you may not get it all in, I ,make meatballs
    with what's left).Pat out the remaining pastry for the lid, dampen the edges
    and crimp to seal, use any excess to decorate. brush with beaten egg and
    make a hole in the centre to allow steam to escape.
    Bake for 2 1/2 hours 180 deg, remove paper collar halfway through the
    cooking time.
    Remove from oven and allow to cool.
    Heat the jellied stock enough to melt and pour into the pie through the
    steam hole.
    Chill for 4-6 hours before serving.
  14. Ben
    Catman Guest
    Saved
  15. Ben
    Likewise, although I'm not sure about boiling up a pig's trotter for
    the jelly. Yukk.
    Ace, Sep 16, 2010
  16. Catman escribió:
    If you're going to send it as-is to your mother, you might want to remove
    the link to the hash cake recipe.
  17. Ben
    Catman Guest
    Can't have a pork pie without jelly, surely?
  18. Ben
    I guess. Although I used to peel it off as a youngster, and still
    prefer ones with just a minimal amount. But what I was referring to
    was the idea of using a pig's foot, rather than ust the aspic.
    Ace, Sep 16, 2010
  19. Ben
    Catman Guest
    Ooooh I see.
    Do you never make stock or similar?
  20. Ben
    Sure. But not from pig bits.
    In many incarnations, I absolutely hate pig meat[1]. Ham is OK, and
    can be great, bacon - well of course, sausages - sure, but anything
    that's called "pork" barring pies and tenderloin, has no place on my
    table.
    [1] What we used to call it as kids when my mum would try to get us to
    eat belly pork and the like. Foul fatty stuff, it was.
    Ace, Sep 16, 2010
