Mutant Nipponese Fasteners
Discussion in 'Motorcycle Technical Discussion' started by Puddin' Man, May 23, 2008.
  1. Puddin' Man
    Puddin' Man Guest
    Bike - '87 CBR600, 20k mi.
    Item - Brace of 4 Keihin carbs
    Please to reference pic on top/left:
    http://farm4.static.flickr.com/3126/2515045092_754fd14937_m.jpg
    Hopefully you can see the intake shroud and 2 mutant phillips screws
    (connected by a strip of sheet metal) per each of 4 carbs.
    Such phillips screws won't break. Even with Liquid Wrench and a
    mechanical impact driver.
    Such phillips screws are soft metal, and efforts to remove them tend
    to strip the phillips slots.
    Such phillips screws shouldn't exist in this application. Bolts might
    have been appropriate.
    What can one do with such garbage?
    Thx,
    Puddin'
    " ... and the bees made honey in the lion's head."
    - from "If I Had My Way", Blind Willie Johnson
  2. Puddin' Man
    . Guest
    Perhaps they were installed using Loctite at the factory. Have you
    tried heating the screws with a torch?
    Don't set your bike on fire doing that...
    ., May 23, 2008
  3. Puddin' Man
    red_bowfire Guest
    I just perused through your previous thread, not sure what you're
    trying to access by removing the brass screw/bracket, but you probably
    won't need to.
    I'll post more in your other thread.
    -88 CBR600 72k miles
    red_bowfire, May 23, 2008
  4. Puddin' Man
    paul c Guest
    Brass, huh? Sorry if I'm impeding this conversation, but I'd like to
    know what's underneath that casting!
    paul c, May 23, 2008
  5. Puddin' Man
    red_bowfire Guest
    Just the the individual carburetors. The brass screws don't connect to
    anything on the other side of the casting. They just hold down the brass
    bracket.
    If I remember correctly, at the top inside of the air box there are
    similar brass brackets. So when the air box is put back on, those brass
    brackets coincide with the the brass brackets on the carburetor housing.
    They formed some sort of baffle, for either noise or for keeping
    crankcase oil blow-by from entering the carb intake.
    There is a crankcase vent hose that connects to the lower part of the
    airbox. Every once in a while i'd find a tiny buildup of oil in that
    lower left hand corner of the casting.
    By the way Puddin Man, just curious how your regulator to stator
    connector is looking. (The center white connector/3 yellow wired). Just
    curious if it's showing any signs of overheating. When my R/R goes out,
    that's the point that always melts.
  6. Puddin' Man
    CBXXX Guest
    I think the philips in Jap application use a different type screw driver
    (JIS) or something like that.The USA type are slightly different and
    cause the problem.I have greater success with them with the stock tool
    kit screw driver.
    CBXXX, May 23, 2008
  7. Puddin' Man
    Puddin' Man Guest
    The Honda tool kit that came with the bike has 1 plastic
    handle, 2 interchangable drivers. The phillips is a
    little flat on the tip like US phillips. J-u-n-k.
    P
  8. Puddin' Man
    Puddin' Man Guest
    The Mutant Screws aren't brass, but they're plated with something
    like brass in color.
    I've been assuming that the MS's pass thru a hole in the casting
    and thread into the carb bodies or somesuch. I can't see anything
    else fastening the casting to the carb ass'y.
    I just Liquid Wrenched one, shot it with liquid air (to freeze it,
    get threads to contract), went after it with very substantial
    phillips driver and a hammer. Nothing, Nada, and Zilch. Truly,
    truly mutant.
    Can't find such on this bike.
    2 hoses, one on each side. Just inspected: trivial amount of oil slime.
    Just inspected the 3 yellow connector in frame behind carbs. I didn't
    remove the whacky connector, but I didn't see any signs of overheating
    or other problem.
    1987 was the 1st year for CBR600 US import if I recall. They were
    "Alpha's" or "Beta's", not 100% production? There were little tiny
    changes between the '87 and '88 models?
    Your comments, etc are much appreciated.
    Cheers,
    Puddin'
  9. Puddin' Man
    . Guest
    Cadmium...
    ., May 23, 2008
  10. Puddin' Man
    oldgeezer Guest
    Memories... memories...
    Years ago I used a vice grip, flattened the sides of the heads, and
    then tried all pliers I own on them.
    I remember that half moon strip, didn't think about what function it
    was
    supposed to have -- I probably mistook it for a lock strip, locking
    those
    phillips screws--
    The screws were fixed with lock tite. I probably swore loud enough
    to persuade them to finally give in.
    That half moon strip gave me a next problem when I reassembled
    the carbs. They warped when I tried to fasten the new screws.
    Rob.
    oldgeezer, May 25, 2008
  11. Puddin' Man
    Ron Seiden Guest
    There's a reason people buy those kits to replace as many philips screws on
    their Japanese bikes as possible with allen key (hex socket) bolts. When I
    put stainless allen key bolts in place of my philips head bolts, I also
    smeared a little anti-seize lube on them. Steel bolts in aluminum (and
    exposed to road moisture) is just asking for something almost impossible to
    remove gently...
    Ron Seiden, May 25, 2008
  12. Puddin' Man
    Puddin' Man Guest
    I hadn't heard of such kits. Available at bike shops?
    Damned if I'd want to replace garbage like that with the same (if I could ever
    get 'em off in the first place).
    P
    Puddin' Man, May 25, 2008
  13. Puddin' Man
    Puddin' Man Guest
    So I'm not the only one to wrestle with such idiot garbage.
    But they actually came off after you squashed 'em with vice
    grips and worked 'em with pliers?
    Do the half moon strips serve any real function?
    Thx,
    P
  14. Puddin' Man
    paul c Guest
    Sounds logical, but I find it hard to buy/locate fasteners that have the
    same tensile rating, often the good looking ones aren't even labelled.
    paul c, May 25, 2008
  15. Puddin' Man
    CBXXX Guest
    I too,have replaced my phillips with Allen SS bolts.Best place I've
    found is www.boltdepot.com for any of my fasteners.Kits tend to cost
    more
    CBXXX, May 25, 2008
  16. Puddin' Man
    oldgeezer Guest
    I started my previous posting with 'Memories... Memories'.
    It has been so long ago that I even forgot what bike it was
    and why I needed to separate the carbs.
    Your picture triggered my memory, because I recognized
    those half moon strips.
    I remembered that I needed the vice grip to get the screws
    out, there was greenish hardened plastic --I took that for
    lock tite-- and that the half moons warped when I
    fastened the new screws.
    So all I really told you was:
    "I used a vice grip to get them out"
    No, I do not know what function those half moons have.
    I did not think about it, because long time ago I was in
    the aircraft business and strips like that were a normal
    way to secure bolts. And 'naturally' I thought they were
    there for that reason.
    But real secure-strips had tang(s) you could fold up
    on the side of a hex headed bolt. And those half moons
    on the carbs had no tangs and the screw heads are
    round.
    So I should have given it a thought. But I didn't.
    Unless you know the difference between a
    Phillips and a Posidriv, read wikipedia for that.
    Rob.
  17. Puddin' Man
    Puddin' Man Guest
    That's OK. It's helpful info.
    I, MyOwnSelf, have tremendous difficulty recalling details of
    outer-space BS. The more illogical the design, structure, etc
    the faster I forget.
    It just blows po' me away: why would they employ alleged super-
    fasteners (or <whotever>), loc-tite, etc just to fasten a lower air
    box to a brace of carbs? All manner of conventional fasteners
    would've made perfectly good sense. And would've flogging come off
    when necessary!
    Damned if I can see any sensible function. But I still
    can't get 'em off, so ... :)
    Thanks, I didn't know about Pozidriv.
    I just looked. They're not Pozi. Wish they were: I've
    got 8 Pozi drivers in my "drivers-for-fasteners-from-
    distant-galaxies" kit.
    Cheers,
    P
  18. Puddin' Man
    oldgeezer Guest
    Ahhh. New info.
    I just saw a picture in a shop manual. The screws
    have hex heads (with a phillips cross, just like the
    screws in your PC) and the half moon strips have
    a tang on both ends that is folded up to a side of
    the hex., preventing the screws to turn loose.
    So I was correct. The strips function is to secure
    the screws.
    But you and I both had round phillips heads,
    thus something must be wrong.
    Either:
    We both worked on a bike that had been worked
    on by somebody who broke off the tangs and
    replaced the screws. Without tangs he did no
    longer need hex heads, but needed loctite,
    or:
    keihin-san ran out of hex screws in 1987 and
    just thought: okay, we'll use round heads and
    loctite until we get a new batch of hex screws.
    I know that things like that happen in a production
    factory. I myself signed waivers for changes
    in production like that.
    Could well be that you and I worked on the
    same batch of Keihins.
    Rob.
    Rob.
  19. Puddin' Man
    oldgeezer Guest
    Stupid me. I focused on that 2-inch image and did not
    RTFM words below it.
    For you to see, I blew that image out of proportions to
    http://www.peterbos.nl/pictures/carb.jpg
    Just read what item #1 is named.
    Nah, it is common practice. I worked for the Quality Dept
    of a Dutch and later also of an American company.
    The US cie had Jap customers among many others
    from all over the world.
    Japs were pretty tough and played everything strict
    to rules. If I had to rank em quality wise; (meaningful rules
    present, rules adhered to) the US-cie would come last.
    Having said that: I own two bloody bikes (identical)
    with rear suspensions that have no lube point and
    a steel allen bolt (inside hexagonal, aka imbus)
    screwed into aluminum that keeps it all together.
    That bolt is impossible to loosen. I froze, blow torched,
    hammered (hit my knuckles), molested hex keys (tools)
    until they resembled a drill, and finally drilled the bolt out of
    one bike's suspension.
    And still can't get the suspension off of the bike.
    Yes, they are Honda's.
    Unfortunately, all this writing does not help you
    to remove the screws.
    Rob.
    oldgeezer, May 26, 2008
  20. Puddin' Man
    Puddin' Man Guest
    OK. "Lock Plate". No problem.
    I haven't owned a Harley since '62. Wasn't much even then
    (just "hummers").
    Tells a tale, b'damn.
    Yeah, but it helped me to sort out the insanity, figger out
    where I stood. Much appreciated.
    HowSumEver, your pic doesn't look like an '87 CBR600. You'd have
    to look at both pics side-by-side: the dividers in the casting
    between each intake are different. Not to say this questions
    your conclusions. I don't see any other plausable explanation.
    How do ya build a mot'sickle?
    Ya gotta have engineering and manufacturing facilities, lots of suppliers,
    etc. Blueprint a design, build a prototype, then troubleshoot. At some
    point in the process, ya just start throwing stuff together and shipping
    bikes.
    How do ya build a 100% solid mot'sickle in terms of structural,
    engineering, and manufacturing integrity?
    You don't. It's never been done. Simply too complex and expensive. And
    it's not what the buyers demand in practical terms.
    And, of course, the same goes for automobiles and all manner of other
    human contrivances.
    Prost,
    Puddin'
    Puddin' Man, May 26, 2008
