Mwahahahah!
Discussion in 'UK Motorcycles' started by Champ, Sep 27, 2009.
  1. Champ
    Yesterday was a good day.
    Alex and Black Mike turned up just after 10am, and we set to dropping
    the road motor out of my ZX10R. All went very well, and it was on the
    floor by midday. The only interruption was Gyp turning up on his new
    (to him) TDR 250.
    So we walked into town to get a bite, and sat and ate pasties while
    watching the totty walk by in the sun.
    Then back to my garage, and we set to fitting the race-spec motor. A
    modern litre bike engine is so small and light nowadays that someone
    like Alex can pick one up and carry it about. Anyway, it went in
    easily enough, and the three of us just worked thru until, around 4:30
    pm, it was ready to test run. Ignition on, press the button, and
    immediately it fired into life. And sounded fantastic with it's new
    full ti exhaust system.
    We then bolted on fairing etc, and I took it for a ride. Bearing in
    mind it was running a road spec ECU, and therefore the fuelling would
    probably not be right, I limited myself to 2/3rds max revs and only a
    couple of seconds at a time at full throttle, but **** me it goes
    well. The front lifts in 1st gear at 5k revs, and in 2nd at about 8k
    Then Gyp and Andy B turned up, so I let Gyp have a go, while I rode
    his TDR 250. Which is a lot of fun, but I suspect the power valve is
    fucked, as it has nothing below 6k, and everything above it.
    Then the five of us went to the pub. And Burnt joined us. And then
    to a curry house. And we told lots of old, tall stories, like you do.
    Next steps on the bike are:
    - get it running with the race kit ECU
    - get it set up on a dyno
    - fit modded, longer swingarm, with underslung brembi
    - fit dymags
    - get it re-painted
    It's going to be a beaut!
    Champ, Sep 27, 2009
  2. Champ
    SD Guest
    Two rear brakes? Surely that's overkill.
    SD, Sep 27, 2009
  3. Champ
    Pete Fisher Guest
    I thought that was exactly the sort of behaviour expected from a power
    valve 2 stroke? Certainly from an electronic power valve, or is the TDR
    one mechanical? On a GFR there is nothing (OK in relative terms for a
    125) until about 7k when the solenoid kicks in and the valve starts to
    open.
    You are meant to ride them so that the valve stays open. Which can get
    interesting in the wet.
    | Pete Fisher at Home: |
    Pete Fisher, Sep 27, 2009
  4. Champ
    Really? My understanding was that the PV is there to fatten the power
    band, thus allowing more extreme top-end tuning. Basically, it
    maintains a more constant exhaust port open period, thus matching the
    spannie pressure wave timing over a wider RPM range.
    Doesn't alter the fact that highly-tuned strokers will always be
    pretty flat alt lower revs.
    Pip Luscher, Sep 27, 2009
  5. Champ
    Pete Fisher Guest
    I suppose it depends on what you mean by 'nothing' or 'flat'. A GFR is a
    special case TBF. Being electronic power valve means it literally opens
    with a bang once the tacho reaches a certain rpm. In fact, when my #1
    suffered a broken wire on the reg/rec and the battery was going flat
    there wasn't enough voltage to open the power valve even if you got the
    revs up. This transformed it into something more like a Suzuki 120 until
    I got it home and sorted it out.
    Up to 7000 it is like riding a bantam, from there to the red line more
    like a TZ125. Claimed power is 30 BHP.
    I've never ridden a TDR250 or an RD250LC, so have no idea how flat they
    are at lowish revs if working properly. Presumably the YPVS system is
    more progressive.
    Paging Lozzo.
  6. On Yamahas, it's there to vary the port height.
    The Older Gentleman, Sep 27, 2009
  7. Champ
    It should be, yeah. It's a rotating part which "infinitely" varies the
    port height depending on revs, controlled by a servo. Up to a certain
    point in the rev range it'll do nothing, then it'll gradually open,
    after which it's wide open til the redline.
    The TDR is still a stroker. All the valve can do is fatten the bottom
    end a bit and, at least where YPVS is concerned, smooth out the jumps on
    the way up.
    The RGV has something more like your GFR - two valves, opening at
    different points (8500 and 10000, or thereabouts), giving two fat jumps
    in the power curve. It has pretty much **** all below 8500, glorified
    trundling power til 10k and then goes batshit crazy. And I wouldn't have
    it any other way.
    ogden, Sep 27, 2009
  8. We were somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Champ <> saying
    something like:
    Nice one.
    Any progress?
    Surely the proddy race guys know something about this?
    Ok, given that a road ECU would be required for a proddy racer, there's
    bound to be someone or more than one who's fitted a race ECU to a road
    loom.
    Fwiw, I bet it's annoyingly dead simple.
    Grimly Curmudgeon, Sep 27, 2009
  9. Champ
    Well done those merry men.
    Wish I could've joined you, but after a day of humping several loads of
    broken-up concrete to the tip I could barely move. I'm definitely too
    old for this shit!
    Krusty, Sep 27, 2009
  10. Champ
    TZR and TDR250s are extremely tractable in the middle part of the rev
    range, but flat as a fart just off tickover. The Powervalve doesn't
    start to open until about 6K revs, but it should still be fairly
    torquey below that from 2.5K upwards. You know when the valve opens as
    the tacho needle buries itself in the redline.
    Lozzo, Sep 27, 2009
  11. Champ
    Yes: by varying the port height, you vary the period the port is open.
    The engine will be tuned for maximum power when the valve is fully
    open; at lower revs the second reflected wave will hit when the port
    is still wide open, so its effort will be wasted and fresh mixture
    will have time to spill into the exhaust. However, by lowering the
    port at low revs, the piston will close it off sooner, so the
    reflected wave will hit it closer to the point wher the piston closes
    it off. The timing of the reflected waves is more-or-less fixed by the
    geometry of the expansion chamber.
  12. Champ
    TBH, the only power-valve bikes I've ever ridden have been 'crossers.
    Oh, 250LCs don't have power-valves!
  13. Champ
    Pete Fisher Guest
    I thought the later one did.
  14. Champ
    Some ideas on paper.
    well, there isn't much actual 'proddy racing' anymore - it's been
    re-invented as Superstock, and you are allowed to do a limited amount
    of things. But, running a kit ECU would almost certainly be illegal,
    I'm sure.
    Champ, Sep 27, 2009
  15. Champ
    I thought you had a different sort of humping in mind.
    Champ, Sep 27, 2009
  16. Champ
    Err, there was an (I think) RZ250 that was US-spec and had a PV engine
    in a 250LC-alike, but I didn't think they were imported into the UK.
    Paging Lozzo!
  17. Champ
    Pete Fisher Guest
    Ah. I wonder if those blighters I used to have to race against in the
    Formula 50 racing club[1] on my 250 single had got hold of them.
    [1] GP125s, 250 singles, 20 LCs and unlimited four stoke twins in one
    race!
  18. Champ
    Pip Luscher wrote:
    Nope. The RZ250 you're thinking of was basically a 250 version of the
    350 Powervalve we got, but made for the Japanese market. The original
    4L1 250LC was also designated RZ250 for Japan.
    Lozzo, Sep 27, 2009
  19. Champ
    It's certainly illegal in MRO Superstock 600 class. You can change
    stuff like shocks, plastics and exhausts, but we even have to use stock
    screens[1] and brake discs. One poor sod got excluded from the results
    because he was running a wavy rear disc on his hopelessly outclassed
    2000 model R6, which was right at the back of the pack anyway. It
    wasn't like he'd used the damn disc to his advantage cos he was still
    slow as **** with it.
    [1] We play cheeky here because there was a special edition 675 that
    came from the factory with a Triumph branded double bubble screen, so
    we use one of those. All the other bikes out there have shitty low
    screens that force you to crawl under the paintwork to make effective.
    Lozzo, Sep 27, 2009
  20. Champ
    Pete Fisher Guest
    Reminds me of the only time raced my Morini Sport. It was a VMCC
    meeting at Snetterton, but featured a production race. Good job really
    as my 1929 350 Raleigh blew up in practice.
    The scrutineers got very huffy about a 'production' bike with clipons
    and a bum stop seat. "Came from the factory like that", was my answer.
    Still second from last in the 350 class anyway - pesky RDs again.
Similar Threads
Loading...
