My gearbox
Discussion in 'UK Motorcycles' started by Paul Carmichael, Jan 18, 2010.
  1. May have asked here before, but don't remember. The Blackbird jumps out
    of 5th now and again (under power - ouch). Will this just mean a new 50c
    spring or summat, or do I scrap the bike now?
  2. Paul Carmichael
    Cab Guest
    Dunno. Thought you may be interested in this:
    http://news.bbc.co.uk/1/hi/england/london/8464222.stm
    I am. :)
    Cab, Jan 18, 2010
  3. Paul Carmichael
    But that's a ham, not a pumpkin.
    CT, Jan 18, 2010
  4. Mmmmmm, pata negra. Lovely. Really does melt in one's mouth. Don't be
    thinking it's anything like that plastic stuff Manolo serves up in "El
    corner caff" with cheese, on stale bread.
  5. Paul Carmichael
    Lozzo, Jan 18, 2010
  6. But there's more to a pig than a pair of hams. I had some lovely pork
    loin last night.
  7. Paul Carmichael
    Colin Irvine Guest
    +1. It's about time one of the channels showed it again.
    Colin Irvine, Jan 18, 2010
  8. Paul Carmichael
    Colin Irvine Guest
    Food for thought there.
  9. Paul Carmichael
    What's a *channel*, grandad?![1]
    [1] No, I don't do torrents either :eek:)
    CT, Jan 18, 2010
  10. Paul Carmichael
    Cab Guest
    Erm, don't forget that I'm related to a Spaniardess and that the art
    of Jamon has been learnt in the same way that Luke Skywalker learnt
    the force.
    As it goes, whoever buys that will need to eat it quickly, as it won't
    keep the same flavour in an English climate.
    Cab, Jan 18, 2010
  11. Paul Carmichael
    Cab Guest
    It's expensive, but decent ham can be anything from €50 to €100/kg
    (sometimes more), so this one is probably about 4-6 times the price in
    a decent jamoneria?
    I quite often purchase from here:
    http://maps.google.co.uk/maps/place...amoneria&hnear=madrid&cid=8080041775396363391
    Cab, Jan 18, 2010
  12. Paul Carmichael
    bod43 Guest
    hmmmm! jumping out of a gear.
    Could be anything really. Best talk to someone
    who knows wot goes wrong with the model.
    Otherwise -
    weak detent springs
    worn positive stop bits - between pedal n drum
    worn selector (crescent or pin or both)
    end float on "fixed" (non sliding) gears
    end float on shaft(s)
    worn dogs - either side
    worn selector drum
    end float on selector drum
    some arbitrary combination of above
    Very tough without prior model experience
    or a big pile of shiny new bits.
    If you decide to take it apart I could perhaps
    come round and hum n haw, if it is not too far.
    I am SE lonon not too far from chez TOG.
    Best idea might be to convert it to four speed:)
    bod43, Jan 19, 2010
  13. Well, perhaps I'll start undoing things and have a kind of a blog, with a
    photo after each "undo". Popping round from SE London isn't really going
    to work.
    Where's my HBOL...
    Paul Carmichael, Jan 19, 2010
  14. Hmm indeed. Jumped out of 4th today. Under hard acceleration. I'm a tad
    concerned.
  15. I don't get any noticeable warning. It just pops out.
    HBOL says "overhaul transmission".
  16. Honesty time. If I use the clutch, it doesn't happen.
  17. I thought you'd say that. It's just that I hate using the clutch to
    change up. Some might say that's the problem I suppose.
  18. Paul Carmichael
    Domenec Guest
    Now go to the "Changing without clutch" thread in EChM and warn them
    what resulted of your bad habits.
    Domenec, Jan 19, 2010
  19. Just read the entire thread. They're all wibbling on about something
    called "cluch cables". What's one of them then? Oh yes, I had one on my
    Ford Cortina mk 2. In 1979.
  20. Paul Carmichael
    DozynSleepy Guest
    It's only a problem if it jumps out of gear now and again ...
    DozynSleepy, Jan 19, 2010
